Question about Carrier Heating & Cooling
COMMON WIRE ON CARRIER MODEL FX4BNF030000AAA
FOR WIFI THERMOSTAT INSTALLATION .
2 Suggested Answers
SOURCE: Carrier Thermostat Model TSTATCCPB501 ER code
I gave up and called a local HVAC business. This thermostat is discontinued and a new one will be purchased and installed.
Posted on Dec 16, 2008
Wiring Honeywell 9580 to old furnace with no C wire
This is not going to be easy. Check the wiring in the wall to look for the third wire. If they did not run one, you have to run new wire to the furnace and thermostat. If they stapled that wire to the walls inside studs, then it is going to be even harder to run the new wire. Once you run that new wire then you have to locate the connection in the furnace that has the common (c) wire for the transformer. Check you tube to see if the have any how to video.
Oct 13, 2015 | Honeywell RTH8580WF WiFi Thermostat
Have a Carrier Electric Furnace & AC, Model #FA4CNF048 and need to know how to connect a Blue wire to power to supply C wire for new Honeywell Wi-Fi thermostat. Any Suggestions?
C is common for 24 volts from the a/c transformer secondary or low side. R and C are 24 volts and will power up loads of 24 volts such as thermostats requiring to be powered up,
C is usually grounded or connected to the metal of the a-c unit. Use any color available to connect the wi-fi thermostat C to the a-c C to deliver 24 volts to the thermostat.
Jul 06, 2015 | Carrier Heating & Cooling
Need wiring diagram for carrier 40yr042300 air handler in order to find common wire (c wire) for thermostat
You don't need the common for the thermostat unless you are installing a thermostat that doesn't take batteries and gets its power from the hot and needs the common to complete the circuit.
Mar 02, 2015 | Carrier Heating & Cooling
New Nest thermostat, Model 2.8 Software version 4.0.1 keeps getting a low battery and shuts off and shuts down the furnace. Please help.
Do you have a common wire? The nest thermostat needs the common 24V C wire installed to keep the battery charged fully. Nest should tell consumers of this problem, but they don't. Its required for any powered thermostat. Even the new fancy Honeywells with touch screens etc..
Gotta realize the battery cannot run the display and wifi plus all the sensors for very long.
Jan 23, 2014 | Nest Learning Thermostat 2nd generation
Carrier OEM to Honeywell Programmable Tstat - NEED HELP
you likely have a "two stage" system, but not a two stage heat pump. the first stage is probably the heat pump itself, and the second stage is the auxilliary resistance heat that suppliments the heat pump at lower temps. if i knew the terminals that are available on the new stat, i could advise you on the proper wiring.
Jan 27, 2013 | Carrier Heating & Cooling
Installed a new Filtrete thermostat on a new Carrier high-efficiency furnace. I followed instructions exactly. It doesn't work. What did I do wrong? Furnace was installed in December. Broom handle...
Hi smargyle,
Welcome to fixya!
I can provide you with diagrams for the old Carrier therm and for the new Filtrete therm. But, I would need to know what the model numbers are for each therm plus how many speeds AC you have.
Please reply back with that information and we will get your AC back in working order.
Thanks,
Handie Andie
Jul 22, 2011 | Heating & Cooling
Forgot the manual to wire carrier fan coil - took care of the thermostat -but need to wire fan coil
Carrier wires are as follow Red black green whiteyellow. R common Black ground Y cool O or orange Reverse valve G fan W heat. The white on the Air handler depending on your electric backup heat has two wires together connected to white. Orange connects to orange on the condenser. Unless you have terminal board the everything is marked. Ruty
Jun 06, 2009 | Carrier Heating & Cooling
Replace thermostat
Typical color codes in Florida are;
white to W1 for heat
yellow to Y for compressor
red to R-RC-RH for power in
brown to W2 and or emergency /auxillary heat
green to G or Fan
orange to reversing valve(o/b)
blue to common.
You can open the control panel on the unit to verify these colors and components.
Feb 21, 2009 | Carrier Heating & Cooling
I have an older Carrier Heat Pump which I am trying to update the thermostat control with a Hunter model 44550. The problem is that the wiring to the current thermostat is as follows, G= green wire, R=...
JUMPER STAYS BETWEEN RC AND RH SO YOU HAVE INCOMING POWER FOR BOTH COOLING AND HEATING. THE WHITE WIRE YOU SAID C IS COMMON AND SHOULD BE USED IF POSSIBLE TO COMMON TERMINAL ON NEW STAT . IF THERE IS NO COMMON, THEN CAP IT BUT YOU'LL BE CHANGING BATTERIES EVERY FEW YEARS. I LIKE THE STATS WITH A COMMON POWERED OFF THE TRANSFORMER BUT YOURS MAY NOT HAVE A COMMON. THE GREY WIRE CONNECTED TO THE E TERMINAL IS FOR EMERGENCY HEAT. IT KILLS POWER TO THE HEAT PUMP, HEATS THE HOUSE ON IMMEDIATE CALL FOR HEAT WITH JUST THE INDOOR BLOWER AND THE INDOOR HEAT STRIPS. THIS PREVENTS ANY DAMAGE OR INCREASED DAMAGE TO THE COMPRESSOR IF YOU SUSPECT A PROBLEM.YOU SHOULD HAVE A TERMINAL ON THE NEW STAT THAT IS MARKED E OR PERHAPS X2 OR W3. THAT IS WHERE THE GEY WIRE GOES. IT IS POSSIBLE THE WIRE CONNECTED TO W DOES THE SAME THING AND YOU CAN GET BY WITHOUT THE GREY WIRE CONNECTED.ALSO SELECT SINGLE STAGE HEAT PUMP. SINGLE STAGE COOLING AND TWO STAGE HEAT . FIRST STAGE HEAT IS YOUR HEAT PUMP AND SECOND STAGE IS YOU STRIPS.
Oct 26, 2008 | Carrier Heating & Cooling
Carrier Infinity Control Thermostat SYSTXCCUID01-B
Your old stat is wired for a traditional thermostat and not a communication stat like the new infinity you have. There is a module plug on the furnace board that will need to be connected to the new thermostat for it to work. The wires that are wired now are from a terminal strip inside the furnace. Please contact your local Carrier dealer. They may be able to get that harness for you
Dec 06, 2007 | Heating & Cooling
Heating & Cooling Logo
24 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
