Question about Goodman Manufacturing Heating & Cooling
Fan does not come on with either a/c or heat with fan is on auto
Fan works but does not always comes on when unit comes on in either a/c or heat
5 Suggested Answers
  • 124 Answers
SOURCE: Blower fan will not come on when set on Auto in heat mode.
the fan is controlled by a fan center or a stack switch. as burners light and heat up the spring sensor on the bulkhead above burners heats up and turns and a a point energizes the indoor fan if it gets to hot the burners go out on safty. sounds like a fan control is bad tap on them gently and they sometimes break loose but if not then have a pro replace fan control and test heat exchanger.
Posted on Oct 24, 2008
relaga58
  • 158 Answers
SOURCE: Heating part of split system not working but fan outside is
if the cooling is ok then the reversing valve outside may be faulty
Posted on May 28, 2009
FurnaceGuy
  • 74 Answers
SOURCE: I have a 24yr old trane hp the outdoor unit has
If this old unit has a outside transformer then you will need to shut off the breaker and take the wires off the compressor and tape them up. Then turn the breaker back on and it should run.
Posted on Jan 03, 2010
  • 157 Answers
SOURCE: With the thermostat selected to a/c and the fan in
Sounds like there may be a separate thermostat to run the fan when the temp in attic reaches a certain point, this can be disabled
Posted on Jun 22, 2011
Need a quick fix for a Carrier that won't heat. Ac works, fan works, auto for heat doesn't.
Could be the capacitor or the heating element (or igniter if it's a gas unit). Unless you're a qualified HVAC repairman, call your local HVAC company to come take a look at it.
Dec 13, 2017 | Carrier Heating & Cooling
Fan doesn't work in heat mode it works on all other functions. Heat does come out but fan doesn't kick in. Outside unit is operating
AC inside fan doesn't come on AUTO - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 21, 2004 - The inside FAN doesn't run when in AUTO mode. If I leave ... Is the thermostat not working correctly or something in the AC unit causing it to do this? Thanx ... The unit is electric central air-conditioning(heat and cool). It made ... Carrier A/C condenser fan not working
Jul 27, 2012
Heater Fan Doesn't Work on AUTO
Jan 23, 2006
Blower doesn't work in ON position after repair
Mar 25, 2005
Central AC/Heat, Blower Doesn't work on Auto
Nov 30, 2004
More results from www.doityourself.com
Nov 01, 2015 | Heating & Cooling
My blower motor wont turn off in my furnance?
check the fan setting on your thermostat. On means always on, auto/int means only comes on during heating/cooling. if the thermostat is set to auto / int and the fan keeps running? you may have a bad fan relay switch. It may be integral on the primary control board of your unit.
Sep 04, 2014 | Heating & Cooling
Hi, my air handler, when the thermostat is on auto will usually turn on but sometimes it doesn't. When the thermostat is set to "on" it always comes on. This has happened with 3 different thermos
Im willing to bet you have a bad relay or sequencer that energized the fan. If it periodically works when in auto im sure this is your problem. If you have a wire landed on the G terminal you should have your tstat set up as electric heat OR tstat energizes the fan rather than gas OR equipment energizes the fan.
Jan 15, 2018 | Heating & Cooling
Fan wont run on auto
Make sure your tstat is programmed for electric, not gas. Or in the settings you want that the TSTAT CONTROLS THE FAN.
May 23, 2017 | Dometic Rooftop RV Air Conditioner
Brivis Buffalo 85 ducted heating unit, fan is always on
On the unit outside there is a button that says "push man. pull auto" if it is set to push man then the fan will go constantly.
Sep 22, 2009 | Heating & Cooling
Coleman rv rooftop unit, fan runs in on but in auto nothing works
R = HOT 12V
W= WHT- GND
Y = YELLOW / POSSIBLE THERMOSTAT
G= GRND FOR THERMOSTAT
f = FAN
F=FAN
aSSUMING THIS IS A TWLVE VOLT SYTEM- The two f's Would be fan control intake and exhaust - fan direction
White is always ground and so is green.. green is more of a static ground where white is a load grnd.
Red is always hot. in low voltage
I hope this helped. No instructions in kit?
May 18, 2009 | Coleman Mach III Air Conditioner
My ducted heating continually blows cold air thru
Well, if need be, turn the breaker off. Turn it on when you need heat. Sounds like the fan relay is sticking or something if that sort. Is the tstat fan selector on auto?
Jun 17, 2017 | Heating & Cooling
Oct 24, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
65 people viewed this question
Top Goodman Manufacturing Heating & Cooling Experts
Robbie Daniels
Level 1 Expert
zephyrusd
Level 1 Expert
snowmanii
Are you a Goodman Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
