Question about Crime Guard DB-HODL-2 03-Up Doorlock Alarm Interface
1989, Honda Accord
Security System will not operate,door,trunk,will not operate with remote
  • blueextc3221
    blueextc3221 May 11, 2010
    Is the model # posted correct? That interface is for '03 and up vehicles.
Posted on Feb 20, 2009
Trunk&gas tank buttons in driver door would not let you pull up or push down.its stuck.what seems to be prob.on 2002 honda accord.
Can you open the trunk with the key? If so, look around the latch mechanism for a tiny lever. This lever can be pulled up or down and is meant to be an additional anti-theft device on many models. On one position it enables the remote lever to open the trunk and in the other position it disables the remote lever to open the trunk, forcing the person to use the key at the trunk to open it.
Dec 15, 2016 | 2002 Honda Accord
Why security system will not arm on 2001 honda accord?
The alarm probably thinks there is an open circuit like a door or a hood or a trunk. Check those switches by inspecting the wiring to each switch. Temporarily ground each switch wire and see if the alarm arms. Good luck.
Aug 02, 2014 | Vehicle Parts & Accessories
I disconnected the battery on my 2003 honda accord ex and after fixing the battery the alarm system doesn't work.
stock alarm or after market.?
check all fuses
if ok, read the operators guide on this .
or the FSM.
opr guide lost in glove box.?
The security system will not set if the hood, trunk, or any door is not
fully closed. If the system will not set, check the Door Monitor on the
instrument panel (see page 60), to see if the doors and trunk are fully
closed. Since it is not part of the monitor display, manually check the
we are not talking the immobilizer system option,.
odd, most really honda's, the horn sticks on. that year. 03
at battery swap or dead. and recharged.
there are 3 related systems.
IMMO (cant start engine) immoblizer
keyfob door mag locks.
and security (alarms)
the all work together,
do say what works and does not.?
Sep 17, 2013 | Honda Cars & Trucks
I have a honda Accord SE and my doors wont unlock from my remote and all but drivers side will open from inside the car (i had to crawl through the trunk) ive never had this happen to me, can you help
I will admit that this is not a solution to your problem but may help until you get it fixed. Many people sometimes forget that the ignition key can unlock the doors from the outside manually. Worth a try rather than crawling in through the trunk.
Feb 23, 2013 | 2006 Honda Accord
Where is the fuel pump for a 1989 honda accord located?
The fuel pump is mounted in the gas tank. If my memory serves me correctly, there should be an access panel under the rear seat bottom. If not accessable that way, you'll need to remove the gas tank.
Mar 09, 2010 | 1989 Honda Accord 4 Door
I have a 2004 Honda Accord EX. Key Fob works trunk but not doors
Key added or replaced. System malfunction.
Obtain all keys. A maximum of 3 keys can be programmed. Close all doors and boot/tailgate. Switch ignition ON. Repeat procedure below 3 times: Within 4 seconds: Press key lock or unlock button. Within 4 seconds: Switch ignition OFF. Within 4 seconds: Switch ignition ON. Within 4 seconds: Press key lock or unlock button. System should now lock or unlock vehicle. Within 4 seconds: Press key lock or unlock button. Within 10 seconds: Press lock or unlock button of first key. System should now lock or unlock vehicle. Press lock or unlock button of second key. System should now lock or unlock vehicle. Press lock or unlock button of third key. System should now lock or unlock vehicle. Switch ignition OFF. Remove key. Check operation of all programmed keys.
NOTE: If less than 3 keys are to be programmed, remove ignition key after programming last key.
Jan 25, 2010 | 2004 Honda Accord
Alb system for honda accord 1989. when i push on the break ,alb system is activated which is abnormal. i well be thanks for your resolve of my problem.
If one of the tyres is a different size to others or the sensor behind a wheel is damaged, the alb system may be making adjustments.
Aug 04, 2009 | 1989 Honda Accord 4 Door
08 accord windows and sun roof open slightly (2-3 inches) when pressing remote to unlock doors, and also when pressing trunk button on remote. Thanks, John
It is a setting preset in your security/keyfob system. It should be outlined in the owners manual on how to change the settings back to the default. If not, your Honda dealer should be able to do this at no charge if you are under 36 mi/36K miles.
Mar 30, 2009 | 2008 Honda Accord
2002 Accord keyless entry-opens trunk,locks doors,etc Wont unlock
just found out it is the left front door latch assembly that failed on my there is nothing wrong with the remote says $385.00..not happy but thats the answer i got
Mar 18, 2009 | 2002 Honda Accord
Intall Remote Keyless Entry System in an 02 Honda Accord
You got the Wrong Information! Go to Wal Mart and Purchase a "Bulldog Security Keyless Entry" System for your Car. It will cost you a Quarter of the Price and is Just asw Reliable as the Factory Unit! Got one on My Truck with Remote Start also and it works GREAT! Should cost about $50.00 Bucks or so.
Jan 22, 2009 | 2002 Honda Accord
Crime Guard DB-HODL-2  03-Up Doorlock Alarm Interface Logo
165 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
Level 1 Expert
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
