We have a RoadMaster Stepper that was making some squeaking noises. I removed the side covers and sprayed the joint areas with a dry-lube lithium. Squeak went away but I don't have any tension in the steps. I can changed the setting with no change in the effort. Any ideas?
SOURCE: stair climbers / steppers maintenance
" * Read all maintenance instructions thoroughly before beginning work. * In some cases, an assistant is required to perform the necessary tasks, use all precautions. * The safety level given by the design of this equipment can only be maintained when the equipment is regularly examined for damage and wear. * Inoperable components should be replaced immediately or the equipment should be put out of use until it is repaired."
