Question about Canon imageCLASS MF5750 All-In-One Laser Printer
Paper sizing error
After I print and envelope I get a paper size error and the only way to clear the error is to unplug the printer and plug it back in. The printer works great up until I manually feed paper. How can I fix this problem
  • 1 more comment
  • loco2902 Feb 07, 2008
    I have the paper sizes error, when I unplug my printer and plug it again, I get the last page I print and then the error again, please some help.
  • Anonymous Mar 02, 2008
    SYSTEM ERROR E100
  • Anonymous Mar 28, 2014
    It says printer is out of paper but isnt. I found very old (2006) notes online about this but no fixes are available now.
Solution #2 WORKS! Just when you use the #clear option.. select "ALL" it will reset everything but all you have to do is simply re set the paper size to letter as it seems to default to A4 size once it re-initializes. What a nightmare this was..
Posted on Apr 01, 2008
I started getting Paper size / cassette / "insert lgl" paper type errors that I could not clear. I tried the update firmware on canon's site and got no answers... but I figured this out. After getting the error, unplug the cable from the computer and the power. Plug the power cable back in and press "copy" button before the error lite starts flashing again. Then press "menu" and "#". Press the <- button until you get to the "#clear" option then press "set". It re-initializes. After doing so, go into the menu and set paper settings to "ltr" or whatever size paper you use.
Posted on Mar 31, 2008
  • 186 Answers
Check the settings for the manual tray paper size. Make sure it is set for envelopes. If it is the paper pick up roller may need to be cleaned. You can try looking where the envelope feeds in and cleaning that rubber roller with a rag and some rubbing alcohol. If this doesnt solve it let me know. John
Posted on Jun 30, 2007
SOURCE:
If envelope printing Canon PC-D340 All-In-One Laser Printer incorrect paper size problems.showing
You need to make sure the paper size and that of the printer matches in the dialogue box.
i.e assuming you a printing an envelop DL size, make sure your envelop is the exact size you choose in your page layout.
secondly, open the properties in the printer dialogue box, where you have letter, change the default "letter" paper to you envelop size.
Note: if your envelop size is not accurate and the actually printed, you will still receive "incorrect paper size" error. At this point I turn of mine and turn on again.
Jul 17, 2011 | Canon PC-D340 All-In-One Laser Printer
Please teach me how to use my HPF4185 to print envelopes. Thanks.
Hi
Use the product software, also known as the printer driver, to change the print settings for your envelope size and type. Then, use the Envelopes and Labels tool in Microsoft Word to select your envelope size.
Step one: Adjust the print settings
-In Microsoft Word, click File , and then click Print .
-Make sure that your product is in the Name drop-down list box, and then click Properties .
-Click the Features tab, or the Paper/Quality tab.
-Select an envelope size from the Size drop-down list.
-If the required paper size is not in the drop-down list, follow these steps to create a custom paper size.
-Select Custom from the drop-down list.
-In the Custom Paper Size dialog box, type a name for the new custom size.
-In the Width and Height boxes, type the dimensions.
-Select the unit of measurement, and then click Save .
-Click OK to close the Custom Paper Size dialog box, and then click OK again to close the Properties dialog box.
NOTE: You must exit the Properties dialog box to apply your changes.
Open the Properties dialog box again, and select the new custom size from the Size drop-down list.
-Select the paper type.
-In the Paper Type or Type is drop down list, click More .
-Click the desired paper type, and then click OK .
-Select the paper source from the Paper Source drop-down list.
-Change any other settings, and then click OK to close the Properties dialog box.
Step two: Set the correct envelope size
-Set the correct envelope size in the Envelopes and Labels dialog box before printing envelopes.
-In Microsoft Word, click Tools , click Letters and Mailings , and then click Envelopes and Labels .
-In the Envelopes and Labels dialog box, click the Envelopes tab.
-Click Options .
-From the Envelope size drop-down list, select the required paper size. If you created a custom paper size, select the new custom paper size from the drop-down list.
-Click OK , and then click Close to close the Envelopes and Labels dialog box.
-Click File , and then click Print to print the envelope.
NOTE: When you finish printing the envelopes, return the paper size and the paper type settings to the defaults.
Regards
Riztech
Oct 30, 2010 | HP Deskjet F4140 All-In-One InkJet Printer
Everytime I try to print an envelope using my Canon imageRUNNER 1023iF I get an error message. I'm using a Microsoft Works Word Processing program. I have loaded the envelope tray and nothing happens...
To get rid of error, unplug machine.
Sett. the correct paper size ( size of envelope ), paper type (envelope ), both on printer properties ( when you prompted to print ) and on machine ( when you put envelope on bypass, machine auto ask you ).
Do not forget to tell printer that he needs to take paper from bypass ( printer properties )
Hope that helped
Jul 04, 2010 | Canon imageRUNNER 1023 Black and White...
Paper size mismatch for A9 envelope (5.75x8.75)
Set the envelope size in the printer properties paper size list to A5 (5.83 x 8.27) which is only .08 inches wider than the short side of an A9 envelope (5.75 inches). The paper size sensor on the HP6520 printer must not be sensitive enough to tell the difference. I can print A9 envelopes just fine using the A5 setting.
Jan 20, 2010 | HP Photosmart C4580 All-in-One - InkJet...
Trouble printing envelopes on kodak esp3 printer
Have you tried this procedure?
Loading Envelopes
You can load plain envelopes into the paper tray of your Kodak ESP 3 All-in-One printer.
Important Do not use envelopes with cutouts or cellophane windows.
1 Remove any other paper from the paper tray.
2 Insert one or more envelopes into the right side of the paper tray with the print side down and
the envelope flaps on the right, pointing left.
3 Squeeze the paper-width guide and move it to its right-most position up against the envelopes.
4 Leave the paper tray open while the envelopes are loaded.
If you have and it's not printing correctly, there is probably a problem with the document you're trying to print.
Jan 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Hp psc 2410 photosmart
marglet, Turn-off and unplug the printer for a couple of minutes...there may be improper setting stuck in the printer memory. then plug it in and try to print the envelopes..if that doesn't work...Make sure there aren't any custom print settings causing this. Lastly...Try updating the drivers. Download the latest drivers from the site. http://www.shopping.hp.com/webapp/shopping/search/search_request.do?pageName=HP+printers_land Good Luck, Tim
Feb 03, 2007 | HP PSC 2410 All-In-One InkJet Printer
Canon imageCLASS MF5750 All-In-One Laser Printer Logo
970 people viewed this question
Clive
Clive
old marine
old marine
Ekse
