Question about Whirlpool Washing Machines
I got a Whirlpool 6 th sense wf 810 wasing machine. The machine works fine, but when it drains the water the water pump works fine and when there is no more water to pump the pump make a noise. I alre
Water pump works the way it should but when there is no more water to pump it make a screaming noise.
Krazytech
  • 725 Answers
SOURCE: I have a whirlpool front load washing machine model WFW8300SW00
Hay Crab.
what I have found is that the washer thinks it is not pumping out .. if your drain pump is clearly removing the all the water in a good time... then the problem is your pressure switch...it is telling the computer that it still has water in the machine...
replace the pressure switch and it will solve your f21 error.
It is a round unit on the right hand side on top...with a tube and wires going to it...let me know if it helps
Posted on Apr 05, 2008
SOURCE: error code F-05 water not leaving washing machine
F05 flashes due to electric oven control failure. The solution is to replace the electronic oven control (also called EOC or clock).
Posted on Dec 12, 2008
  • 5 Answers
SOURCE: Whirlpool Front Loader machine will not drain
On our LHW0050PQ the "Done" light stays on solid-- it does not blink, so on yours it may be indicating a malfunction, either in the electronic control or a problem with the pump. As VersaStyle suggested, you can check the connection to the pump, check for power to that connection and also look for evidence the impeller might have a pin or something stuck in it. If it used to work and it made a lot of noise before failing, I would suspect an object lodged in the impeller or a seized bearing.
(I find that when I use non-HE detergent, the pump gets really noisy, making sounds like the bearing is going out. I have a solution for that, but your situation sounds like a complete failure somewhere.)
Posted on Mar 05, 2009
SOURCE: lg 801 3f washing machine. 15 seconds after selecting any cycle a
I had the same problem. Redistributing the clothes inside the machine seems to do the trick. Even though the clothes seemed evenly distributed and I had far less than maximum capacity in the machine- it seemed to think that something was out of sync- simply moving the clothes around did the trick!
Posted on Oct 05, 2009
  • 10865 Answers
SOURCE: Need to buy drain pump for LG washer WM1812CW but
Hello. you can order the LG parts from any home depot.
Posted on Mar 08, 2010
I have whirlpool aquasteam 6th sense fromtliad washer 9760. It wont drain the water
Probably you have a clogged water pump clean it if not clogged then you have to know how to check if you have voltage to it, do so if you have 120 volts then it's your water pump http://www.appliancepartspros.com/whirlpool-washer-drain-pump-280187-ap3953640.html
Apr 29, 2016 | Whirlpool Washing Machines
PE error on WF 1330TP turbo drum machine
The PE error or fault code indicates that the machine is overfilling with water. This washer is equipped with a water level pressure switch. As the machine fills, the pressure increases on the switch, at the set pressure, the switch cuts power to the water inlet valve and the water stops flowing into the washer. If the pressure switch fails to sense properly, or the water inlet valve fails to shut off the unit can overfill. This situation can also be caused if the machine does not drain properly. First, check to see if water ever enters the machine when it is turned off. If so, replace the water inlet valve. Next, check the drain line to be sure it's not clogged or kinked. Next, check to see if the drain pump is working properly and removing the water from the previous cycle. If all of those check out, you may need to replace the pressure switch.
Aug 14, 2014 | LG Washing Machines
Wsher gt water in bottom wont drain or wasing saying sensing
Hi Kimberly, I am happy to assist you. Often when a unit does not drain properly, it is because it cannot dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Aug 06, 2013 | Frigidaire Washing Machines
The spin/drain cycle are leaving the clothes wet after wasing almost all the time.
Hi kerry_coorner,
Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Wasing machine fills with water during washing and wont pump out filling the drum...
1. Empty the drum via the filter / trap at the front (there is sometimes a drain pipe near the filter - otherwise be prepared to use lots of towels to soak up the water).
2. Check / clean the filter.
3. Ensure that the drainage pipe is not blocked.
4. Check that the pipe from the pump to the waste water pipe is not kinked / blocked.
5. Check that the pipe from the drum to the pump is not blocked.
6. Does the pump sound like it's trying to work? If not, it could be that the pump is dead. Pumps can often become blocked with fluff / slime from the machine.
Jan 13, 2011 | Bosch Washing Machines
Wf-t7030tp - Pump does not work!
possibly a problem with the fill switch
Aug 22, 2009 | LG Washing Machines
Whirlpool washer; spin cycle not draining
It sounds like your water pump is broken. there is a motor inside that pumps the water out when the machine computer changes to spin cycle
Aug 06, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
Hay Crab.
Apr 05, 2008 | Washing Machines
Washing Machines Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
