Question about Rock & Ice Climbing
Manual for jt e-kast paintball marker - Rock & Ice Climbing
What should I consider before buying paintball gun?
Most paintball markers have either a center feed or a balance sustain. The benefits of a center feed are that the marker is able to use both hands, more adjusted and you can tilt it somewhat so your container remains behind cover. Paintball Gun Buying Guide is the best for you to get the full information.
May 13, 2017 | Paintball Sport & Outdoor - Others
Paintball gun
Paintball guns that are semi-automatic are generally more reliable and rugged than their electronic counterparts as they have a smaller number of moving parts. They are particularly preferred by beginner and intermediate level players who are discovering how to play the game, relying on a reliable gun rather than player skills. To get the guidance you may look on to Paintball Gun Buying Guide.
Jan 18, 2014 | Sport & Outdoor - Others
The paintballs just fall straigt out of the gun or shots like 5 at a time
The part that is bad Tippmann calls a "ball latch". It's a small orange rubber part that keeps the ball in place before the marker is fired. The parts is inexpensive it is common in most paintball stores or can be found online at www.tippmannparts.com
I highly recommend taking this paintball marker to a local pro shop to have the part replaced. You can service this marker at home but is not easy to put together if you have experience working on then, they have a few springs under tention that make it tough to put back together. If you are interested in doing the repair yourself I highly recommend doing it on on a clean floor in a clean room so when you disassemble it it will be easier to find the springs that could shoot out.
One thing that will make it easier is to leave the feedneck on. It will keep one less spring from jumping out at you, just a tip from a pro. I also highly recommend not using a spray lubricant and to only use oils in you tippmann made for paintball guns.
Sep 19, 2011 | Tippmann 98 Custom Act Paintball Gun
Instructions on assembling a bt-4 paintball gun.
http://www.paintballsolutions.com/pdf/manuals/bt/BT-4-manual.pdf
Let me know if you need step by step instructions
Oct 13, 2010 | Paintball BT 4 Combat Marker
Bruizer outlaw paintball gun
There are many things to take care of the paintball gun. The good thing is that with paintball gun so much choice available, you should always be able to find a marker that meets your requirements perfectly. To get the details about each and everything you can refer to Best Paintball Guns.
Aug 26, 2010 | Sport & Outdoor - Others
Fix view loader brawler
The first time you might check with your local paintball store or airsmith and let them walk you through it. That way you can ask questions and see it in action.
You can check out the website and get a parts breakout which will show you how it all goes together in one picture, and the user guide gives you the basic information for standard maintenance. But again, being able to ask question while seeing it done may go a lot farther towards enlightenment.
Play hard, play safe, play with honor!
8^)
Jul 26, 2010 | Tippmann 98 Custom Marker
Air leakage from paintball gun around the barrel area
My first suggestion is to make sure your marker is clean, and properly lubed with a quality oil made for paintball.
Next would be to make sure you're checking with a full tank of air.
If lubing the marker doesn't fix you up, does it quit if you **** the marker? Not a condition you wanna walk around the staging area with, but it may stop the leak.
It can be an o-ring, and if it's been a while since you had any o-rings changed, it may be high time to get a set and change 'em all out, then you know they're all good to go!
8^)
Jul 25, 2010 | Paintball Tippmann U.S Army Alpha Tactical...
Installing a paintball bolt
Take off the quick disconnect to the back of the marker and pull out the bolt and the striker (note that the cocking rod might inhibit the bolt from coming out so pull or unscrew it in order to allow the assembly to come out easily) replace the old bolt with your new one and then replace the bolt and striker assembly into your marker (the hole in the bolt goes down) replace the back of the marker, and secure with the quick release pin. Below are the schematics to your marker, you might want to reference it if you get confused.
http://www.spyder.tv/section/support/manuals/spyder_xtra_05.pdf
Apr 22, 2010 | Tippmann 98 Custom Act Paintball Gun
Paintball gun is rapid firing when trigger is pressed. CO2bottle is full and i have tried other bottles but stillth same.
Tippmanns are known for their reliability and are very simple markers making them very easy to repair. you need oil from a local paintball shop or regular sewing machine oil will do.
On one side of the marker there is a little "handle" for cocking the gun, pull that handle as far back as you can and you will see 1 o-ring. put 2 drops of oil on it and fire it a couple times without paintballs to test it. This solves the problem 9/10 for tippmanns, if not..
Sometimes paintballs can break inside your gun. Look and feel inside your breech (where the paintballs go into the gun) and check for paint. If its dirty this can be causing your problem, strip it down and clean it (refer to your manual if you have difficulty)
on one side of the marker there is a little "handle" for cocking the gun, pull that handle as far back as you can and you will see 1 o-ring. put 2 drops of oil on it and fire it a couple times without paintballs to test it. This solves the problem 9/10 for tippmanns
Jan 08, 2010 | Tippmann 98 Custom Act Paintball Gun
Rock & Ice Climbing Logo
175 people viewed this question
Top Rock & Ice Climbing Experts
RatanbssBD
Level 1 Expert
Bill Boyd
Are you a Rock and Ice Climbing Expert? Answer questions, earn points and help others
