Question about Watches
Esq e5470 the Seconds hand does not stop at 12 when reset after putting new battery.
SOURCE: Reset Stopwatch Hands on CL1111 ?
Try setting the crown to position 2 - i.e. the position normally used to adjust the date.  Then use the top and bottom stopwatch buttons to adjust the minute hand and 1/10th hand respectively.
Posted on Feb 22, 2008
SOURCE: Ta Heuer Professional stopwatch minute hand reser to 12 position
pull the crown on first click and push the upper button until it reaches to your desired position.
Posted on Mar 20, 2008
escapement
  • 2334 Answers
SOURCE: The second hand on my luminox 8150 does not reset to 12 o'clock
Pull out crown to the first click. Push and hold pushbutton at 2 o'clock till the seconds hand reaches desired position. Push the crown back. You may need to operate pushbutton at 4 o'clock instead of pushbuttton at 2. Try both.
Rate me, please.
Posted on Mar 23, 2009
SOURCE: reset timer after battery change in seiko sna285
If the stop watch hands are not in the "0" (12 o clock) Position, follow the prodedure below to set them to the 12 o Clock position
1, Pull the crown to secound position
2, Press Button "A" for 2 seconds.
3, Press Button "B" to Adjust the minute Hand to "0" Position
4, Press Button "A" for 2 secounds then press Button "B" to adjust secound hand to "0" Position
5, Press crown into normal position
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Posted on Aug 28, 2009
SOURCE: The chronograph hand of my TAG Formula1 starts at
If you pull out the crown to the first stop, then press the start/stop button that should move the second had on one second per press. The reset button moves one of the other dials. If you pull the crown out to the second stop, the start/stop moves the minute hand on, and the reset button moves the other small dial round.
Posted on Apr 23, 2010
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
Stop running
is it battery..this will need replacing, if its automatic you need to wear it for about 7hrs to put in a reserve power of about 40hrs or if its hand wound wind it buy turning crown about 20 times..need a little more imfo....or is crown out on side push it back in to case side..
Mar 25, 2010 | ESQ Swiss Muse 07101116 Watch
New battery install in my esq e-5290 watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all ESQ watch manuals. Rate me, please.
Mar 05, 2010 | Watches
Stopping after 12 or 24 hours
Read your manual carefully and you will notice that the big, tall seconds hand is part of chronograph function. So, by pushing upper button you are actually engaging chronograph. This puts more strain on movement gears and consumes more battery power. When your watch is in normal timekeeping mode, the small seconds hand is counting seconds, not the big one which should be steady pointed at 12. I would recommend to put a new battery in your watch, reset it and start using it as described in users manual. You can download users manual here: http://www.oakley.com/customer-care/support/watches
Rate me, plz.
Jan 10, 2010 | Oakley Detonator OAK0530 Wrist Watch
I have an ESQ Aerodyne and the time set by the
this watch needs to be taken in as this is not proper time telling. has the johnson rod been used yet. if not, do so. if so have it taken in and checked with a caver device.
Jan 01, 2010 | ESQ 07301132 Aerodyne watch
Reset timer after battery change in seiko sna285
Chicago, IL 60601
Ph: 312 641 7000
Aug 28, 2009 | Watches
My second hand on my esq bracer chronograph resets to a few seconds before zero...how do i fix it?
Mine did the same. I fixed it. Go here
http://www.esqbymovado.com/pdf/ESQ_Fusion_Instructions.pdf
Jun 06, 2009 | ESQ Swiss Bracer 07301091 Watch for Men
Rate me, please.
Mar 23, 2009 | Watches
Crane and Viceroy ladies RC watch
Hi, Klik and Crane & Viceroy are excellent and robust watches, but due to the radio control batteries need to be changed more often than ordinary watches. Instructions for resetting the time on a Klik or Crane & Viceroy watch. With the watch face upwards and the buttons on the right assume the buttons to be; top button - "A", middle button "B" For setting the watch to GMT all hands need to point to 12 oclock exactly. To achieve this press Button A until the hands start spinning. Stop the spinning when the time reaches a couple of minutes before 12 oclock by repressing A. Inch the time forward by repressing Button A until all hands are at 12 oclock.(EXACTLY). Press Button B within 10 seconds and the time will advance 1 hour and stop. The radio signal will be picked up automatically and time will set itself in a few minutes. Notes: If you have radio dead spots avoid these when resetting the watch and do it away from magnetic or large metal objects. i.e. trays etc. If you are refitting a new battery and have a battery that isn't quite dead, do the advancement of time with the old battery and fit the new one near to 12 oclock to get the best life out of the new battery. If for any reason you want the watch to be in radio mode but read a time other than GMT ( no adjustment is needed for BST ), then instead of stopping the watch at 12 oclock stop it at the time in relation to 12 oclock. i.e. if you wanted the watch to read 30 minutes fast then stop the watch at 12.30. if you want any other info my email is; Charles@adept.fsbusiness.co.uk
Jul 15, 2008 | Watches
Klik r c watch.
problem solved.
regards.
Matt.
Apr 17, 2008 | Watches
Watches Logo
69 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
