If your Crazart cotton candy maker is no longer producing cotton candy, there could be a few potential issues to consider. Here are some steps you can take to troubleshoot the problem:
- Check the power supply: Make sure that the machine is properly plugged in and that the outlet is functioning properly. You may also want to check the fuse or circuit breaker to ensure that the machine is getting the proper power supply.
- Check the heating element: If the heating element on the machine is not functioning properly, it may be preventing the machine from producing cotton candy. You may need to replace the heating element to fix the issue.
- Check the spinning head: If the spinning head on the machine is not functioning properly, it may not be able to spin the sugar into cotton candy. You may need to replace the spinning head to fix the issue.
- Check the floss bucket: If the floss bucket on the machine is not properly seated or is damaged, it may be preventing the machine from producing cotton candy. Make sure that the floss bucket is properly seated and check for any visible damage.
If none of these steps resolve the issue, it is possible that there is a deeper malfunction or defect with the machine that will need to be addressed by a professional. In this case, you may want to consider contacting the manufacturer or a customer service representative for further assistance.
Do you hear any noise when you turn it on? I need more info so that I can help you better.
