Question about Toshiba SD-3960 DVD Player
Toshiba 2805 5 disc dvd player - disc error - Toshiba SD-3960 DVD Player
5 Suggested Answers
SOURCE: Toshiba DVD SD-3980SU2 or SC2 player loads every disc as "bad disc"
Toshiba says:
Information for Owners of Toshiba SD-3980 and SD-K750 DVD Players spacer.gif To ensure the satisfaction of our customers and to maintain the integrity and quality of our products, Toshiba America Consumer Products, L.L.C. is issuing an important product update. This is not a safety issue.
Toshiba is committed to customer service and to continuously improving the quality of its products. It has come to our attention that certain DVD players bearing the model numbers SD-3980 and SD-K750 may at some point in their life stop playing discs due to a component part failure. In such case, the error message "bad" will be shown on the unit's display. Affected units will have "SU2" at the end of the model name (e.g., SD-3980-SU2), which can be found on the back of the unit.
If you own either of these models and experience the issue described above, please contact Toshiba Customer Solutions at 1-800-631-3811 for information on how to obtain a replacement unit.
Posted on Jan 18, 2009
praky16
  • 744 Answers
SOURCE: Toshiba SD-K770 DVD player flashes error and BAD DISC
hi... the problem might be in ur dvd... If ur dvd is perfect and u found that ur player has some problem means the best solution is that to clean up ur dvd player lense which plays a vital role in reading ur dvd when u insert into it...For cleaning up ur lense all u need is a lense cleaner dvd available in electronic shops.. u can purchase it and play that dvd as normal one.. ur problem will get solved..
thank u rate me!!!
Posted on Feb 07, 2009
SOURCE: toshiba sd-310vu dvd player makes
The motor that spins the disk rests on rubber shocks. The rear shocks wear out over time allowing the disk to set uneven and rub eventually stopping the disk and giving a disk error. To fix simply put one small flat washer under each of the rear shocks this will level the motor and stop it from rubbing.
Posted on Mar 13, 2009
localwonder
  • 6784 Answers
SOURCE: disc error
HI. if this error is coming up on every disc you insert, this will be a sign of a serious malfunction that is localized in the optical lens assembly. It could eb that the tracking rail motor is damaged or, the entire assembly is not functioning. replacing this failed assembly will fix this issue.
Posted on May 29, 2009
How can I play a disc reading incorrect and error It worked fine this morning
Try some other discs first or try that on another player, usually if cannot read the disc either a dirty of bad Optical Pickup in the player.
Dec 16, 2012 | Toshiba SD-V291 DVD Player/VCR
Toshiba sd-k510 disc error
Have you tried several discs?If so,then your DVD player may need servicing and a probable lens replacement.
Thanks!
Jan 04, 2012 | Toshiba SD-K510 DVD Player
Toshiba Satellite 2805-S202 DVD rom is shot, any possible cheap solutions?
Go online to ebay, and check out new and used DVD drivers for your make and model.
Dec 21, 2010 | Toshiba Satellite 2805-S202 Notebook
Toshiba D-VR16SB Gets error code: e4 54037380
This DVD combo will only read DVD-RW and DVD-R format discs the manual says that Verbatim DVD-RW 2X are the best to use also TDK DVD-R
Apr 25, 2010 | Televison & Video
The dvd player does not read every cd or dvd.
No-disc errors are usually caused when the DVD or the laser-lens pickup has become dirty and causes the DVD player to not be able to read the DVD.
http://www.ehow.com/how_2036277_fix-error-dvd.html
Dec 26, 2008 | Toshiba SD-140E DVD Player
I cannot open my Toshiba Satellite 2805 S301 DVD-ROM drive.
Hi Packman,
right click the DVD drive, an choose "push it open" -> direct translated from Danish :-)
. but I´m sure you´ll find it.
regards
/Teis
Dec 16, 2008 | Toshiba Satellite 2805-S301 Notebook
Disc Error
Simple issue, the lead laser cannot read any data, for better result please try to check with the DVD shop.
Hope you like my solution please rate me solved.
Best regards,
Philip
Nov 17, 2007 | Toshiba SD-3980 DVD Player
Toshiba disc error
Check formatted disc see if it's +R,-R and see if Toshiba will play homemade disk or just disc recorded in different format.
Jun 25, 2007 | Philips DVP642 DVD Player
Disc will not play
Have your set check by a tech according to your explanation it seems that you had broken a gear on inside your set.good luck to you
Apr 05, 2007 | Toshiba SD-2805 Multi-disc DVD Player
Toshiba SD-3960 DVD Player Logo
41 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
