Question about Electro-Harmonix POG2 Polyphonic Octave Generator
My POG2 works by itself, but when plugged in to my pedalboard no sound comes out of my amp.
On my kimball 700 organ, the pedals make no sound.
This can either be an unplugged or dirty connector, or a blown circuit. If possible , get to the connectors on the pedalboard and clean them. If that doesn't fix it, call in a repairman.
Jan 30, 2017 | The Music
All the foot pedals on my 1972 Yamaha Electone D-7 from 'A flat' down sound like 'A flat'. What's happened?
That sounds like a problem with the contacts in the pedalboard or a short in the wiring harness. I'd suggest calling a tech in. You could cause a bigger problem if you aren't experienced.
Feb 05, 2016 | Yamaha Music
My spider III amp has no sound.. lights on but no sound
No, probably NOT a fuse issue here (still lights up, etc.). Are you using the foot-pedal accessory? If so, then unplug it and go direct into amp. Try some headphone via the output jack (sound?) Yes -> GOOD. NO? -> Not so good. May require servicing. Also, check the guitar cord you're using. While unlikely, somehow it might have gotten damaged. Good luck!
Jan 10, 2013 | Line 6 Spider Iii 30
I just get a pedalboard. I have some bosspedals. What about their polarity ?
Be careful, while most pedals are consistent with the 9 volt DC polarity, SOME BOSS pedals use AC inout. Those typically will appear to work on the DC inout, but fail to pass audio through the effect. Read instructions for EACH pedal and verify the requirements.
Jun 28, 2011 | Roland Boss PS-6 Harmonist Pedal
I have a Line 6 spider 3 of 150 w, and i buy a floordboard, when i connect it, the pedalboard damage my amp, burn the processor Board, and i dont know where to buy this part.
It is NOT likely that any significant damage was done to the amp. Find a COMPETENT tech that knows how to fix, rather than replace boards.
May 31, 2011 | Line 6 Spider III 150 Guitar Combo...
How To Use The effect Loop?
The effect loop is to use exteernal effect module... It is NOT to use guitar pedals !!!! The signals are line levels, NOT guitar type levels. An example of a device might be an Alesis Quadraverb. You take the effect send jack and run it into the inout of the effects module and the output of the effects module into the effects return jack. Many try to use guitar pedals and massive distortion results because levels are too high for the pedals.
May 12, 2011 | Peavey 6505+ 112 Combo Amp Combo
I'm trying to add a Digitech X Series EX-7
You CANNOT use the Voodoo as it outputs DC voltage and the EX-7 requires an AC voltage and of 9 VAC and also 1.3 amps at that.
May 07, 2011 | Digi-Tech Digitech X-Series Synth Wah...
How do you calibrate the volume and expression pedal
You'll find it here:http://line6.com/community/docs/DOC-4499;jsessionid=15493B7A2C4B9635CC2C820C7274E79B
Nov 14, 2010 | Line 6 Fbv Deluxe Pedalboard
Wha pedal dysfunctioning
Its cause from an intamitent in other words a make and break in the pedal.
Apr 27, 2010 | Line 6 Fbv Deluxe Pedalboard
I have just bought a used Marshall VS65R. When I
Make sure that when the audio from the speaker cuts, the headphones are still working (try it several times). If this is correct the problem isn't at the preamp or driver tubes. Try to locate the wire that is connecting the speaker with the amplifier. There must be a bad connection at this cable or at the speaker's coil itself. Try hiting with a solid tool (the back of a screwdriver for example) the parts and the connections (not the tubes, just the mountings) while the amplifier is working in order to locate a loosing contact. Once you find it use a soldering gun to fix the connection.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Apr 22, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Electro-Harmonix POG2 Polyphonic Octave Generator Logo
23 people viewed this question
Top Electro-Harmonix Music Experts
Vito Vacirca Jr.
Are you an Electro-Harmonix Music Expert? Answer questions, earn points and help others
