Question about Samsung Digimax L85 Digital Camera
Card error with Samsung Digimax L85
Turn on camera... Card Error!...>... Format Card!
If i choose to format it trys and eventually says Formatting Error and turns off, if I click No, camera turns off.
I have tried different SD cards, all the same. It's really annoying as havent been able to use for a year
  • herewer2006 Mar 16, 2009
    the problem is it wont read above 2gb sd cards.. i have formatted the card and it works as long as its 2gb and below but if any higher it wont read the card and says error... until there is a better solution use only 2gb and lower cards in this product..
Quack
  • 542 Answers
SOURCE: Samsung Digimax 201 and INFINEON 128mB SD Card
Had a similar problem running windows XP, it couldn't read my sandisk SD card on a usb sandisk imagemate reader/writer. The solution on Microsoft's site was worthless, having already applied all XP patches. Fortunately, I tried accessing the SD card under windows 2000 and it worked fine, so I formatted the SD card in windows 2000 and now it works fine in XP.
Posted on Sep 12, 2005
mark sox
  • 24 Answers
SOURCE: Samsung S630 Digital Camera, Card Error and Format Error
you have several options:
1. see in the specification details of your camera what memory card is compatible for camera. for S630 it is SDHC/MMC/SD card (Up to 4GB Guaranteed). see if you're using memory card within this capacity and type. If you're using a different memory card type and capacity, try to use memorycard that is compatible with your camera.
2. try to use memory card to other devcie like cameras, cellphones and other devices and if it still has error problem, your card may be the one defective. use other cards.
3. try to take pictures without using memory card. use only the internal memory of camera. if camera still display this error meassage, camera needs service.
hope these options solve one of your problems. c",)
Posted on Jan 11, 2008
  • 104 Answers
SOURCE: Card Error Message
the error message is because the 2gb sd card is not supported (is too big for the camera)
try 1gb sd card and it should be fine
Posted on Oct 04, 2008
  • 18 Answers
SOURCE: Format error
I don't believe the camera can handle a card of that size. I believe the camera only supports up to 512MB cards, anything above that is not guaranteed.
Samsung Specs
Posted on Mar 03, 2009
SOURCE: SD memory card will not format in a Samsung Digimax 301.
I own a samsungDigimax 301, 3.2 mpi camera. When I inserted an SD card in the slot, the screen read " card error". Could you guide me as to dealing with this problem so that I may use the camera to take pictures this weekend? Thanks. Mathew.
Posted on May 22, 2009
Samsung camera L50 card error
If this card has been used before in a previous camera, it would say card error, because it was formatted for the previous camera. However if you do not have any pictures on the card yet I would go to the camera settings menu and format the card. DO NOT format if you have pictures that you would like to keep on the card, because when you format, you stand a chance of erasing them. After formatting the card it cannot be used in any other camera until formatted again.
Apr 15, 2014 | Samsung Digimax L50 Digital Camera
Samsung digimax 4010 camera has error message.
tis logical that sumsung digimax 401 cannot procees a 2gb memory card, use 1 gb will format ok.
May 11, 2010 | Samsung Digimax 4010 Digital Camera
Is San Disk memory card compatible with Digimax 401 ? I inserted one and got the message card errior.
SD Memory Card is compatible with your Digimax 401 camera. You just need to format the card.
Formatting a memory card
** This is used for formatting the memory card. If you run [FORMAT] on the memory card, all
images, including the protected images, will be deleted. Be sure to download important
images to your PC before formatting the memory card.
** If the memory card is not inserted, the internal memory will be formatted.
** Be sure to format the memory card if you are using a newly purchased or non-initialized
memory card, if it contains data that the camera cannot recognize, or if it contains images
captured with a different camera.
Formatting a Memory Card
1. In any mode other than Voice Recording mode, press the MENU button.
2. Press the LEFT/ RIGHT button and select the [SETUP] menu tab.
3. Select the [FORMAT] menu by pressing the UP/ DOWN button and press the RIGHT button.
4. Select a desired sub menu by pressing the UP/ DOWN button and press the OK button.
- If [No] is selected : The memory card will not be formatted.
- If [Yes] is selected : A [PLEASE WAIT!] message appears and the memory card will be formatted. If you ran FORMAT in Play mode, a [NO IMAGE!] message will appear.
Apr 12, 2010 | Samsung Digimax 401 Digital Camera
Camera say i need to format it because of a card error
First, get a card reader and download your pics to a computer. Then, format the card in the camera.
Jan 29, 2010 | Samsung L200 Digital Camera
New memory card issue
To rule out a faulty card, format it in the PC using a card reader.
Aug 10, 2009 | Samsung Digimax 4010 Digital Camera
What happens if you choose the setup format on the
If you choose the format option in the camera's menu it will basically format your memory card or the internal memory if you don't have a card. Formatting will erase all your pictures, try not to choose this option until you have backed up all your pictures to a computer.
Regards
Jul 10, 2009 | Samsung Digimax S630 Digital Camera
Formatting Memory Card
did you format your card? try going into the set-up menu on your camera and you should find a format option - THIS WILL ERASE ANYTHING YOU MAY HAVE HAD ON THE CARD...so if you have anything on there use a memory card reader and transfer it to your computer before formatting. If the formatting doesn't fix the card error message you could try formatting it on your computer (if you have a pc, go to 'my computer' and under 'removable devices' you should see the memory card, right click and choose format - i don't know the process for macs, but i would guess do a ctrl+click on the memory card when it appears on the desktop). If that still doesn't work the card is probably corrupt and you may need a new one.
Feb 01, 2008 | Samsung Digimax 4010 Digital Camera
Card error samsung s730
I own a Samsung S730, i downloaded all the drivers on Vista Home, I tried formatting the SD Card but it says CARD LOCKED, and it isnt. Any solutions
Oct 25, 2007 | Samsung Digimax S730 Digital Camera
Memory card
is it for a camera or a phone because if it is for a camera you have to format the memory card by the camera itself you cannot format the data or etc on the computer
Sep 26, 2007 | Samsung Digimax S630 Digital Camera
Samsung Digimax L85 Digital Camera Logo
90 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
