Question about Leviton (102-5G108-RW5)
Switch to io box color coding - Leviton (102-5G108-RW5)
2 Suggested Answers
alikhambati
  • 151 Answers
SOURCE: Hello, I have a 4 port BSNL Dial up internet modem
well if its a standard coding here is a webside where u will see the color coding just need to scrol down and u will find it
http://www.zytrax.com/tech/layer_1/cables/tech_lan.htm
Posted on Jan 30, 2011
Colour coding of cat6 io box
All category cables have the same colors. This config is a regular cable.
Nov 12, 2012 | Computers & Internet
How to connect RJ45 cat5 cable in wallmount I/O box
how i can punch cat 5 cable in cat 5 io box
Mar 01, 2011 | Leviton (102-5G108-RW5)
Hi. Can you please tell me the correct code for the Curtis tv for Cablevision Remote? We have two remotes now, the cable remote cannot operate the volume or the power on/off tv, must use Curtis remote.....
Hello
Codes for Curtis TV with Cablevison remote control are:-
070 004 101 127 236 011 072 081 120 164
*Tip: The iO button will light on for 20 seconds. The
next step must be entered while the iO button is
on.
STEP2 Press the [INFO] button.
The iO button will blink number of times indicating the
number of each digit of the code number. Each digit is
separated by a 1 second interval of the iO button being
turned off.
Example :One blink, three blinks and eight blinks with
an interval of 1 second of iO button being
turned off, indicates the code number 138.
Note :Ten blinks is equal to the number 0.
D. Program the Volume Controls.
By following the steps below, the user can program
the volume controls (Volume UP, Volume Down and
MUTE) . The default volume control settings on the
remote control is TV volume control. If you wish you
can control the volume via your CABLE box, use the
following steps.
STEP1 Press the [CBL] button and the [SEL] button
simultaneously for 3 seconds. The iO button
will turn on.
*Tip : The iO button will light on for 20 seconds.
The next step must be entered while the
iO button is on.
STEP2 Press the [VOL +] button.
STEP3 Press the [CBL] button.
The iO button will blink twice to confirm the
programming.
To return to original state:
If you wish you can control the volume via your TV,
repeat the above steps by pressing [TV] in STEP3 .
OK.
Dec 23, 2010 | Curtis CM13102 13" TV
Electrical box has one red and one black wire and the switch has two balck wires and a green wire. How do I connect them?
If I understand correctly, you are replacing a switch that has a black and red wire?
And your new switch has 2 black wires + green wire
The green is color-code for ground, and it always connects to bare ground wire.
The switch wires are not color-coded (both are black) so they can connect to either of the two wires that came off old switch.
If switch does not operate, they try reversing the two black wires.
As a general rule, the wires inside your box are color-coded.
The color-code information says:
The black is the Hot from breaker box. This wire carries electricity from the breaker to the switch.
The red wire goes to Load (fan, light, motor). This wire carries electricity to the Load when you turn ON the switch.
Oct 23, 2010 | Solar Leviton Decora Sureslide Dimmer...
Hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t print/installed new color'' Let our Experts solve your ''hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t...
hi..
try to install and reinstall the printer cartridge...and also clean the tab circuit of the cartridge and tab circuit of the printer carrier..
if the problem still exist..
rebreak the printer by full-out the power supply...to reset the settings and then turn it back...
Apr 01, 2009 | HP Officejet 5510xi Printer
Io box criping
how can i clour commnation in io's box cat 5 cable
Jan 03, 2009 | Leviton (102-5G108-RW5)
Where do i find the codes to program my remote to the cable box
you can do a auto progrom
first you turn tv on
on the cable remote you have the io button and the tv button you press them both down at the same time for 3 secounds the io button will light up while it is lite you press the channel button up or down till the tv turns off then you press tv again it should blink twice to confirm the code then you will be able to use the remote with your tv if it dosent work take your time when it goes off dont hit the channel button to fast or again or you will load the next code if it dosent work try it again slowly till the tv turns off
Dec 14, 2008 | Polaroid PLA-4250A 42 in. HDTV-Ready...
Leviton (102-5G108-RW5) Logo
1,462 people viewed this question
Top Leviton Computers & Internet Experts
vimal
vimal
ashburton
Michael Galve
Michael Galve
Are you a Leviton Computer and Internet Expert? Answer questions, earn points and help others
