Question about Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer
Wurlitzer OMT CD Jukebox I have two Florescent tubes out
I have two florescent tubes which have blown I cannot see how to remove them and I do not want to damage anything. Could someone please help and tell me how to remove the tubes one at the top left one Vertical upright in the door with a revolving cover.
Also any ideas where I could get replacement tubes.
Any help greatly appreciated.
The tubes are standard "twist" fit, turn the tube about a quarter and it should come out. I had a couple of tubes go around a year ago, I got new ones from Ring Lighting of Leeds, you should be able to get them from one of the DIY sheds (B&Q etc)
18" (450mm) 15 watt, model number 61012 £1.60p each, I was told by a" dealer" that they are specially made for Wurlitzer and cost £5.50p each + vat. I sometimes think some dealers work on the bulls**t baffles brains theory.
Good luck, Graham
Posted on Jan 26, 2009
My Box Was Damaged in shipping, Where can I buy Replacement Plastics and Bubble Tubes.
If you google for "cd jukebox parts" you can find a list of suppliers of all kinds of jukeboxes. You check with a few that work for Wurlitzer and I think you can find what you need.
Mar 16, 2015 | Wurlitzer Jukebox 1015 One More Time...
I have a Wurlitzer Juke Box (One More Time, 1015, Vinyl) & need to replace one of the florescent bulbs in the turning, side cylinder. Someone said to turn the color cylinder a quarter turn & it...
The actual light tube slides sideways into the socket and then is rotated 90 degrees so it clicks (quarter turn). It is physically impossible so wurlitzer added a black plastic cap at the top and bottom of the tube with a bit sticking out that you can use to turn the tube. So look at the very top and bottom of the actual light tube and try turning the black part.
Aug 05, 2010 | Wurlitzer Jukebox CD Player
How can I take out the side florescent bulbs encased in plastic?
Usually the plastic tube has two end caps that hold the plastic tube onto the lamp. These end caps allow the connection pins to go through a slot in the end of the cap.
If the lighting fitting is the turn type then turn the complete tube and over tube by the end caps and remove the tube/over tube. If it is in a lighting fitting where you just push the connection back and pull the pins out of the fitting.
The end caps will have a ridge that the plastic tube fitts into at each end.
I have seen some overtubes have screw on end caps.
Alan Hood
Aug 10, 2009 | Wurlitzer Jukebox 1015 One More Time...
Im looking for laser for model omt cd 100
You are looking for a CDM12 or CDMPro or CDM Pro2
Mar 20, 2009 | Wurlitzer Jukebox 1015 One More Time...
It's a blown fuse on the amp.
You have to undo the cover plate at the top and then flex it to unhook the bottom. Once it is off you'll see the fuses.
Jan 01, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 1015 CD 50 disk - florescent bulbs change
You have to rotate the tube 90 degrees until you hear a click, then it pulls straight out of the sockets at the top and bottom (towards you). In order to grip the tube Wurlitzer put a black plastic cap on the end of the tubes with a bit sticking out for you to get hold of. On models where the colour cylinder is flexable you can actually squeeze it in the middle and grab the tube that way.
Nov 02, 2008 | Wurlitzer Jukebox 1015 One More Time...
Replace florescent tubes in Wurlitzer Jukebox (model 1510)
The column tubes can be replaced by turning them 90 degrees using the small black tabs on the end. They then slide out sideways. The top tubes are twist and pull also but hard to get to. One end goes forwards the other pulls backwards. Removal of the yellow plastic light diffuser is often required. It slides out in a spiral motion.
Dave F.
Jul 21, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Jukebox 1015 One More Time 100-Disc CD Changer Logo
267 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
