Question about Electrical Supplies
How to check fuel pump on champion generator c49055
2 Suggested Answers
  • 3 Answers
SOURCE: Champion generater. It seems fuel pump
First start small Check to see if there is any clogs in the line also check the fuel filter if the pump is broken go to google and type the model number in and that should bring up everything about that and possibly help you find parts for it
Posted on Mar 10, 2011
Bad gas champion 6800 generator
You need to:
1) replace the fuel in the tank
2) Remove the petcock and clean filter located on top
3) Rinse out tank with clean fuel
4) Clean the carb (replacement carb or carb rebuild kit might be required if damaged by ethanol in fuel)
5) Put it all back together and run the generator.
If you do need a carb or carb repair kit you can purchase them on our website:
http://www.generatorguru.com/champion
Nov 27, 2016 | Electrical Supplies
This gen won't start , good fuel, carb good get's air & fuel spark plug new. any ideas
if it has air fuel and spark then check the compression. if it has all 4 of those then it will be a timing issue but I am willing to bet you are missing 1 of the 4.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Sep 28, 2013 | Champion Fulfillment Champion 2000 Watt...
It won't start. I put in fresh fuel, carb is good get's air & fuel but will not start. what could this be?
Three main things are needed for all small engines to run: Compression, spark, and fuel. I would purchase a compression tester and a spark tester from a local auto parts store. Both are reasonably priced and easy to use. Compression tester screws into spark plug threads, then you simply pull starter rope a few times until needle on gauge stops rising and observe reading. You should have at least 60 psi and should hold awhile. Next, screw in spark plug and hook up spark tester inline, pull handle and observe spark tester. Next, check for obstructions in fuel lines to carb.These simple steps will lead you in the right direction instead of guessing. Good luck. Keep me posted with results and I can help you further.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Champion 3500 watt generator shuts down after 1 min. Not low on oil!
You have a carburetor problem. Stuck float or clogged filter. Gas cannot get into the carb as fast as it is used. Letting it sit for a few minutes will allow the bowl to fill.
Aug 02, 2012 | Champion 3500/4000 Watt Portable Generator
Low current. Will hardly drive a sander or lights. Voltage guages says 120V. Unit is 3 years old but has maybe 10 hours of use max
I found this at http://www.championpowerequipment.com/tech-bulletins/
AVR Voltage Adjustment
This bulletin covers the following Champion Power Equipment models:
C46535 C41150 C41365
C46540 C41155 C75520E
C49055 C41255 C71350E
Note: Read instructions completely before performing service.
1. On the end of the generator locate the round yellow cover held on by two 7mm bolts.
Remove the two bolts and the yellow cover will come right off.
2. At approximately 7 o'clock you'll see a kidney shaped electrical component called the AVR,
which is held on by two 7mm bolts. Remove the two bolts but do not disconnect the wiring
and turn the AVR over so you can see the backside. You should see a round part coming off
the AVR, this is the capacitor. You should also see a small rectangular box with a jewelers
screw, this is your voltage adjustment screw.
3. With a flat head screw driver turn the jewelers screw counter clockwise and this will lower
the voltage. As the screw is turned back watch the volt meter to see adjustment, the
generator must be running to do this.
4. Adjust the screw until the meter reads 250 volts. On model C46540 when the toggle switch
is turned to the 120 side the volt meter should read around 130 volts. Optimum voltage is
121.8 volts.
5. If voltage does not decrease or does not hold a steady output please contact Champion at
877-338-0999 for a new AVR.
If you have any questions, please contact Champion Power Equipment:
Champion Power Equipment, Inc.
10006 Santa Fe Springs Rd.
Santa Fe Springs, CA 90670
Phone: 1-877-338-0999
Email:
tech@championpowerequipment.com
Jul 02, 2011 | Champion International Champion Power...
Champion generater. It seems fuel pump is not pumping the gas . what to do?
Mar 10, 2011 | Champion International CPE 1000Watt...
Starts with ether then dies. I've cleaned the carburator and changed the gas.
Make sure that fuel flows freely from the tank to the carburetor. There should be a petcock (shut off valve) that has a screen on it (inside the tank), which also can become plugged with sediment. Work backwards from the carb, checking also the fuel supply line, back to the tank.
--W/D--
Jan 21, 2011 | Hobart Champion 4500 Ac Generator/Ac...
Electrical Supplies Logo
99 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
