Question about Samsung DLP HL-P5663W 56" TV
Samsung hlp5063wx/xaa vertical lines on picture
3 Suggested Answers
jerryg50
  • 1667 Answers
SOURCE: 46" Samsung DLP Lines & Freeze up
This is a possible fault in the power supply, and can be a problem with some decoupler caps on some of the boards. The vertical bars and unstability are usually attributed to having high frequency noise and or clocking pulses crosstalking on to the power distribution lines that run through the boards. This can be switching power supply noise, or cross-talk from clocking pulses.
Another thing that can cause your described fault is unstable clocking between the devices that are reading and writing to the data busses. There are a number of data busses running through the set for the boards to be able to communicate with each other.
The tech will use the process of board swapping to service the set, and then do the adjustments as necessary to make sure the new boards match up.
Yes... DLP sets are fairly expensive to service!
This is my personal opinion. If the set is out of warranty, I would change for a Plasma or LCD set. If you compare the performance of these to ther DLP, the difference is very big. From what I am seeing from a service point of view, the DLP's are lower in reliability.
Jerry G.
Posted on May 06, 2008
  • 610 Answers
SOURCE: Our Samsung Model HLP5063WX/XAA - dark images
I suspect that you may need to replace the ballast for the lamp and the power supply board.
Posted on Oct 30, 2009
Testimonial: "Thanks for the assist..."
Why does my DLP TV turn itself off
Try replacing that lamp door switch, this has been known to cause issues in some Samsung DLPs
Contact Samsung at 1-800-627-4368 for proper part#
Oct 21, 2014 | Samsung HLP5063WX/XAA
Samsung dlp
If you have have 40 vertical lines 16 pixels wide: DDP1011 or BCA, DMD panel interference: Replace the DMD board.
Jul 26, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
LNS4695DX/XAA Samsung tv vertical and horizontal lines on picture - all components
Thats usually caused by the Tconn board and or its connection also samsungs have been plauged with tab bond issues with the LCD panel itself. Send a pic of the issue to customerservice@tvrepairworld.com and they will be able to tell you whats happening with it be sure to include the model number with the pic
Mar 13, 2012 | Samsung Televison & Video
Oct 30, 2009 | Samsung DLP HL-P5663W 56" TV
No picture on samsung hlp5063wx/xaa
to test this set
unpug the 4 pin conector labeld + and _ 20v on the cg convergence module
if set turns on, the problem is that modual
repaie
replace bolth convergence IC'c stk392-040
also check all 3.9 ohm resistors and both pico fuses.
regards,
daniel.
Jan 16, 2009 | Samsung HCM4215W 42" Rear Projection...
Loud humming noise
Usually a humming noise is a transformer going bad.
Jan 06, 2009 | Samsung HCM4215W 42" Rear Projection...
Samsung DLP HL-P5663W 56" TV Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
