What is the problem on TNPA4221 Board? - Televison & Video
How to Add a Board on the MA5600?
You can add a board on Huawei MA5600 in the following two ways:
· Adding a board offline: Run the board add command to add a board to an vacant slot (in this case, the system generates the "Board Fault" alarm). Then, insert a board to the slot (in this case, if the type of the inserted board is the same as the type of the board added offline, the system generates the "Board Recovery" alarm; if the type of the inserted board is different from the type of the board added offline, the system generates the "Type Mismatch" alarm).
· Automatically discovering a board: Insert a board to an vacant slot (in this case, the system displays a message indicating that a board is automatically discovered, and the board is in the auto-find state). Then, run the board confirmcommand to confirm the board that is automatically discovered.
This way is also can be adopted by Huawei MA5616 equipment.
Apr 27, 2017 | The Computers & Internet
Is There Any Changes in the Board Software Version After a Service Board Is Replaced?
fter a service board is replaced, the control board checks and determines the software of the new service board.
1. If the IO board package file contains the new service board, the control board updates the software of the new service board to that of its own.
If the new service board supports the anti-downgrade function and the control board software is within the anti-downgrade version range, the new service board runs with its default software.
If the new service board supports the anti-downgrade function but the control board software is not within the anti-downgrade version range, the control board updates the software of the new service board as that of its own.
If the IO board package file does not contain the new service board, the software of the new service board is loaded to the IO board package file of the control board.
Huawei GPBD Board Thunder link com
Dec 09, 2016 | Televison & Video
What boards are applicable on OSN7500?
List of Cross-Connect Boards and System Control Boards T1PSXCSA,T2PSXCSA Super dual-plane cross-connect and synchronous timing board N4GSCC,N6GSCC System Control and Communication Board List of Packet Processing Boards N1PEX2 2-port 10 Gigabit Ethernet switching processing board N2PEX1 1x10GE Ethernet processing board N1PEG8 8-port Gigabit Ethernet switching processing board List of http://www.thunder-link.com/HUAWEI-OPTIX-OSN7500_p554.htmlPacket Interface Boards N1CQ1 4-port channelized STM-1 CES optical interface board N1PEFF8 8-port FE optical interface board N1PETF8 8xFE electrical interface board N1MD12 Multi-protocol 32xE1 interface board (120 ohms) N1MD75 Multi-protocol 32xE1 interface board (75 ohms) List of EoD Boards N1EDQ41
4-port 622/155 Mbit/s SDH optical interface Ethernet dual-mode multi-function processing board List of SDH boards N4SLD64> 2xSTM-64 optical
interface board N1SLD64 2xSTM-64 optical interface board N4SFD64 2xSTM-64 optical interface board with
the FEC function T2SL64, T2SL64A 1xSTM-64 optical interface board N1SF64, N1SF64A,
N4SF64 1xSTM-64 optical interface board
(with the forward error correction
(FEC) function) N1SL64 1xSTM-64 optical interface board N4SL64 1xSTM-64 optical interface board N4SLO16 8xSTM-16 optical interface board N1SLO16 8xSTM-16 optical interface board N4SLQ16 4xSTM-16 optical interface board N1SLQ16, N2SLQ16 4xSTM-16 optical interface board N3SL16, N3SL16A 1xSTM-16 optical interface board N1SL16, N1SL16A,
N2SL16, N2SL16A 1xSTM-16 optical interface board N1SF16 1xSTM-16 optical interface board
(with the outband FEC function) N1SF16E 1xSTM-16 optical interface board
(with the outband EFEC function) N3SLH41 16xSTM-4/STM-1 optical interface board N3SLQ41 4xSTM-4/STM-1 optical interface board N1SLQ4, N2SLQ4 4xSTM-4 optical interface board N1SLQ4A 4xSTM-4 optical interface board N1SLD4, N2SLD4,
N1SLD4A 2xSTM-4 optical interface board N1SL4, N2SL4,
N1SL4A 1xSTM-4 optical interface board N1SLH1 16xSTM-1 signal processing board N1SLT1 12xSTM-1 optical interface board N1EU08 8xSTM-1 electrical interface board N1OU08 8xSTM-1 optical/electrical
interface board (LC) N2OU08 8xSTM-1 optical interface board (SC) N2SLO1, N3SLO1 8xSTM-1 optical interface board N1SLQ1, N2SLQ1 4xSTM-1 optical interface board N1SLQ1A 4xSTM-1 optical interface board N1SEP1 2xSTM-1 line processing board when interfaces
are available on the front panel
8xSTM-1 line processing board when interfaces are
available on the corresponding interface board N1SL1, N2SL1,
N1SL1A 1xSTM-1 optical interface board List of PDH board N2SPQ4 4xE4/STM-1 electrical processing board N1MU04 4xE4/STM-1 electrical interface board N2PQ3 12xE3/T3 service processing board N1D34S 6xE3/T3 electrical switching interface board N1C34S 3xE3/T3 electrical switching interface board N1PD3, N2PD3 6xE3/T3 service processing board N1PL3, N2PL3 3xE3/T3 service processing board N1PL3A, N2PL3A 3xE3/T3 service processing board
