Question about Creda W120VW Front Load Washer
Door lock creda front loader
Can you plese let me know how to chnage the interlock for a front loading washing machine?
it snapped, i got a replacement but i don't want to snap anything else trying to fix it.
thanks
    President:
  • 373 Answers
Read through the following manual and please let me know if this is effective.I have suggested the same to several other people and they found it useful.It deals with simple instructions to solve washer problems.Just to avoid a lot of cost on the technician.Good luck.And please do check the following link.
click here for washer problem solving
Also please do rate my answer if accepted.Thank you.
Posted on Jan 20, 2009
It is not spinning now.
Depending on the make and model top loader or front loader, the most common issues are the lid switch or door lock safety interlock, or the pump filter is clogged and need cleaned. Let me know what machine you have and I can go from there.
Jan 27, 2011 | Washing Machines
Hoover washing machine front loader, has power, have reprogrammed, but still won't start. Door lock light won't come on. For the last few washes before it quit altogether, the time lapse between pressing...
Hi brennanjodi
I think your door interlock needs replacing. Turn off the power undo the front of the door gasket and that will get you to the lock mechanism. They're about £20 to replace.
Adrian
May 14, 2009 | Hoover PE235 Front Load Washer
Door won't open at end of cycle Creda 1000 ecowash front loader
Hi Jenny. Do you have the model No. available?
Most common cause of this problem is
1. A faulty or broken door catch.
2. A faulty interlock. This is the part that the door closes in to.
Some older models have other devices that will prevent machine opening if it has not pumped out fully, or mechanical devices that check for drum rotation that can be knocked during the spin. Could really do with age and model No. of machine.
Apr 04, 2009 | Creda W100FW Front Load Washer
Door not locking and program reverting straight to end
initially i would replaced the door interlock then if no result the control boart could be faulty.
Mar 13, 2009 | Zanussi ZWF1430W Front Load Washer
Door interlock
Probably blown a track on the timer pcb, you need to remove the timer to check for short circuit.
Aug 08, 2008 | Creda W100FW Front Load Washer
Door can't be opened
Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure First disconnect the machine power cable from the wall socket. You should remove machine's top cover and then you will have an access to the door lock unit.
Sep 20, 2007 | Creda W120VW Front Load Washer
How can i open the door on my washing machine it wont open
Remove machine's upper cover and you will have an access to the door lock unit. Don't forget to disconnect the power cable first! Good luck!
Aug 01, 2007 | Indesit W 123 Front Load Washer
Washing machine
the wire that is live goes to terminal "l". check which of the other two is neutral and put it on terminal "n". (it is probably the thinner of the two red wires) the remainong wiree goes to terminal "c". usually there is a little circuit diag on the interlock and this may help you
Mar 23, 2007 | Creda W100FW Front Load Washer
Creda W120VW Front Load Washer Logo
117 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
