Question about Ingersoll Air Tools & Compressors
Compressor spits out oil when unit is stopped
I have a ingersoll-rand 25hp rotary screw(ep-25) compressor.it spits out oil(ssr coolant) when i shut unit down.this is a packaged unit full voltage with modulation(480 volts,3ph,control volt-110)it uses ssr ultra coolant which is very expensive($500.oo) per 5 gal.i live in the bahamas where there is little to no tech-support including factory authorized distributor.i have changed scavenge orifice check valve as indicated by manual.i also changed all filters including coolant and air fiters.i ran out of coolant and had to use 30w non-detergent motor.did this cause problem?i have also noticed drop in air delivery capacity.i await your responce.i hope this info helps.thank you.
  • allthatf4039 Feb 03, 2009
    thank you jbridger for helping solve my problem.i did have worn parts on solenoid valve.i will contact you to get quotes on coolant and maintenance parts.might have to rebiuld compressor due to lubrication fault.
    Scholar:
  • 89 Answers
MIGHT CAN HELP. NOT AN I.R. EXPERT BUT KNOW A GOOD BIT ABOUT SCREW COMP. ARE YOU SHUTTING UNIT DOWN SUDDENLY WITH EMERGENCY STOP OR SOMETHING. SOME UNITS DO THIS MORE THAN OTHERS BECAUSE THE WAY THE VALVE CLOSES. BURPING OIL THROUGH THE INTAKE IS ALSO CAUSED BY SUDDEN STOP INSTEAD OF THE UNIT SLOWLY SHUTTING DOWN AND THE OIL IS RUNNING BACK SLOWLY. THE UNIT ACTUALLY TURNS BACKWARDS A LITTLE BIT. YOUR OIL SHOULD NOT COST THAT MUCH. YOU CAN CONTACT ME FOR PARTS AND PRICING ON THE OIL. YOU CAN SAVE ALOT OF MONEY WITH AFTERMARKET SERVICE PARTS AND OIL -THEYRE JUST AS GOOD AS OEM.I WOULDNT USE 30W OIL ! YOUR POOR AIR DELIVERY MAY BE AFFECTED BY WORN PARTS DUE TO LUBRICATION. HOW OLD IS UNIT? MODEL # ? CONTACT ME JBRIDGERS@CA-EQUIP.COM FOR INFO & PRICING. ME AND 1 TECH WOULD PROBABLY COME DOWN AND FIX IT FOR YOU FOR AN ALL EXPENSE TRIP FOR FREE. WE ARE IN NC AND DONT GET OUT ENOUGH.
Posted on Jan 27, 2009
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
Ingersoll Rand SSR EP60 60hp Compressor w/ Intellisys 39817655 controller. Need to reset target pressure. What is the secret button sequence to access programming mode on this controller? I am aware of...
OK, Compressor should be shut down and showing (ready to start) in display. Press load/unload button once then press hidden right button within 3 seconds. This will let you access the set point program. It will include language, temperature and pressure, rated pressure,etc. Make sure you look at the data tag affixed to the unit and see what the rated pressure is for your unit. You can endanger yourself and equipment by over pressurizing the components of the compressor.
May 19, 2011 | Ingersoll Rand Stationary Air Cooled...
What does alarm start fault mean on the control panel on a ingersoll rand ssr ep-30 air compressor
I use to start up a 25 HP Ingersol screw type compressor. The only alarms I got were from power spikes which just needed the reset button to be pushed, then the on button - and the low oil sensor would shut it down and give an alarm when the tank was about half way down. They will blow up with no oil so there is a saftey margin on oil level.
Mar 28, 2011 | Ingersoll Rand Stationary Air Cooled...
I have an Ingersol Rand SSR-EP40SE Rotary screw Air compresor. We ordered a new control panel for the unit because the old panel had a burnt resisitor. The new panel was installed and wont start the unit...
First you need to program the controller. Controllers do not come programed for a specific compressor. You will need to enter factory set point and and set all parameters. Horse power, pressure, DOL start or wye delta start etc. The new controller is probably set incorrectly. Look at factory set points on the old controller and copy all the parameters and then set the new controller to those set points.
Sep 06, 2010 | Ingersoll Rand Stationary Air Cooled...
40 hp ingersoll rand rotary screw air compressor keep shutting
I have a ingersoll compreesor that keeps shuting down on high discharg air temp
Nov 12, 2008 | Ingersoll Rand Stationary Air Cooled...
Air Tools & Compressors Logo
471 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
