Question about GE Security Simon 3 Wireless Home Security System
Sensor replacement can I purchase and replace a sensor myself?
  • 423 Answers
Yes you can.
Posted on Feb 11, 2009
Replacing old wireless remote with another
The remote will need to b programmed by the security co your with they have specific codes or rolling codes so they cannot be scammed or hacked by bad guys ..
Feb 18, 2014 | DSC Wls910 Wls910 900mhz Wireless Remote...
Defiant 270 Degree White Replacement Motion Sensor manual
i ave a live switch leg no switch wil sensor function correctly or will it always stay on?
Oct 17, 2013 | Heath Zenith 270 Degree Replacement Motion...
Change battery ws4904p
First, make sure you have the correct replacement battery. Go ahead and get a Lithium CR123A battery. These are rather expensive at retail, so do yourself a favor and get as many as you need at an online source such as Amazon. These sensors require one battery. The DSC glass break sensors in our home required two. Our glass break sensor went out within a week of the motion sensor, so I just replaced all of them. YMMV.
Second, determine which way the sensor is housed in the, uh, housing. The "bottom" will have a small tab with a circle in the middle, like the picture below.
As you can see from my incredimazing MS Paint skillz, use your knuckles to gently tap the sensor away from the tab. It should pop right off. This can be annoying if you don't have lightning speed and cat-like reflexes to prevent it from falling behind the entertainment center.
Once the sensor is removed from the housing, push the battery cover off of the battery compartment. Remove the old battery, and install the replacement in the same direction. Put the cover back on, and then align the sensor in the housing until it is flush with the bottom part of the housing. Remember to recycle the old battery if at all possible. Good luck!
Sep 12, 2013 | DSC Ws4904p Wireless Motion Detector...
Shows: missing sensor % O2
Your oxygen sensor is most likely dead. Here's a guide on how to replace the sensor, and a link to a page to buy a replacement O2 for the Solaris cheap. MSA Solaris Oxygen O2 Sensor
Let me know if you have any questions:
james@idealcalibrations.com
Jul 05, 2011 | MSA Solaris Multigas Detectors - 10049297
I replaced the batteries in the motion sensor and now it appears that I need to learn how to adjust the timing. Is there a manual for the 270 (I think this is the one from the picture)?
there is a slide switch on the bottom of the sensor......test....1 min.....5min...
u may have to reset the sensor....turn power off .....then remove batteries.....wait 5 min....then turn on power....then replace batteries ......do not move the sensor and wait 1.5 minutes...
U can also call heath zenith @ 800 858-8501 and talk to tech support....
Jan 24, 2011 | Heath Zenith 270 Degree Replacement Motion...
Need replacement battery for Simon 3 Home Security System for the smoke sensor. Cannot find one to fit. Could you tell me where or how i can purchase one and what size batteries will fit this part?
Different smokes take different batteries. If you google the part number of the battery you will find it on-line. If you Google the Smoke Detector part number you will be able to find the battery part number.
AlarmProfessor.net
Jun 14, 2010 | GE Security Simon 3 Wireless Home Security...
Auxiliary light was lite on my white-rodgers 1f82-51 thermostate and i have no heat?
follow this guide:
Diagnostic: Set SYSTEM Switch to HEAT and raise
the setpoint above room temperature. Within a few
seconds the thermostat should make a soft click
sound. This sound usually indicates the thermostat
is operating properly. If the thermostat does not
click, try the reset operation. If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating is operating correctly.
Mar 01, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Sensor failure Simon 3 wireless home alarm
the sensor is going out, i would switch it out with another one in your house and see if the problem follows it there.
Sep 02, 2009 | GE Security Simon 3 Wireless Home Security...
Simon 3: A remote window sensor downstairs creates a constant Low Battery beep/message.
it should be a 6 volt, 1.3 amp hour battery. you can get them at batteries plus. best bet is to take the old one with you to the store to ensure that it fits.
Jun 14, 2008 | GE Security Simon 3 Wireless Home Security...
GE Security Simon 3 Wireless Home Security System Logo
128 people viewed this question
Top GE Home Security Experts
Sean
Bill
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
