Question about Hotpoint Washing Machines
Hi , i have a aqualtis washing machine and have power going to the machine but no display or any lights anywhere ,has not worked since we had a power cut ,
Aqualtis
SOURCE: My washing machine wont work properly!!!!!
may i suggest that you check that the filter is not blocked, i had a very similar problem to this except my machine stopped washing and started making a beeping noise.hope this helps
Posted on Aug 03, 2008
gittos73
  • 244 Answers
SOURCE: Faulty washing machine
if its no heat there only 2 items it can be heater element or the thermostats u could test the element by replacing the plugged in wires with wires that hasve a plug on place the wires into right places turn the plug on and if the element works it will start to glow turn it off as soon as u see it glowing from the inside of the washer also u can check the thermostats by dropping them into hot water and u should hear them pop
Posted on Nov 19, 2008
SOURCE: My Hotpoint Aqualtis washing machine
My Aqualtis just stopped mid program with F-05 on the display. This is apparently a failure to drain properly. I was luckily able to hold the power button to cancel the current program drain the water out (very slowly) and empty the machine.
THIS IS HOW I RESOLVED MY PROBLEM.
Disconnect the machine from the mains. Turn off the water supply to the machine. Disconnect the cold water pipe from the machine at the top corner.(Watch out for some water) Remove the drain hose from where you have it going to.  Pull the machine out and lay it gently down on the left side panel (use a towel to protect the side and absorb any water). Then, from the now exposed underside there is a black rubber pipe connected to the pump (black) coming from the main drum. Use some pliers to pinch the steel spring that clamps the hose in place and remove. Then using your fingers (there is nothing sharp in there) see if you can find any blockage.
I REMOVED: A pound coin, a dairylea slice wrapper and a piece of kinder bueno packet.
Carefully replace the black hose making sure it is fully on. Replace the drain hose, reconnect the water pipe and turn the water back on. (check to see it's dry with no leaks). Plug it in, turn on and that for me was it. Job Done.
Posted on Feb 01, 2009
  • 15 Answers
SOURCE: Aqualtis washing machine door locked, need quick release?
yes there is a quick release
the door lock have 3 wires u should connect 2 of them together the first one and the third
but its dangerous if there is kids cause u will b able to open the door while its on
Posted on Jun 05, 2009
  • 89 Answers
SOURCE: error code 07 on my Aqualtis AQXXF
Might be a bit complex but this is your problem and solution
REMEMBER TURN THE POWER OFF
F07: Heater relay stuck or element open circuit
This fault is only signalled when pressure switch is in empty position.
Check the efficiency of edge connector J3 on module.
Check wiring to heater and continuity of element (25 ohms approximately).
Check the efficiency of pressure switch connections and correct operation of pressure switch,
and the pressure chamber is not blocked with sludge.
Remove edge connector J3 and check wiring and contacts at positions 2, 3 and 4 on J3.
If all above OK replace pressure switch, module or eeprom as required.
Posted on Jun 10, 2009
Aqualtis washing machine has error code F01 what does this mean?
F01 Electronic circuit board fault
Issue: Washing machine is not operating - some or all functions are not selectable.
Advice: We recommend you disconnect (unplug) the appliance from the mains supply for a minimum of 2 minutes. Reconnect supply and wait 30 seconds and try starting the machine again.
Jan 14, 2016 | Hotpoint Aqualtis AQXXL129PM Washer Front...
Hotpoint aqualtis aqgd169s no power wont turn on not even had an error code come up
If the machine is dead, I would check the cable from the main boad leading to the front display on the door. Often the cableharness breaks at the hinge. (one of cables). If that is not the case, eather the main board or display board is dead.
May 26, 2014 | Hotpoint Ariston AW125 Front Load Washer
Ariston aqualtis aqlf9d
PLEASE URGENT!! I have the same washing machine WMW-5812.ER when i press the power on it does not start up why? Please help children getting back to school this week....pleaseee....
Jan 04, 2014 | Washing Machines
I am looking for a manual for hotpoint aqualtis AQCF 852 BU. Can you help please?
I have the same dryer and went on the Internet and typed "Hotpoint Aqualtis" on Google. One of the alternatives is "Instruction Booklet" This when printed is the Manual for the dryer, in full.
Aug 25, 2011 | Hotpoint Dryers
My hotpoint aqualtis aqxxd 169pm displays a blockage, we have cleared filter and checked pump is working, yet it still displays same message, and now when the power is on the drum wont turn.
Did you check the filter the pepellor sometimes can get something stuck in it. In one case i came across there was a hair go-go stuck in the pepellor.And also check the pipes at the back the cold water mains pipe going to the washing machine and the discharge pipe are not twisted or kinked
Aug 06, 2011 | Washing Machines
Washing Machines Logo
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
