Question about LG WM-2277HW Front Load Washer
Washing machine door is hard to shut and now leaks at bottom.
Washing machine door is hard to shut and now and leaks at bottom of the door.does any one know how to take it apart or what mite be wrong.
  • ppp246h Jan 23, 2009
    There is a small leak from the lower side of the door. I have tried removing build up around the gasket and clearing the 3 small drain holes that are located in the rubber gasket. We still have a leak.
    Can anyone help?
I had this problem and was really stressing b/c I really did not want to call someone out to fix it. As it turns out, it ended up just being a seriously HUGE chunk of lint that had gotten lodged into the plastic piece that keeps the door closed. It took me about 10 minutes to get this thing out, but the leaking problem seems to be solved. I am SO happy that's all it was!!
So, check at the top of the rubber rim (I'm not a handy woman at all, so I don't know all the right terms). There should be a whiteish piece that hangs down to lock the washer door. Make sure there's nothing obstructing it/in the middle of it. (you may have to look from the side w/ a flashlight). Hope that helps!!
Posted on Jan 24, 2011
Why does machine smell of stale water
you most likely have hose leak some where on one or more lines coming into the washer, need to check both water lines from the wall and the machine itself. it mite be a little drip once in a while, but it is building up or storing the water in the drain pan.
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
IF YOU HAVE STACKABLE SYSTEM CHECK THE DRIP PAN UNDERNEATH THE WASHING MACHINE.
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
check the overflow line to inspect for cracking, or is the machine balanced while it spins.
the water in setting in the bottom of the washing machine, going to have to be taken apart and dried out,
Apr 14, 2015 | Washing Machines
Why is my frigidaire washing machine model # ltf2140fs2 door is hard to shut and the hinges are rusted
Good Afternoon Friend,
I understand that the door on your Frigidaire washer, model# LTF2140FS2, is hard to shut and the hinges are rusted. There could be a possibility that there is a leak that is rusting the hinges. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why the door won't shut and why the hinges are rusted. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Frigidaire Washing Machines
Lg intellowasher 7kg wd 8013c
the push to on switch may be not in operation pl.. check
Oct 01, 2017 | Washing Machines
Leaking under machine
If it's leaking you need a new door seal. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5520777
Taking it off is kind of hard. You have to take the top off, the door lock off, and the front off, and the screws out of the bottom on the drain filter. Make sure it's not leaking from the bottom by putting water in the tub. Check to see if the gasket is torn on the inside by removing the spring ring with a flat head. Find your way to get it back on after replacing this part. The rings are tricky.
Jan 19, 2012 | LG WM-2277HW Front Load Washer
Water is leaking during the wash cycle. Nothing shut in the door. Been happening with the fuller loads.
try wiping or cleaning off the bottom part of the door,i've seen pieces of hair on the door and water leaks down the pieces of hair through the door,if that's clean then check for a hole in the rubber boot seal,most likely there's a hole in it
Feb 21, 2011 | Kenmore HE2 Plus Front Load Washer
Water leaking bottom front door
Check out the front seal carefully for a replacement. Due to the flexibility of the seal, it is not to easy to spot a tear mark, Under pressure of an operation load, a small tear will allow water leaking through, so there is a leak. It is very common that a hard sharp object left inside clothing and during washing cycle, it makes its way to the seal and cause a damage. Hope this can help.
Jan 08, 2010 | LG WM2487H Front Load Washer
HE2 washer leaking water from bottom of door/seal during washing
Open the door so it is 90degrees from machine, see if it is upright. if not undo the door bolts slightly and re alighn door. Good luck and feel free to give feed back.
John
Sep 03, 2009 | Kenmore HE2 Plus Front Load Washer
Leaking from the bottom of maytag washing machine
a good possibility that the front door seal is leaking check for tears or any small holes if it is that it it is hard to do
Jun 07, 2009 | Maytag Neptune MAH6500A Front Load Washer
Leaking out of the bottom
The water drainage pipe is probably tampered. You need to replace it. Take apart the washing mashine and find the drainge pipe. If it is not tampered, some pipe is loose or broken in the washine mashine. If all this is too hard, call a repair man to fix it.
Apr 07, 2009 | Washing Machines
LG WM-2277HW Front Load Washer Logo
147 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
