Question about Bush WS6671 28" TV
No picture on Bush WS6667 TV
I've been given a Bush WS6667 TV with no instruction manual. I've connected it to my Virgin Media cable box and can hear the sound for each channel perfectly. However, I can't seem to get a picture. I've tried tuning via the remote control menu, but to no avail, but I'm not convinced I'm doing it correctly. Any advice would be gratefully received.
  • Bush Master
  • 1,527 Answers
Hello make sure the scart lead is connected tight
Posted on Jan 20, 2009
My TV will not stop switching itself off
Hi, The first thing to do is troubleshoot your TV independent to any other service provider that has a box that probably connects to your TV via a HDMI cable or old version scart.
Simply turn off your TV and turn off the socket that the TV is plugged in for 20 mins. Also turn of any Virgin media boxes.
After 20 mins turn on the TV. Do not worry if you get a message saying no signal detected. Wait and see if the TV stays on with no messages such as auto-standby. If the TV remains on with no problems then turn on your Virgin Media Box. The box will need to initialise ( about 30 seconds ) and then the TV should recognise the HDMI signal and you will see the Virgin TV.
If your TV turns off at any point during this process you have a fault with the TV, If when you turn on the Virgin box and no signal is detected you have either a cable connection problem or a Virgin Box problem, so using your TV REMOTE turn your TV back to ARIEL input to receive the normal television broadcasts via your Ariel that give you the normal freeview television that all modern TV's can receive, if you can get the normal reception contact virgin support who will troubleshoot your problem.
Nov 07, 2017 | Internet Computers & Internet
The how to clear Configuration screen on Bush LTD TV, cannot get channels
Sounds like main system control memory IC fault. Contact any service technician to replace it.
Jul 14, 2016 | Bush Televison & Video
Connecting cisco 851 cable to virgin media superhub problems?
Did you follow instructions on the manual , re install the driver .
Dec 27, 2013 | Cisco Computers & Internet
I purchased yesterday a 42"
I came across this very same problem a year or so ago regarding a Plasma TV and connection via scart. It turned out to be a problem with the scart lead. Replacing the lead with an all pins connected type fixed the problem. It was caused by the TV not being given the +ve voltage on pin8 and the TV thought it was not a proper signal and shut down.
Hope that helps.
Feb 27, 2011 | Televison & Video
I have a JVC RM-C60 TV. I'm trying to tune it in to my Virgin Media HD box using a standard SCART lead but having no joy. It's completely failing to find the cable channel (or any other for that matter)....
Tuning of the TV not required when using scart lead, just select external input that the scartis connected to, ie AV1,AV2 (EXT1,EXT2) etc. The problem is possibly to do with the Virgin box, it may be set to HDMI out in which case it will not output anything via the scart lead, you would need to connect via an HDMI lead (small socket on the rear of the unit looks a little like a USB socket). Problem is if your TV is a CRT television its unlikely to have this socket. Your Virgin box can be reset to output via the scart but you would need to contact Virgin for this process.
Feb 17, 2011 | JVC Televison & Video
Tv connected via scart cables through dvd and virgin media box. Picture sometimes goes yellow the flickers then back to clear.Other times it can go red. Plays dvd's okay though. Is this a connection...
This will be a problem with either the Scart leads (9 times out of 10) or the virgin media box. Not a problem with the signal coming from Virgin Media. Try checking the scart leads are not loose, or looped through the wrong way.
Hope this helps
TV_Doctor
Jan 03, 2011 | Sharp LC-32P50E 32 in. LCD Television
I have a toshiba 19w330db tv and already have a virgin media box and toshiba SD220EB dvd player connected. I am trying to connect a nintendo wii using the AV cable provided and am using the audio L R...
Do I understant this correctly? You are using a composite video cable (A/V y,r,w) and connecting it with the component video input (and then telling the TV to use the YPbPr source). You need a component video cable (3 RCA plugs on each end - red, green and blue) and an audio cable (2 RCA plugs - red and white) for the Wii. It wasn't included with the Wii but it does have the component video ports. Otherwise you would need a SCART to composite connector to work with the input. Alternatively, you could get an HDMI cable and connect that between the Wii and the TV (depnding on the age of the Wii).
If I've read this correctly, you have the media box and dvd player sharing the SCART input (EXT1).
I hope this helps.
Dec 26, 2010 | Toshiba Televison & Video
Televison & Video Logo
340 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