(Interfaces are available on the front panel.) N1PQ1 63xE1 service processing board N2PQ1 63xE1 service processing board N1PQM 63xE1/T1 service processing board N1D12B 32xE1/T1 electrical switching interface board N1D12S 32xE1/T1 electrical switching
interface board (120 ohms) N1D75S 32xE1 electrical switching
interface board (75 ohms) N1PFL1 8xE1 optical processing board N1TSB8 8-port electrical switching interface board N1DX1 DDN service accessing and converging board N3DX1 DDN service accessing and converging board N1DXA DDN service converging and processing board N1DM12 DDN service interface board List of EoS boards N1EFT8 8xFE/16xFE transparent transmission board N2EFT8 8xFE/16xFE transparent transmission board N1EFT8A 8xFE transparent transmission board N2EFT8A 8xFE transparent transmission board N1EFS0A 16xFE switching and processing board N2EFS0, N4EFS0,
N5EFS0 8xFE switching and processing board N1EFS4, N2EFS4,
N3EFS4 4xFE switching and processing board N1EAS2 2x10GE Layer 2 switching and
processing board N3EAS2 2x10GE Layer 2 switching and
processing board N1EGSH 16xGE switching and processing board N1EMS4 4xGE and 16xFE switching and
processing board N1EMS2 2xGE and 16xFE switching and
processing board N1EGS4, N3EGS4 4xGE switching and processing board N1EGT2, N2EGT2 2xGE transparent transmission board N2EGS2, N3EGS2 2xGE switching and processing board N1EFF8 8x100M Ethernet optical interface board N1EFF8A 8x100M Ethernet optical interface board N1ETF8 8x100M Ethernet twisted-pair interface board N1ETF8A 8x100M Ethernet twisted-pair interface board N1ETS8 8x10/100M Ethernet twisted pair
interface switching board List of ATM boards N1ADL4, N1IDL4 1xSTM-4 ATM service processing board N1ADQ1, N1IDQ1 4xSTM-1 ATM service processing board List of RPR boards N2EGR2 2xGE ring processing board N2EMR0 12xFE and 1xGE ring processing board List of SAN/Video Boards N1VST4 4-port video service transparent
transmission board N1MST4 4-port multi-service transparent transmission board List of Auxiliary Boards T1EOW Orderwire processing board T1AUX System auxiliary interface board N1FANA Fan board (high power) Lost of WDM board TN11CMR2 2-channel optical add/drop multiplexing board N1CMD2 2-channel bidirectional optical multiplexer and demultiplexer board TN11CMR4 4-channel optical add/drop multiplexing board N1MR2C 2-channel optical add/drop multiplexing board TN11MR2 2-channel optical add/drop multiplexing board N1LWX Arbitrary bit rate wavelength conversion board TN11MR4 4-channel optical add/drop multiplexing board N1FIB Filter isolating board N1MR2A 2-channel optical add/drop multiplexing board List of Optical Amplifier Boards and Dispersion Compensation Board N1BPA One-channel power amplifier and one-channel pre-amplifier board N2BPA One-channel power amplifier and one-channel pre-amplifier board N1COA, 61COA,
62COA Case-shaped optical amplifier N1DCU Dispersion compensation board N2DCU Dispersion compensation board TN11OBU1 Optical booster amplifier board TN12OBU2 Optical booster amplifier board N1BA2 Two-channel power amplifier board N1RPC01 Forward Raman driving board (external) N1RPC02 Backward Raman driving board (external) List of power boards UPM Uninterruptible power module T1PIU Power interface board (supporting standard subracks) T1PIUB Power interface board (supporting type III subracks) Huawei osn 7500 MSTP transmission sytem Thunder link com
Aug 31, 2016 | Huawei Optix Osn 550-basic Software...
What is the difference between dispaly board and a bulletin board?
No difference. a bulletin board is a type of a display board. Display board is a generic name for all presentation boards.
Jan 24, 2013 | Office Equipment & Supplies
TNPA4221 - Television won't turn on, fuses and transistors good
If TV is completely dead you have either a bad power or a bad main board.
Talking form experience I'd go with the power board first.
The alternative is to make sure the power board outputs the normal standby power to the main board and see that the main is not responding to command. That would point to the main.
The fact that Q406 is not shorted does not mean it is good let alone that the power board is good; while the most common issue there it is definitely not the only one that can happen.
You can send in the board for inspection/repair if interested although you're probably better off just buying a replacement.
Oct 08, 2012 | Panasonic TH-42PX75U 42 in. Plasma...
Error code 11 flashes shown on the power LED
HI:
Sorry for your luck. If you just bought it I would definitely return it. Here are the codes for your set.
