Question about Hoover Washing Machines
Hnwf 6165 cycle stops, lights of 'start' and 'timer' flashes... any clue?
We stopped everything, waited, restarted, it works a few minutes then, flashes again. I cleaned the filter (flooding my bathroom, of course), to no better results. There is nothing I can find in the instruction book to help (nor on Hoover's website)... Any clue?
  • 1028 Answers
SOURCE: kenmore he2 front load washer
remove bottom panel open pump port and ck for foreign objects lean washer toward rear wall this will help help keep water toward rear and reduce flooding floor might try opening door first and dipping out as much water as possible with bottom panel removed reach up to lock area there is a tear shaped plastic peace pull it down to release door
Posted on Jun 02, 2008
MNTECH
  • 1543 Answers
SOURCE: cycle stops after a few minutes,LE flashes on screen
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Posted on May 09, 2009
barkencoa
  • 3463 Answers
SOURCE: Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Posted on Jan 16, 2010
sudel
  • 90 Answers
SOURCE: Hotpoint WMF540 will not start. Lights keep
Had this same problem myself. To get mine to start i have to push the door to until it starts.
Posted on Mar 07, 2010
SOURCE: Hoover HNL7166 'Start Delay' light flashing
Hoover (Nextra series) washing machines
The 'Start' & 'Pause' LED's will flash together to indicate the error code. You have to count the flashes within each 15 second period to get that error code. The start and the pause LED's will flash together at 1Hz (i.e 1 flash per second) within that 15 second time frame, then will continue and show again within another 15secs and so on.
1 Flash = Interlock fault
2 Flashes = Fill time-out
3 flashes = Drain time-out
4 flashes = Overfill fault presure pipe blocked
5 flashes = NTC error
6 flashes = faulty control board
7 flashes = Motor jammed
8 flashes = Tacho fault
9 flashes = Motor triac on module board
10 flashes = Prog Selector or wiring fault
Posted on Aug 10, 2010
NEC vt800 projector troubleshooting
That is a problem with the lamp. Replace it with a known good one.
Feb 27, 2013 | NEC VT800 LCD Projector
Merlin Prolift 230T wont clear / delete remotes from memory
Press 'setup' key for 11s not 'learn' key.
Jun 26, 2012 | Cell Phones
GE dishwasher with tactile board. Worked fine until special fingers caused issue? Now only the CANCEL and timer light-up when CANCEL pressed. Pump runs to drain for 2 minutes. Stops. NOTHING. Dont see...
This should help: PDW8000 series: press the resetbutton once. This will cancel the washing cycle and pump the water out of themachine. PDW9000 series: open the door aninch and wait for the machine to stop. Touch the reset button to cancel thewashing cycle and reboot the panel.
According to the GE Owner's Manual for the PDW9000 series only: If the"start/reset" light is flashing, close the door until the water pumpsout (this takes approximately 2 minutes) and the light stops flashing. When thelight stops flashing, the dishwasher can be reprogrammed and restarted. If the machine is unresponsive, killthe power to the machine by turning it off on the wall switch (if applicable)or turning the circuit breaker off. Leave the power off for 30 seconds,then turn the power back on. If thatdoes not work here is the repair info: Get into the service mode by pressingkeypads #8 and #4 for 3 seconds. Then reset from service mode. LINK to SCHEMATIC
Mar 28, 2011 | Dishwashers
Whirlpool GU2300 Dishwasher. The machine stops for long periods during the cycle. All lights go out. If the machine is opened before the cycle finishes, it will not resume. If I try to restart, the normal...
Hi
Door latch.
Open and close the door to make sure the door latch is securely fastened.
Check the dishwasher wiring for a possible loose connection where it connects to the house wiring.
Fuses or circuit breakers.
Check your house fuses or circuit breakers to make sure you have power to the dishwasher.
Thanks for contacting fixya.com
Oct 24, 2009 | Dishwashers
Icemaking cycle automaticall self stops and cleaning light blinks
ice machine runs one cycle and freezes ice will not release ice block to wire cutter. then after a few minutes the cleaning light starts blinking
Jun 11, 2009 | Kenmore 51lb. Clear Ice Maker
"F" error code in WTW6600SG1 Cabrio Washer
I don't have a solition and am looking for one my duet whirlpool keeps coming up code F
Jul 07, 2008 | Whirlpool WTW6600SW Top Load
Washing Machines Logo
50 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
