Question about Siemens HANDSET GIGASET C59H BLACK 1Line Cordless Phone
Siemens gigaset c59h batteries wont charge
The batteries wont charge up despite being constantly on the charging base. I've had the twin phones for about 18 months. The second phone can only be used for a few minutes at a time.
  • 518 Answers
SOURCE: Phones will not register
Try this:
Pick a handheld, press Menu - H/set settings - Reg Handset - Select Base 1, enter 0000 as password. Now on the bottom of the base station press and hold the Register button in for about 10 seconds or until the h/set beeps.
Geno
Posted on Jan 23, 2008
  • 518 Answers
SOURCE: siemens gigaset 4215
Then the base is bad. I have 1 base like that also... nothing can be done other than send it out to be rebuilt.
Sorry,
Geno
Posted on Mar 22, 2008
SOURCE: Problem Siemens Gigaset 4000 and 4200
when someone trys to call the phone says please dial the desired number
Posted on Jul 26, 2008
  • 9 Answers
SOURCE: Gigaset 8825 cordless phone pin reset
The default PIN for base and handsets is 0000 - if it has not been changed
  • Press Menu on Handset
  • Scroll to Mobile Settings - press ok
  • Scroll to Local Settings - press ok
  • Scroll to Chang Pin - press ok
  • Enter Current handset PIN - press ok
  • Enter New PIN - press ok
  • Display will show Confirm - Reenter PIN - press ok
Posted on Dec 26, 2008
  • 3230 Answers
SOURCE: need a manual for siemens gigaset as185 or as185
Well you can please follow the below link to get your manul -
http://gigaset.com/medias/sys_master/A31008-M2026-L101-1-7643_en_GBR.pdf
Good Luck!!
Posted on Apr 02, 2010
Batteries don't hold charge
you will need a new battery, however, check your options, it is probably cheaper to purchase a new phone than a new battery for your old phone
Jul 03, 2013 | Siemens GIGASET-A49H GIGASET-A49H
The phone wont pick up the base and the phones wont charge on the base - there is power to the base
Check that the connections are clean and the battery is good. Interstate Batteries carry lots of batteries and can make you one if they don't have what you need.
Sep 19, 2012 | Siemens Gigaset A140 Cordless Phone
Siemens Gigaset 4200 Cordless keep searching for base
The handset should be returned to the charging station, let it set for a few seconds. If this is a satellite phone, make sure the main phone "base unit" is connected to phone outlet and plugged in. After the phone has established its physical connection with the base again you can remove it and use it like normal.
May 18, 2012 | Siemens Gigaset 4200 Cordless Expansion...
My Siemens gigaset A 490 cordless phone is showing Register HS what i have to do pl advise
To register the Gigaset handset, you need to have the handset near the base. Press and hold the Register/Paging button on the base for 3+ seconds (it's hidden by the handset when on the base). A shorter press of the button will activate the Paging feature. Then within 60 seconds of pressing the Register button on the base, press Menu and select Settings. Press OK and go to Handset. Press OK and then select Register HS. Enter the base PIN (default is 0000) and then press OK. (Use the up/down arrows to navigate the menus.) You will see Registering flash on the display of the handset for approximately 1 minute while the registration is processed.
The manual for the Gigaset A490 is available here: http://gigaset.com/medias/sys_master/A31008-M2200-R301-2-3S19_en-fr-es_USA_CAN.pdf . If you need it in another language (or country), start here: http://gigaset.com/hq/en/product/GIGASETA490.html?tab=manuals .
I hope this helps.
May 26, 2011 | Siemens Gigaset A490 Twin Cordless Phone
My siemens gigaset AS 140 wont fully charge.maybe get 10 minuets talk time..
The battery in the phone needs to be replaced, because it is at the end of the charging cycle and the usage becomes less over time.
Feb 07, 2011 | Siemens Lands Phones
Gigaset showing no base n hand set display, how do we fix it?
Off hand I would say your battery is totally dead
May come back with an overnight charge
Jan 30, 2011 | Siemens Gigaset 4010 Cordless Phone
Base on the 2 phones both keep flashing base. tried to swap them over, turned on and off, but nothing
try replacing the batteries. Sometimes the flashing is just because it's not charging them.
I believe the Siemens uses standard rechargable AA batteries?
Jun 11, 2010 | Siemens Gigaset 4200 Cordless Expansion...
Siemens sl30 phone wont charge. Just blinks the last part of the battery. When I turn on the speakerphone to dial the phone dies and shuts off. when regular dialing can hear crackling static
I have similar problem with my gigaset 4000 micro, i bought 600mah NiMh bettery and when I start charging it charges cca 3 min and displays that battery is full and it doesnt charge it any more. I can speak max 12 minutes and phone starts beeping that battery is empty. What should i do to make phone to charge this battery properly.
Aug 08, 2008 | Siemens Lands Phones
Siemens HANDSET GIGASET C59H BLACK 1Line Cordless Phone Logo
238 people viewed this question
Top Siemens Lands Phones Experts
Greg Cann
Greg Cann
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
