My Toshiba 48" tv is out of focus
I've tried everything and the big runs fairly clear, but any writing is fuzzy and is very hard to read. Ex. the info. of the satelite is pushed or the news writing. Can you help me solve this problem?
tlm931
  • 273 Answers
SOURCE: my toshiba big screen tv is shaky and blurry
most likley your problems are on the hyper board in the set
it will sorta dance at the top and be shaking back and forth at a fast rate
it would require the hyper board being repaired or exchanged
you would most likley wont to locate a professional in your area to assist with this repair
average repair is 280 to 320 in my area
Posted on Jan 20, 2009
  • 2920 Answers
SOURCE: how to fix fuzzy pic & red,blue,green lines on your screen?
i would call a repairman and have him come out and fix it.if you like the tv then its worth fixing if you dont then dont invest any money in it. but if it were me id have a repaiman come and fix it
Posted on Jan 26, 2009
racer7x
  • 42 Answers
SOURCE: images have red and green outlines on them picture somewhat fuzzy
your convergence ic's are Shorted
They have a kit for this tv it is available through local parts distributors
If you can't find it locally just Google HITACHI CONVERGENCE KIT
If you are not good with de-soldering and soldering do not attempt this repair. Remember to replace all the resistors in the kit
If you are not sure about doing this repair you should have your local tv guy do it for you
I
Posted on Feb 10, 2009
  • 1779 Answers
SOURCE: Toshiba problem!
Your Convergence IC's need replaced. I recommend calling a service company if you want to invest in the repair. Most shops charge anywhere between $250-350.
Posted on Jun 23, 2009
Ecollier2012
  • 3459 Answers
SOURCE: 53' sony projection tv colors off and print is out of focus
Sounds like a convergence problem. You can buy the IC chips over the internet or you can get a complete kit with instructions and support from www.TvRepairKits.com
Posted on Jul 31, 2009
Fuzzy focus
try reseting the camera to factory defaults, theres either a option for that in the menus or there should also be a reset hole somewhere.
Jul 31, 2008 | Casio Exilim EX-S600 Digital Camera
I'm getting a double image of everything on the screen in a hazy blue colour. I tried configuring the colour within the menu but the cross simply won't line up. touch focus seems to work with the...
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 11, 2011 | Toshiba 57H81 57" Rear Projection...
Toshiba TV Model 42H81 will not focus
Ur convergence it dead.Buy the kit and replace the ICS an the resister.Focus don't go that far.
Aug 11, 2009 | Toshiba 42H81 42" Rear Projection...
Jul 30, 2009 | Sony KP-53V75 53" Rear Projection...
How to fix fuzzy pic & red,blue,green lines on your screen?
Typically this is due to a convergence chip failure. This repair can be done pretty easy with the proper instruction. Have a look at this video to help determine if you truly have a convergence problem.
Jan 26, 2009 | Toshiba 57H82 57" Rear Projection...
My 55 inch Toshiba Projection TV is getting fuzzy.
try to adjust the focus from the back inside the tv it may be out of whack because of the focus
Nov 26, 2008 | Philips 55P8241 55" Rear Projection...
One channel fuzzy
Tis is an ongoing problem I seen increase alot over the past few months. From what I can gather, all the channels being broadcast over going from the analog to digital, there's no big suprise to anyone. However, the change from analog to digital is changing at a faster rate, so when you look at the TV some channels will be fine and others will have grey lines, fuzzy picture. The only solution-you need a TV with some kind of digital tuner. On the TV itself if the (TV has one) it will say "SD" or "ED" which stands for standard digital or enhanced digital.
Jan 25, 2008 | GE 27GT277 27" TV
Fuzzy pictures
Go back to film. Digital SUCKS.
Dec 21, 2007 | Casio Exilim EX-Z50 Digital Camera
Tv only has select channels
If you have a good cable signal connected to the TV and it receives channel 50 nice and clear but all lower channels have nothing but snow, then the tuner is defective and needs to be replaced. This is quite an easy thing to correct. Sometimes resoldering all connections inside the tuner will bring it back to life, but in either case the set should be serviced by a qualified tech.
Aug 23, 2007 | Toshiba 36AF43 36" TV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
