Question about Kenmore 16.7 cu. ft. Freezerless Refrigerator
Refrigerator not working properly
My refrigerator temperature is not consistent throughout. The top shelf is not very cold at all and the bottom two shelves freeze things solid? In fact, the back of the refrigerator (inside) is a huge chunk of ice? Any ideas on how to fix this?
  • FixQuickGal Oct 02, 2008
    Same problem here. The top shelf is about 45 degrees but the bottom shelf is about 30 degrees! There is frost on the back wall of the bottom two shelves. My product is a Kenmore Refrigerator that is all refrigerator (NO FREEZER). Model # 253.60722004 I bought this on 6/30/08. It is still under warranty so any help would be appreciated. I do keep it full but make sure to leave room for the air to circulate. I also checked to make sure the light isn't staying on when the door is closed--so that isn't why the top shelf is warmer. :) Anyway, please help. Thanks! ALM
    Scholar:
  • 76 Answers
Laurau In order to better help you I need the complete model number and the serial number of your fridge. Gendos
Posted on Jun 30, 2007
Refrigerator side is not getting cold enough and freezer side has ice forming on the bottom so bad that is freezes the bottom cage/drawer in solid ice. The fan is working as I pulled off the panel to the...
Hello there and thank you for choosing fixya
This is a common problem that often
The first thing to check is the overall internal refrigerator temperature. The proper temperature should be between 35 and 42 degrees. Here are some things to try:
If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly. If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf. If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
Oct 16, 2011 | Refrigerators
I have a Kenmore 17 cu. ft. refrigerator. Model 67741 series.I keep it in the garage mainly for liquids Most everything in the refrigerator freezes. I have turned the dials down to no avail. What do you...
If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly. This is a common problem that often doesn't have a clear, permanent solution. The first thing to check is the overall internal refrigerator temperature. The proper temperature should be between 35 and 42 degrees. Here are some things to try: If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf. If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper.
Aug 21, 2011 | Kenmore Top Freezer Refrigerator
My food in the refrigerator is freezing. How do I fix this? What are the temps that the fridge and freezer should be set on.
Aug 21, 2011 | Maytag MFD2561HEQ Bottom Freezer French...
Vegetable crispers and deli tray freeze food.
This is a common problem that often doesn't have a clear, permanent solution. The first thing to check is the overall internal refrigerator temperature. The proper temperature should be between 35 and 42 degrees. Here are some things to try: If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly. If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf. If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper.
Feb 15, 2011 | KitchenAid KBFA25ER Bottom Freezer French...
Fridge is freezing items on bottom
restrict lower airflow from freezer vents to refrigerator is their a damper air flow control ... try blocking off vent halfway for a day or two next to bottom shelf or drawer how cold is the top shelf of refrigerator refrigerator should never be colder than 37 degrees f"otherwise bad temperature controle or the thermistor
Jan 28, 2011 | Fisher and Paykel E522BLE Bottom Freezer...
Freezer is icing up we have already vacuumed the vents in teh front and the back of the refridge and it is still icing up
Hello, This is a common problem, the first thing to check is the overall internal refrigerator temperature. The proper temperature should be between 35-42 degrees.Here are some things to try:
  • If your refrigerator temperature is closer to 25 degree try turning the temperature up slightly.
  • If you find the temperature varies a lot from the top shelf to the bottom(where it is coldest) try putting produce or other sensitive product on a higher shelf
  • If the temperature is too low and you cant make it warmer by adjusting the thermostats, you probably have a defective thermostat. If so you need to replace it because they cannot be repaired. Other possible problems are a leak in the seal(refrigerant) system, cold air migration(in side by side models) or a defective air damper.
Thanks
Jun 28, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerator gets too cold and freezes all the food
This is a common problem that often doesn't have a clear, permanent solution. The first thing to check is the overall internal refrigerator temperature (see the Appliance Accessories section for a refrigerator/freezer thermometer). The proper temperature should be between 35 and 42 degrees. Here are some things to try:
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
May 26, 2009 | Dometic RM2652 Refrigerator
Fan runs constantly, freezer ice melting, bottom drawer in refrig
  • Mar 24, 2009 | Refrigerators
    Jenn air french door refrigerator
    Can you place the unit into Turbo Cool? once it reaches 34 degrees it will reset to 40.
    This can happen if you've recently added a lot of food lately, such as for a party. The energy saving nature of the unit cannot cope with the influx of a lot of food food from the grocery store all at once.
    If that doesn't do it, stick around and someone will be along to help you.
    Kind regards,
    Worldvet
    Jun 02, 2008 | Jenn-Air JFC2089H Bottom Freezer French...
    Refrigerators Logo
    156 people viewed this question
    Top Kenmore Refrigerators Experts
    Sal De
    Jim Goldsmith
    Jim Goldsmith
    oldblindman
    Level 1 Expert
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
