Question about Archos 704 WiFi Digital Media Player
My Archos 705 is not turing on.
I purchased the Archos 705 at the airport, when leaving USA for Australia,
Used it the first month I was back in Australia. Moved house and put in a box for 4 months. now want to use it once out of storage and not turning on. Charged it overnight (24hours) Still no life. When pugged into mains no lights on 705 unit. When I Attach it to DVR station it shows that power is going though, with green LED light on.
Is this a little thing or a warranty issue. I haven't found user manual yet, in all the boxes (saw it 2 days ago and put it somewhere safe).
    Problem Solver:
  • 13 Answers
704/705 will not power up at all without a bettery that has a little charge. If these batteries are not used they have a tendancy to die. you could try charging it on a DVR for a few days. then when you disconnect it from the DVR immediatly connect it to a DC charger and your lights should then work. Either way I would consider id a warranty claim.
Posted on Jul 16, 2009
2 Suggested Answers
SOURCE: DVR to Archos
That's what the DVR does. All you need to do is play whatever program you would like on your cablebox/DVR and hit record on your archos. It will record it like any program.
DamPinou
Posted on Mar 29, 2008
Can you advise where I can buy a replacement screen for my Archos 705
Hi
You can order the screen for the Archos 705 from this link---
Archos 705 replacement screen
Link 2
Hope this helps...
Daniel
Aug 28, 2010 | Archos 705 WiFi Digital Media Player
Can you connect an archos 605 to a bell 9142 pvr
Archos Dish Network Plug-In says:
  •  Quickly transfer hours of your favorite TV programming from select DISH Network DVR receivers and enjoy the shows you watch every day- on the go.
  •  DISH Network customers with ViP622TM and ViP722 TM DVR receivers can enjoy this next generation of PocketDISH service with Archos 605 WiFi and Archos 705 WiFi models
  •  This plug-in is free for DISH Network Customers.
  •  Not a DISH Network customer? Find out more at www.dishnetwork.com and get the most out of your Archos player today
  • Jan 24, 2009 | Archos 605 WiFi Digital Media Player
    Just got Archos 5 goes into error 101...
    Hi there, these instructions are for the archos 705 but they are the same for the 605.
    A) Download the firmware from Archos and save it to your desktop (Make sure the file name on the desktop hasn't changed from the original download file name)
    B) The Archos 705:
    1- Connect the unit to its power source.
    2- Start the unit in recovery mode: Press the TV button first then the power on/off and keep pressing TV button (do not release it)
    3- The recovery mode will start (the screen that asks for repair or format etc…)
    4- Select "Repair" by scrolling up and down with the TV Button (it is all explained to move through the menu at the top of the Archos screen) (Do not press "Format" at any time)
    5- Now that you are on "Repair" select it to validate your selection
    6- The unit will go to "Plug the unit etc…" plug it with the USB cable to the computer
    8- Wait until Pc should recognizes your Archos (around 5 seconds)
    C) Computer
    1- From your computer select the firmware file you downloaded from the net and put it in your Archos (in the root folder, nowhere else, where it has the folders, music, videos, pictures etc… as a file)
    D) On the Archos 705:
    1- Select "Ok" on the Archos (on & off button) shortly to select and confirm the file is now on the Archos
    2- you are done! The Archos 705 should now read through the file you have transferred and repair the system
    3- DO NOT DISCONNECT the power cable until the process is finished
    4- When done safely disconnect (as you usually do, for Mac trash the letter of the Archos to the bin or for PC's: right click the green icon bottom right of the screen for xp & vista)
    5- Press on/off button to reboot
    Your unit should restart with a fresh repaired, updated system like day one.
    Jan 21, 2009 | Archos 605 WiFi Digital Media Player
    Battery difference between archos 704 and 705 (wifi) ?
    I use the same batteries in both units. The only difference is the colour of the back plate and the label on the inside. Clone and extended batteries are different backs anyway.
    Nov 17, 2008 | Archos 605 WiFi Digital Media Player
    Can not register Archos for WIFI connection
    Switched unit on and held tv button until repair options showed. Selected repair disc then switched off when task completed. Switched back on and selected systems and again selected reset settings and switched off. Then this time I removed the battery and pressed the reset button. Switched back on re-entering all the required data.Everything now appears to be functioning normally.
    Thank you for your offer of assistance,will keep your site on file incase of future problems.
    Aug 29, 2008 | Archos 705 WiFi Portable Multimedia Player
    Archos 604, frustrating problem.
    Ribbon on hard drive came loose, take out battery. remove 2 screws on inside of battery compartment (not the ones mounting the plastic frame) remove 2 screws on side of unit(not all four, tough to get back together if you do. take ribbon and reset it into hard drive first, then unit. slide battery back on and backcover, turn on, problem sould be sovled. If not, try again the ribbon is not seated. it took me 3 or 4 times, about half an hour, with jewlers phillips-head screwdriver. my Archoes was a 604 wi-fi but it shoud work pretty much the same on 404, 504, 604, 605, 705 605 wi-fi, and 705 wi-fi.
    Mar 24, 2008 | Archos 604 Digital Media Player
    Web conection
    http://www.archos.com/products/plugins/plugins_g5.html?country=global&lang=en
    try that one (assuming you've already purchase the plugin and have linked it with your archos account)
    Mar 09, 2008 | Archos 605 WiFi Digital Media Player
    Archos 704 WiFi Digital Media Player Logo
    123 people viewed this question
    Top Archos Audio Players & Recorders Experts
    kaiserh1
     Grubhead
    Grubhead
    Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
