Question about Samsung SGH-T519 Cellular Phone
My phone receives poor signal. how can i fix the problem
Maybe your network has something to do with that
Posted on Jan 20, 2009
ECM error message
Noise in the phone line, or low signal strength during fax transmission can result in fax failures. Noise or poor signal strength can cause a partial or complete loss of fax information during transmission. When Error Correction Mode (ECM) is on, the receiving fax machine checks the fax information for errors during reception. If the receiving fax machine detects an error, the receiving fax requests that the sending fax resend the information. Resending all or part of the information can make transmission times longer, but helps improve the quality of the received fax.
If the phone line quality or signal strength is extremely poor, sending a fax can fail. Turning off ECM can improve the ability of the product to send a fax successfully when the phone line quality is poor. However, the image quality of the received fax might be poor.
If ECM must be off to send faxes successfully, have the telephone service provider check the phone line quality. For an HP Fax, turning off ECM from the control panel does not necessarily mean that fax transmission will not use ECM. Fax products use ECM as follows.
  • All faxes sent in color use ECM.
  • All faxes sent at the highest transmission speed use ECM.
  • The ECM setting affects only sent faxes, not received faxes.
Enabling or disabling Error correction mode (ECM)
  1. On the product control panel, press the Menu button (c01743394.gif ).
  2. Use the arrow buttons (c01073166.jpg ) to select Basic Fax , and then press the OK button (c01335940.jpg ).
  3. Use the arrow buttons (c01073166.jpg ) to select ECM Mode , and then press the OK button (c01335940.jpg ).
  4. Use the arrow buttons (c01073166.jpg ) to select On or Off , and then press the OK button (c01335940.jpg ) to confirm the setting.
  5. Press the Back button (c01496476.gif ) twice to return to the main screen.
Mar 06, 2014 | HEWLETT-PACKARD HP 2140 Fax
SIGNAL STRENGTH IS EXTREMELY POOR COMPARED TO OTHER PHONES ON SAME NETWORK
your phone antenna have some problem just open your phone if your phone out of warranty and make sure your antenna contact point is clean
May 21, 2012 | Motorola Mobility W173 Cell Phone
Very poor mobile signal
That is the Service Providers tower signal being poorly received or being disrupted/blocked in certain areas.
Best change your service provider using number portability to a reputed one, viz., Vodafone, Airtel, Tata, etc.
Jan 10, 2012 | Cell Phones
GPS Garmin 1450 poor satelittle signal- can't find satelittloes
If the Garmin nuvi 1450 could find satellites at the same location and time before there's something wrong with the built-in receiver / antenna. Because it's not accessible from the outside it needs to be opened to check the antenna connections. Best is to check battery at the same time and replace it - once the problem is fixed.
At some locations there can be poor GPS sat reception - due to line of sight obstructions, such as trees, buildings. For a 2D fix it needs to "see" at least 3 satellites signals.
Jul 05, 2011 | Garmin nuvi 1450 GPS Receiver
My cordless phone is not functioning properly.I get consistent disturbance in the background while talking on cordless.Please help me remove this noise.
This can be due to poor meshing of the base and handset , a poor signal strength that tends to pick up stray EMI signals. Make sure that the antennae of the Base phone is tight and up . Check the voltage to the base phone - if adapter is faulty.
Also check the handset for any loose fittings on the antennae.
If the problem does not resolve then you need technical help to check if the operating frequency or the signal processing is weak and faulty on the base unit. Best you can remove base unit and look for any loose links in RF section or shielding faults in this section that picks up stray signals.
Jan 22, 2011 | Audio Players & Recorders
"Poor GPS Reception" error on iPhone Tom Tom GPS
Unfortunately it appears the iPhone's GPS chip isn't up to much as we've all suspected. Some people can get it working while many are reporting, like you, that they get drop outs and poor signal strength errors. This is happening accross all the iPhone Sat Nav apps so it points the finger at the GPS chip itself, especially as many of these people are stating they have dedicated tomtoms and the like that work fine. I've tried Copilot, tomtom and others on the iPhone 3GS and none are able to keep signal long enough to be any good. In fact they are a complete waste of money. It's no suprise Tomtom are releasing a cradle for the iPhone which includes a seperate more powerful GPS receiver...
Aug 27, 2009 | Tomtom GO 930 GPS Receiver
Failure to receive text messages
Hello marshallcose,
I'm sorry but there are no settings for receiving text's. If you are having issues there are one or two things that come to mind.
Your phone gets a poor signal where you live, and it takes longer than usual to receive texts if at all.
Or there is a problem between your phone and the network signals/towers. The best thing you can try is to call your service provider as they will be the only ones able to make any changes if necessary.
Post back if you have any question's or comments and I will try to be of further assistance. Thank you for choosing Fixya!
Aug 17, 2009 | LG RUMOR Cellular Phone
Cant recieve picture messages
before receiving or sending picture messagers u must activate the MMS settings by requesting ur network provider only then u can send or receive picture msg
if u hav a signal problem nothing can be done
a small suggetion is in stores they sell a external antenna try getting it and fix it
tat helps in signal problem
Jan 17, 2009 | Sony Ericsson W910i Cellular Phone
Poor signal
Need more information.
You said that it was working good a year ago.
this could be several things if the phone has been dropped then the connections n the back could have came lose or your network around your area has been infected by another mast which makes it lose signal other one is wear and tear and get a new phone. sorry to say
Mar 27, 2008 | Nokia 6230i Cellular Phone
Poor reception
1.Sometime due to bad antena, the signal receiving power goes bad, to confirm this, try another sim card in ur handset.So go to service centre to repaire or change the antena of ur handset.
2. Select network manually.
3.Try once ur sim card in diffrent area and in diffrent handset.
Sep 19, 2007 | Samsung SGH-D600 Cellular Phone
Samsung SGH-T519 Cellular Phone Logo
49 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
