Question about Refrigerators
Gss25qgmd ww the flap on door dispenser not working. It won't stay closed what do I need to get to fix it.
    President:
  • Refrigerators Master
  • 1,922 Answers
You need a new door flap solenoid thats behind the dispenser display on the door
Posted on Jan 07, 2013
  • Gerald Brown
    Gerald Brown Sep 22, 2015
    how do i remove dispenser display?
3 Suggested Answers
  • 33 Answers
SOURCE: GE GSS25VGMA WW Ice/water dispenser
it sounds like you have a bad flapper solenoid
Posted on Jan 01, 2008
richroth
  • 9472 Answers
SOURCE: fixing in door ice dispenser
What is the model number of the unit?
Posted on Nov 24, 2012
Kenmore refrigerator model 106.57372700
This is usually not hard to fix. Either the tab that hold the dispenser actuator is broken or the ice guide may have come loose. Repairclinic.com has a nice video on how to fix this.
Jul 23, 2014 | Kenmore Refrigerators
Drawer door won't stay close
Hi Paul Lehto - I understand that the drawer will not close, however may you please provide me the model number so I can assist you better in pinpointing you the information.
Dec 19, 2012 | Frigidaire Gallery Series GLHS269ZDB 36"...
Fixing in door ice dispenser
Nov 23, 2012 | Kenmore Side by Side Refrigerator
Freezer door ice dispenser flap will not close completely. The cold air is leaking out of the freezer. What can I do to fix?
There are multiple parts to the dispenser for GE. You say that door isn't closing properly, which could mean that the solenoid isn't working properly, or that the door flap retainer itself is broken, I want to say that they make a complete kit for it but not for certain,
Jun 02, 2012 | GE Refrigerators
The ice dispenser door stays open. Selenoid works
This is due to a rusted solenoid plunger .You will need to remove the top freezer door hinge cover ( 1 screw ) , and disconnect the plug there . This will remove power to the dispensor . Using a screwdriver , insert it just behind the dispensor board , and twist , to pry the board off . Remove the 3 plugs there , and remove the board . Remove the 4 screws on the white cover , and slide the cover out and off . In the top right , in the dispensor area , you will see the solenoid and plunger . 3 screws hold the solenoid on . Lift the flap , and the plunger will lift off . Part number for solenoid and plunger is WR62X10055 . The closing spring is probably good , and if you are pushing the flap closed , you are moving the plunger itself , instead of it gliding inside the solenoid , to the closed position .
Nov 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE mod #gsh22kgmb ww. port thru which ice exits
Try cleaning the edges of the flap and the ice chute as well. Once you've done that, check to see if the pivot rod is fully engaged at end side, as having it out of position could be causing it to "hang up" and not fully close.
If the rod has been knocked out of position, reposition it with your hands then you can lightly lube each end at the pivot points, with a food grade silicon lubricating spray. Use ONLY a food grade lubricant so you don't end up getting nasty tasting ice cubes or contaminating the cubes as they pass thru the chute and flap.
If that doesn't resolve the problem, you'll need to remove the chute & flap assembly from the dispenser section of the door and check for the return spring engagement, as it may have become disconnected and as a result, isn't closing the flap fully, as it should.
To do this, you'll need to remove the trim bezel around the dispenser section with a plastic putty knive (to avoid scratching the trim). be very careful when prying the bezel, do it VERY carefully so as not to snap/break the trim piece. Once you have that removed, you can see and get at the retaining screw(s) that hold the chute & flap assembly on the door panel.
Check the line drawing attached for proper part placement of the spring (part #63) and for seeing how your particular dispenser is attached to the freezer door.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=GSH22KGMBWW&productCategoryId=0165000&brandId=0432&modelName=REFRIGERATOR-M-SERIES&diagramPageId=00004&componentDescription=FREEZER%20DOOR&documentId=G0311032&backToLink=Return%20to%20Sub%20Components%20list#partLst
Hope you find this Very Helpful and best regards!
Aug 27, 2009 | Refrigerators
Frosty Ice dispenser
you need the flap in the dispenser replaced ,,, you can get a door flap kit to fix it ,,, i know cause i still have one here from when i closed my shop ,,, if flap isnt closing tight the air goes in and it frost up the opening and dispenser / larry
Dec 08, 2008 | Frigidaire FRS3R5EMB Side by Side...
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Ice dispenser chute
most flaps have a solinard that opens and closes the flap,if you can replace or get in there to lube it you should me ok,let me know more-mike
Sep 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
95 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
