Question about Amana NAV2330AW Top Load Washer
How to open top of amana nav2330aww
Does it open like a Kenmore with just clips that you pry open?
3 Suggested Answers
SOURCE: How do you change the
you will need to unhook the belt from the transmission pulley and then take out the 3 screws running up from the bottom of the pump that runs into the motor support and drop off the pump ,,, the easies is to remove the 4 screws holding the motor support in place and set the motor and pump out to remove the pump and swap the belt
Move the washer out from the wall so you can remove the back. You may need another person to help move it because it is full of clothes and water. It would be easier to take the wet clothes out and put them in a pail or nearby laundry sink and then try to bail or pump the water out. It will be a messy operation, but easier in the long run.
Remove the back of the washer. Use screw drivers, nut drivers or hex head wrenches to remove the screws or fasteners on the back casing of the washer. Don't forget to unplug the washer from the electrical socket first. If it is a gas dryer, remove the hose from the gas line and temporarily cap off the line at the wall. Be very careful with gas lines and be sure they are capped off securely.
Find the belt. Belts are usually easy to find. They look much like fan belts in cars or belts in vacuum cleaners. A damaged one will be easy to spot. It will be broken altogether or so loose from wear that it does not grab the pulley and turn the washer drum.
Loosen the bolt on the motor bracket. Use a crescent wrench for this job. In a pinch a pair of pliers may do. Move the motor to put slack in the belt. Even if the belt is broken, you will still need to move the motor to install the new belt.
Remove the old belt. Stretch a new one into place on the pulleys.
Put tension on the new belt by using a hammer handle or a short pry bar to push the motor into position while you tighten the bolt in the adjustable bracket. Leave about 1/2-inch of slack when you press it in the center. If it is too loose, it will slip on the pulleys. If it is too tight, it wears quickly and may start to smoke or burn.
While you are in there tighten the pulleys by checking and tightening set screws all around the pulley hub. You may forestall another problem in the future by taking care of pulleys now while it is convenient.
http://www.servicematters.com/maytag_library/docs/16022937.pdf
Above is your service and repair manual.
Posted on Jun 21, 2010
  • 6277 Answers
SOURCE: My Amana Super Capacity Plus
The first thing to do is to have the leak investigated by somebody there as we could only offer a list of guesses ;-0)
Once it is empty and carefully lifted onto its side, it should be possible to inspect the hoses and clips and hopefully identify the culprit. In some cases it might even be possible to affect at least a temporary fix whilst obtaining the necessary spare.
Sorry we could be only of limited help in this instance- it's very difficult diagnosing this sort of problem remotely ;-0(
Good luck,
John C
Posted on Apr 06, 2011
My Amana dryer is over 20 years old. I want to remove lint from inside the dryer (if necessary) by vacuuming. To do this, should I lift the top of the dryer. If so, how do you lift the top . There...
The top is held on by metal clips and must be pried up at the front to release the clips. Use a pry bar
or wooden shims/large screwdriver, and be careful, since a clumsy attempt will scratch the paint job on the appliance.
This is one of the standard things that any maintenance tech would do when cleaning out a
dryer - the other thing to do is to unscrew the screws to release the back cover, and vacuum out
the back too.
May 13, 2011 | Amana Dryers
My Amana Super Capacity Plus washer, model NAV2330AWW is leaking. Any ideas about the problem and/or cost to fix?
Good luck,
John C
Apr 06, 2011 | Amana ALW480DA Top Load Washer
How do I open the front bottom of my Kenmore 90 Series dryer to vacuum out under the dryer drum?
Disconnect power then look for the clips that hold the bottom panel secured. The clips are located on the top or at the sides of the bottom panel depending on the model of your dryer. Once located, pry the lower access panel off with a flat-head screwdriver or any similar prying tool at the location of the clips as shown.
Clips at the Top of the Bottom Panel
Clips at the Sides of the Bottom Panel
Sep 24, 2010 | Dryers
How do I open the top of my Kenmore Series 600 gas dryer?
Most dryer tops are held down with spring clips ... there may be a screw or two in some depending upon where the filter is lcoated.
To pop it open, insert a pri in the crack between the top and the sides ... be careful of the finish. Pry on the side that will not show if you chip the paint.
Thanks for your interst in FixYa.com
Please vote
thanks
Dec 20, 2009 | Kitchen Ranges
NAV2330AWW top loading washing machine will not agitate or spin. what to do?
Check the belt, it is most likely loose or broken.You can access it by removing the lower front panel.
Nov 07, 2009 | Amana ALW480DA Top Load Washer
Very noisy and leaking
Water pump may be leaking. Check idle pulley and big counterweight spring that stedies the drum. Go to www.appliancepartspros.com for a diagram. Have model number ready.
Jun 23, 2009 | Amana NAV2330AW Top Load Washer
I have a electric Kenmore Dryer, the Tumbler is off the tracks, but I can not seem to open the housing. No screws, just (2) plastic clips between the Top and Base Housing. How to open?
two screws at the bottom of the front panel, the lid will lift off when you pry the front up with a large screw driver screws or clips on the inside
Jun 18, 2009 | Kenmore 63942 Dryer
I need to open the top of my kenmore washer...
Hi!
To remove the top use a pry tool or a putty knife and insert it straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. And under them would be the screws, open them.
Under the console you will find the lid switch connector. Unplug the switch from the connector. See the following on how to do this---
Now you can acces the lid clips.
Please ask for further clarifications.
Please rate this solution.
Thanks
Rylee
Feb 14, 2009 | Kenmore 24902 Top Load Washer
Opening the front of Kenmore 62622 electric dryer
Remove the lint filter on top. remove the two screws. Use a butter knife or thin screw driver to pry up the front near the corners. Push in the clips when you pry. prop the top up and remove the wires to the door switch. If the front has 2 pieces open the bottom panel from the top and loosen but don't remove the two screws . From the top inside remove the two screws and lift the front off. If the front is one piece there will be clips holding the bottom just lift up.
Jun 22, 2008 | Kenmore 62622 Electric Dryer
Amana NAV2330AW Top Load Washer Logo
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
