Question about Garmin nuvi 250W GPS Receiver
How do I know when my GPS is fully charged?
I'm using the computer to charge my new Garmin. How do I know when it's fully charged?
Thanks - Kathy
  • 44 Answers
SOURCE: Is m Garmin nuvi 200 GPS charging
Merritt, Your Garmin Nuvi does not have a charging indicator similar to say your Cell ph. Simply a battery charge indicator scale. Normal full charge time is approximately 3 to 4 hr. If you looking to ensure your unit is in fact charging Plug in & then remove the connection, Your unit will pop-up a screen to request if you wish to remain on battery power. I hope this helps you.
Posted on Jun 02, 2009
  • 35 Answers
SOURCE: how long does it take to charge a garmin 255W gps?
Are you charging through the computer or wall charge,I charge my Garmin 255w with a wall charger for about 3 hours and I have all the bars.There are different strengths of chargers but even so,overnight is excessive,try a different charger.
Posted on Aug 08, 2009
SOURCE: My Garmin Nuvi 710 GPS doesn't switch on
Connect your Nuvi to a PC using a USB and then hold the switch to the left for 15 seconds. It should then power up after a soft reset
Posted on Oct 10, 2009
odiebugs
  • 949 Answers
SOURCE: Garmin nuvi 1350 can't find signal
Fist you should travel around with it, and see if in a different area you get satellites.
It could be where you are at, so this does not mean that in another town or state it won't work.
If you try this and still have problems it could be the unit and you should contact the MFG and send it in for repair.
This is the contact support page I posted below if you need it, its a live link so if you click on it the page will open.
http://www.garmin.com/garmin/cms/cache/offonce/us/support/supportcontact;jsessionid=0D1782886E6A3CF9512F8AEE898B8248
Posted on Feb 12, 2010
  • 502 Answers
SOURCE: Garmin charger has red light on and wont charge
Try a different charger, if you encounter the same sympton, the problem could be caused by a broken DC-Jack on the GPS. If they don't give you a new one under warranty, are third party Garmin repair services that will fix it for cheap. Also, I found an DYI GPS repair guide,so you can do it yourself too, not that difficult.
Posted on Jul 12, 2010
I have a new Garmin NUVI 57 LM. I have it plugged into my computer to charge. How long should it take to get charged?
Charging via a PC is not the quickest way to charge a GPS because many USB ports can not supply enough current, so the battery will take longer to charge. Using an AC adapter is a better way. Leaving the unit to charge over night should be fine. The way to tell if the GPS is fully charged is to look at the battery icon on the main screen of the GPS. It consists of 4 bars. 4 bars = fully charged. 3 bars = 75%, 2 bars = 50% and 1 bar = 25%.
Nov 26, 2016 | Garmin nuvi 57 5" GPS
Hi I have garmin 2599 lmt-d. Can anybody tell me how to charge this unit? My computer is acer 5742. Thanks
Connect a usb cable at the back of the unit with the computer for hours till it is fully charged.
Mar 16, 2015 | Garmin GPS
How do i get my garmin to charge to a full charge
You can connect to your computer with a usb cable until it is fully charged. And remember to turn it off after use each time in car. And actually, if you use it in your car and is always connect with the 12V DC, it is really not a matter it is fully charge or not. It still functioning well.
Mar 02, 2015 | Garmin nuvi GPS
Brand new Garmin Nuvi 1490 T out of the box. How do I charge it? The only devices in box were a car charger (my commute is 5 minutes daily) and a USB connector? Should I just plug the USB into my computer?...
Garmin satnavs come with a charge out of the box.
In some cases your device may have lost a charge during shelf life. In this case you can charge these units in three ways:
  1. Place unit on computer with USB cable for approximately 8-12 hours
  2. Place unit on Garmin specified AC adaptor for approximately 4-6 hours
  3. Place unit on 12V vehicle adaptor for approximately 4-6 hours.
Some cars continue to supply power to the cigarette lighter socket when turned off and others don't. If yours doesn't you can charge it from your computer. There's no indicator to show that it's charging or when it's charged. However when you disconnect the satnav from the computer and turn it on there's a battery state indicator which shows if it's fully charged or not.
Aug 16, 2010 | Garmin nuvi 1490T GPS Receiver
How to charge garmin 765 on computer
Very simple: connect the cable that came with the GPS: USB end to computer, mini USB to the GPS. When the unit is charging, the battery icon will disappear.
Unfortunately, Garmin did not think you would want to know the percentage of charge completed (they confirmed it to me in email), so you have to guess that after 2-4 hours your GPS is fully charged.
Nov 29, 2009 | Garmin n?vi 765T Car GPS Receiver
My new nuvi 255w will not start displaying info
When using a usb from your computer it is only a trickle
charge to the garmin. Will take a day or two to fully charge. If you use a the cigarette lighter plug that came WITH the garmin, it will fully charge in 4 hours. Stick with garmin approved plugs and all will go smooth. I know, I made the same error.
May 15, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
Not knowing when my nuvi 250 is fully charged
if the greens bars on the upper right indicates fully charged
Nov 29, 2008 | Garmin nuvi 250 GPS Receiver
Battery charging
Cig-lighter offers 1A current. The battrey will be fully charged for 4 hours if the unit is not used.
Jun 15, 2008 | Garmin nuvi 200W GPS Receiver
Garmin c340 does not charge
I came here looking for solution and tried the "press eraser in bottom right corner and turn on" but didn't work for mine BUT if you look at the face plate (the part on the front that says "Garmin",) just under the word "Garmin" you see a small indent in the plastic, useing your finger nail, gently pull upwards and the face plate will come up. Also, be gentle while pulling the face plate being careful not to break it. ( I advise that you use your nail and not anythng that might scratch the plastic if you are intending on returning the unit, cause they may suggest that you tampered with it and that "voids the warrenty") Anyway, look at the USB plug (above the ON button on the side) and you see a tab, press it and the unit will reset.
Seems to me that with all the problems Garmin has had with their units freezing up that I should have found this solution on the garmin site! To think that there are people who will throw there unit away because of this problem OR who will pay 150.00 bucks to get it fixed through Garmin.
Jan 15, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot C330 GPS--Battery
The batteries on the units are not meant to be serviced by the unit. If you are not familiar with taking it apart, you may damage internal components in trying. If the unit needs service, it is best to return it to Garmin and let them take care of the repairs. As far as the battery not holding the charge, if you have not done so, charge the unit on the computer for a few hours. This sometimes helps.
Nov 26, 2007 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi 250W GPS Receiver Logo
709 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