12G Models :
X24 / C2 / U2 / S2 / G20 / G25 / VT20 / VT25
Code:
BLINKS PROBLEM CHECK POINT
2 blinks 15v SOS D-Board / P-Board
3 blinks 3.3v SOS D-Board
4 blinks Power SOS P-Board
5 blinks 5v SOS D-Board
6 blinks Driver SOS 1 SC-Board / D-SC FPC
SC Energy Recovery Circuit
D-SC FPC DET
7 blinks Driver SOS 2 SU-Board / SD-Board
SU/SD Connector DET
SU/SD Scan and Logic IC
8 blinks Driver SOS 3 SS-Board / SS2-Board
SS FPC Detect
SS Energy Recovery Circuit
9 blinks Discharge Control SOS D-Board
10 blinks Sub 5V SOS / Sub 3.3v SOS A-Board / SC-Board / SS-Board / P-Board
Sub 9V SOS / Tuner Power SOS
MIHO 3.3 SOS / LED 8v SOS
11 blinks Fan SOS A-Board / Fan
12 blinks Sound SOS A-Board / Speaker
Good luck
Apr 20, 2011 | Televison & Video
Error code 11 flashes model TCP50VT25
12G Models :
Code:
D-SC FPC DET
SU/SD Connector DET
SS FPC Detect
Good luck
Apr 20, 2011 | Panasonic 50 in. Plasma TV
What is code F-24
E11 Fill time too long. Refer to test (1).
E13 Water leak in tub or air leak in air bell. Refer to test (2).
E21 Water not pumping out fast enough. Refer to test (3).
E23 Drain pump relay on control board failed, wire off pump or pump Replace console control board, wire or
defective. pump.
E24 Drain pump relay on control board failed. Replace console control board.
E31 Pressure sensor not communicating with control board. Refer to test (4).
E35 Pressure sensor indicates water overfill. Refer to test (5).
E36 Console control board problem. Replace console control board.
E38 Air chamber clogged or pressure sensor defective. Check air chamber, rpl press. sensor.
E41 Control board thinks the door switch is open. Refer to test (6).
E43 Console control board thinks the door locking device has failed. Refer to test (7).
E44 Console control board problem. Replace console control board.
E45 Console control board problem. Replace console control board.
E46 Console control board problem. Replace console control board.
E47 Console control board thinks the door PTC circuit is open in spin. Refer to test (7).
E48 Console control board thinks the door PTC circuit is closed. Refer to test (7).
E52 Bad signal from tacho generator. Refer to test (8).
E56 High motor current. Refer to test (9).
E57 High current on inverter. Refer to test (9).
E58 High current on motor phase. Refer to test (9).
E59 No tacho signal for 3 seconds. Refer to test (10).
E5A High temperature on heat sink caused by overloading. Test first-if bad-rpl speed control brd.
E5B High temperature on heat sink. Replace speed control board.
E5C High temperature on heat sink. Replace speed control board.
E5D Communication problem. Refer to test (11).
E5E Communication problem. Refer to test (11).
E5F Communication problem. Refer to test (11).
E66 Heating element relay failure. Refer to test (14).
E67 Input voltage on microprocessor incorrect. Refer to test (15).
E68 Current leakage to ground on heater or fuse opened. Refer to test (14 & 15).
E71 Wash NTC failure. Refer to test (15).
E74 Wash temperature does not increase. Wire off NTC - rpl water valve.
E75 Water temperature sensor circuit. Refer to test (12).
E82 Console control board problem. Replace console control board.
E83 Console control board problem. Replace console control board.
E91 Comunnication error between UI board and console control board. Refer to test (16).
E93 Console control board problem. Replace console control board.
E94 Console control board problem. Replace console control board.
E95 Communication error. Replace console control board.
E97 Console control board problem. Replace console control board.
E98 Console control board problem. Replace console control board.
EB1 Incoming power frequency out of limits. Refer to test (13).
EB2 Incoming line voltage above 130 VAC. Check voltage at outlet. If < 130VAC,
replace the console control board.
EB3 Incoming line voltage below 90 VAC. Check voltage at outlet. If > 90VAC,
EBE Console control board problem. Replace console control board.
EBF Console control board problem. Replace console control board.
EF1 Clogged drain pump. Unclog the drain pump.
EF2 Too much soap. Advise customer to reduce the amount
of soap they are using.
Apr 24, 2010 | Kenmore 43142 Front Load Washer
No picture and the led ligth is blinking panasonic veita 52
If you have the flashing red light of death you can use the chart below, and call Panasonic to have it replaced. At the bottom is the list terms.
BLINKS PROBLEM MALFUNCTIONING PART
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
Panel = Plasma Display Panel (Plasma Glass)
D Board = Format Converter / Plasma AL / Sub-Field Processor
DG Board = AC-DC Converter / Digital Signal Processor / Full HD
Microcumputer HDMI Interface / Peaks Lite 2
H Board = Speaker Out / Sound Processor
AV Terminal / AV Switch
P Board = Power Supply
PB Board = Fan Control
SC Board = Scan Drive
SD Board = Scan Out (Lower)
SS Board = Sustain Drive
SU Board = Scan Out (Upper)
Jun 11, 2009 | Panasonic (TH-50PZ700U) Television
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Electro Med Services...
