The ignitor on one of the burners does not spark and needs to be replaced but I am stumped on how to remove the burner to get at the ignitor
SOURCE: Replace burner spark ignitor?
Electric igniters are usually very simple installs since they usually only come with a common and hot wire, and the igniter clips on to the burners right near the burner top for ignition. The easiest way a DIYer can do this themselves is to slowly take apart the current ignitor after lifting the top of the range up and taking note of every thing's placement. If you have the direct OEM part, then it either work or will not, based upon the fact that it's either the ignitor or the switch for it that has gone bad.
To test if your igniter has gone bad, remove it completely. (it should only be a small cylinder with two prongs, and two wires coming out the other side) Be sure not to strip any screws as heat from the oven will make them hard to remove. From there, you'll need to jump the connection on the top of the igniter with a conducting piece (ie: aluminum foil or wire), then test the common/hot wires with your circuit tester or volt meter. A solid tone or light means that your igniter is good, and the problem lies somewhere else.
SOURCE: GAS STOVE
yep replace the bottom ignightor take out the rackes remove the two bott screws in the oven remove the bottom plate and just keep going down
SOURCE: kitchenaid gas stove left back burner won't light. hear clicking
I have a Kitchen Aid gas stove. All the burners will not light. No clicking, NOTHING. Is there a lighting switch or something that needs to be replaced ?? Or do I replace all 4 lighters ??
SOURCE: Ignitors won't stop sparking
If your ignitors on the burners continue to click after cleaning it is because they are wet. The spark module is not sensing the flame is on therefore still telling it to click. Just leave all burners on high for 20 minutes until they dry out and stop clicking. The clicking is not dangerous. Just annoying. If they continue to click you may have some grease residue or cleaning residue on the ignitors. Take a piece of sandpaper, nail filer and file the tips of the ignitors where it has metal above the porcelain white part. Good luck.
SOURCE: Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
