Question about Weiser Lock Locks & Locksmithing
I installed my gate house electronic keypad dead bolt and it is locking and unlocking backward?.
It beeps but it is backward
5 Suggested Answers
SOURCE: Lock works in reverse
You need to set the door direction jumper pins inside the unit. From LH to RH or vice versa depending upon your door.
Posted on Jun 01, 2009
  • 963 Answers
SOURCE: dead bolt does not align
I have included a link to the installation instructions for the Kwikset 909 lock. I think that if you go through the installation instruction routine carefully, you will solve your problem. Pay particular attention to Step 8, the synchronization routine.
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
Posted on Apr 18, 2011
  • 963 Answers
SOURCE: I have a Weiser Electronic
To determine why your lock is beeping abnormally, please follow these steps:
Take out batteries and unplug powerstrip. (Replace the batteries with new.)
Let it sit for 1 minute, then put the batteries back in and wait another minute.
If it does not beep, the keypad needs to be replaced (17733-1).
If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish).
Navigate to the complete page that I cut this from can be found by cutting and pasting this link into your browser search bar:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Then go to: US & International/FAQ Categories/Keyless Entry/Powerbolt 1000/Search Results/ How do I troubleshoot my Powerbolt 1000?
I suggest calling the appropriate toll-free number and having a conversation with a representative about this problem, first of all to confirm that you need the part before you go through the expense. Secondly, your lock may be new enough for you to talk them into warrantying it, and thirdly, they will be able to get the correct part on order for you.
Good luck--and please provide feedback if this helps!
Posted on Sep 14, 2011
  • 963 Answers
SOURCE: Locked out of house. After pressing code I hear a
Why is my Powerbolt beeping?
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Follow this link to find out how to remove the cover for your Powerbolt:
This link:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
is the "manual" for the installation of the lock. Programming instructions are found on Page 6.
I'd recommend changing the 4 alkaline AA batteries at the same time.
Posted on Nov 05, 2011
How to change baterry o schlage be365
To change the battery on the BE365, you need to remove the inside cover by removing the two screws (one above and one below the deadbolt knob). Be careful to tuck the wires inside the lock so that they will not be crimped when you put the cover back on.
Do you here a beep and see a flashing light? Usually if pressing the Schlage button unlocks the deadbolt, your installation was done improperly. The cam on the base plate must be vertical and the bolt must be correctly installed.
You will always be able to lock and unlock the deadbolt with the inside thumb knob.
I hope this helps.
Dec 04, 2013 | Schlage BE365-CAM BE365CAM613 Oil Rubbed...
I have a gate house electronic keypad deadbolt, but I lost the book. I need to know what to enter to change my passcode
Try this:
1. Press [SET] button for more than 2 seconds.The red LED will light and the lockset will beep twice.You are now in programming mode.2. Enter 123456 (or current programming code) and then press lock button. The red LED will light continuously for 10 seconds.Enter new programming code (six digits) and then press lock button. The red LED will light continuously for 10 seconds. The new programming code is effective.
Dec 04, 2012 | Locks & Locksmithing
Shlage keypad dead bolt unlocks when you press the
Does my Schlage BE365-CAM BE365CAM505 have a feature that allows it to automatically lock the deadbolt without having to enter code and turn the dial?
Sort of. The lock has what is called the "turnlock" feature. When enabled, you have to only push the Schlage button, then manually turn the dial. When disabled, you have to enter the user code, then turn the dial.
To enable/disable this feature, enter your Programming Code--press the Schlage button--Press 7.
Each time you do this, you toggle between enabled and disabled.
Videos for installing and programming can be found on this page:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
Scroll down and find them under the heading Electronic Security--Keypad deadbolt 365
Aug 31, 2012 | Schlage Camelot Deadbolt Keypad, Satin...
I don't know what's wrong with it. I tryed to unlock it and it beeped well everytime i try it just beeps now. Also there's a green light .
There are two things to consider.
The first is if the door the unit is mounted on tends to jiggle when it is windy outside. This jiggling will loosen the batteries inside just enough to set off the beeping. I have two gates and one gate tends to jiggle from slight breezes, setting of the beeping. Finding something like a rubber square pad that you can press to secure the batteries more tightly and maybe use some electrical tape to secure the pad against the batteries will help solve this first condition.
The second condition on the gate I have that beeps is the handyman did not install the unit so that the entire back of the unit is fully flush on a flat surface, so it is half on the board trim on my gate and the other half extends out into the air. This allows bugs and weather to enter and rust the insides badly, which I discovered on the second unit I purchased. So, the front and back parts of the unit MUST be fully installed on a fully flat surface ... meaning if you have two planks of wood with a gap in between, you need to use some filler to fill any gap to avoid moisture, etc., from getting inside.
The main problem I see with the design of these is with how the batteries are secured ... so, if someone really bangs/jiggles a gate hard and the deadbolt housing area the deadbolt goes into has a little leeway room allowance making not a tight perfect fit, it can jiggle the gate back and forth a lot, whereby one or more battery will lose just enough proper contact, and sets off the beeping alarm ... or it will simply quit working until the jostled battery is re-secured. Having said that, I have three of these and they are really great.
Jan 10, 2011 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Lock beeps every 10minutes changed batteries still does it
check that the keypad is not defective. You can disconnect the batteries and then unplug the keypad. Now put the batteries in without the keypad connected. If the beeping stopped, your keypad may need replacing. http://www.weiserlock.com/en/SupportPortal/SuggestedFaqs.aspx?prod=FAQ+Categories_Keyless+Entry_Power+Bolt+1000
Dec 25, 2010 | Weiser Lock Powerbolt 1000 Lock
I have a kwiklock key pad. when i hit the lock button to leave house it wil not lock. it only locks dead bolt with the code. you can get into the house by just hitting the lock botton and it opens the...
The Weiser brand and Kwikset brand Powerbolt are identical (Black & Decker), so these instructions will work just fine for you:
Notice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Dec 20, 2010 | Kwikset 907 907-15 Satin Nickel Powerbolt...
We changed the batteries and the lock will not reset it will not lock or unlock just keeps bepping
Oct 04, 2010 | Weiser Lock Powerbolt 1000 Lock
I have installed the Kwikset set smartcode, while it operates correctly while the door is open, when I close it it will beep every 30 seconds, I measured the precut hole for the bolt and it is 11/16 th...
This link:
Sep 23, 2010 | Kwikset 907 907-15 Satin Nickel Powerbolt...
Powerbolt 1000 started beeping and quit functioning
  • Take out batteries and unplug powerstrip.
  • Let it sit for 1 minute, then put the batteries back in and wait another minute.
I contacted customer support... they tell me the FAQ information on their own website is incorrect. The opposite is true, therefore the following is correct:
  • If it does not beep, the powerboard needs to be replaced
  • If the unit continues to beep, the keypad needs to be replaced
Here in Canada, they will send you a new one within 3-5 days free of charge. Call customer support:
Canada: 800-501-9471
US: 800-677-LOCK
The woman was very friendly. Great customer support!
-=dån=-
Jun 14, 2009 | Weiser Lock Powerbolt 1000 Lock
Kwikset smart code touchpad electronic deadbolt
I have the same problem, electronic locking system went dead but still beeps, stuck using keys now...according to the kwikset website though it says "Warranties cover the original residential user of Kwikset Products against defects in material and workmanship as long as the original user occupies the residential premises upon which the product was originally installed." so hopefully they will fix the problem
Oct 12, 2008 | Deadbolt PFK Touchpad Electronic Lockset
Locks & Locksmithing Logo
190 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
