Question about Sanyo Office Equipment & Supplies
I have a sanyo Pro-X SVGA Mulitverse Projector model DGU-DSU20E I am looking for the manual, and we are getting black and white square dots in left corner and can you hook up a xbox360 to it? Thanks
  • 84 Answers
SOURCE: Sanyo PRO Xtrax Multiverse Projector powers on but no reflection appears
broken lamp?? check for little cracks in the bulb bar.
If lamp is discoloured( dark grey), overheating is cause, no cooling after using the PJ.
Posted on Sep 25, 2008
SOURCE: Sanyo Pro Xtrax Projector
not all computers are F4 - some are F7... - If there is not a small graphic on each Function button - just press and hold your function button and I'd start with F3 then F4 then F5 and so on - often your image will appear on the projection screen and disappear from your laptop - just re press Function and the appropriate key - you may also need to change your display - go to your control panel then display then settings and you will want 1024x768 - as far as cables you will need a male VGA that will plug into (usually blue) connection on your laptop and then depends on what type of projector you are using - it may take a VGA or RGB (5pin cable ~ red green blue horizontal vertical) make sure that in your menu settings that you have it set to the same as the input you have plugged into
Posted on Feb 13, 2009
Master Rod
  • 8 Answers
SOURCE: Power Point Presentation Using Sanyo Pro Xtra X Multiverse Projector
Don't forget to select the Fn key and F4 on HP laptops. It could also be the Fn key and F8 depending on the laptop brand. It is the apple key and the F7 key on a Mac notebook. On Laptops this will toggle the video to the aux port where the monitor cable connects to the projector. There are 3 modes. video on the laptop screen, video on the laptop and projector, or video to the projector only.
Master Rod
Posted on May 08, 2009
  • 1139 Answers
SOURCE: Sanyo Pro xtra X Multiverse
Depending on the age of the projector it sounds very much like your colour filters have become "burnt out". This unfortunately happens after some time when the colour used in the glass of the filters fades. Once the colour fades in these filters there is nothing you can do apart from buying a new set of filters which can be very expensive. I am sorry to be the bearer of bad news but with most projector problems they do tend to be expensive to repair.
Posted on Sep 16, 2010
SOURCE: Help! Our Optoma DLP
There is a lense behind the main focus lense that's causing this. Flakes of the colored tint are coming off causing white light to shine through. If you look at your projection, you can see black spots as well, these being the flakes that have re-located themselves. I dug into mine deep enough to diagnose this, to actually replace the little lense would be a little tricky. The unit has to be mostly disassembled. Also I haven't been able to locate a vendor who sells the part. Optoma wants you to send it in so they can do the repair, and won't part w/ these component level parts.
Posted on Nov 20, 2011
Dell 1201mp projector screen flickering black lines with svga cable?
If you projector can not process SVGA then no there is nothing you can do
Dec 16, 2015 | Dell 1201MP Projector
My Sanyo PDG_DX100 projector only 100 hours now, its started white dots and balck dots how to fix it. if DMD chip problem, how much it cost me.
Sanyo PDG DXL100 1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.I supply the DMD chip and the price is USD200 We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel, motherboard, powersupply ... with high quality and competitive price. any questions, feel free to contact me have a nice day! Jerry Lampdeng Limited
Jul 23, 2014 | Sanyo Office Equipment & Supplies
I have sanyo projector model PDG-DSU20E. Few white spots appeared on the right side of the screen. Gradually the spots has filled the right side about 1 feet is width till bottom of the screen. Now few...
1,white spots appeared on screen,means the DMD is broken,you need a new DMD.
2,the projector running off after only a few minutes,means the Inductor (Sensing element),near the Color Wheel. Use a cotton swab moistened with alcohol to wipe the Inductor.
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Sep 11, 2013 | Optoma PRO250X Projector
I am looking for a manual for my projector and wanting to know if a xbox360 can be plugged into it. We are also getting white and black spots on the screen?
Yes you can plug in your xbox into it. A manual can be found online for a price but to find a free one will take some digging. Black spots are usually a dirty lens but with white spots there will have to be more digging.
Jan 06, 2013 | Sanyo Office Equipment & Supplies
White dots on the screen
Need more info. But initial suspicion is there is a problem with your projector.
Are they stationary and always in the same position? You may have bad pixels.
Are the dots there with no signal going to the projector?
What is connected the the projector? Detail the video path - try all the sources. The dots still there and in the same position on all sources?
It is probably your projector.
If some of your sources are fine - the problem might be from a connected source.
Hope this helps.
Aug 26, 2012 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
How do I get a manual for a Sanyo Pro X Projector?
Hi, thanks for posting your Question,,
Don't really know the model your looking for the manual..But you can use the below link to see available manuals for Sanyo Pro X Projector.
http://www.retrevo.com/samples/Sanyo-Projector-manuals.html
http://www.myprojectorlamps.com/projectormanuals/Sanyo.html
Take care.
Sep 15, 2011 | Sanyo Audio Players & Recorders
My Acer X1130P has white dots (dead pixel)..... How can I fix the problem
You will most likely have to get the DMD chip replaced. I suggest you get a quote from the local Acer agent as to how much it would cost for this repair.
Aug 22, 2011 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
No signal input from computor to projector
I have full sanyo schematics available at http://yama.co.za/forum/index.php?topic=146.0
Im sure you'll find what you are looking for there.
Enjoy
May 15, 2009 | Sanyo PLC-SW35 Multimedia Projector
Projection issue
sounds like you might need to change the KEYSTONE settings
Nov 14, 2008 | Sanyo PLC XU35 Multimedia Projector
74 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
