Question about Salton Juicers
Looking for part of JM503CAN p/N 71232 basket
Looking for the stainless steel filter basket that goes with the Juiceman juicer. it is part number 71232. if anyone has one to sell let me know
  • 6 Answers
SOURCE: Juidelady jl500 juicer replacement parts
I also have a Juicelady, & need a part(s) HEre is a probable solution to your problem!
In the U.S.A. or Canada call 1-800-233-9054 to order the part. Or see if they have it in stock.They will ask for your address & phone number. Have your serial number ready-it should be on the bottom (or possibly the side) and you may need a magnifying glass to read it! It starts with the letters JL, and mine was JL500 (so look for that-but your may be a different model, I gave you mine so you have an idea of what to look for.)
Note: Anywhere else, or to check them out online:
The same warehouse is also at foxinternational.com if you'd rather see what they offer that way--but we got our call answered after waiting les than a minute. They even had the part we require but won't ship to Canada, so if your Canadian--call anyway, as it is a different part than we required,( the arms that brace the unit together.)
Hope this was helpful for you!
Posted on Oct 21, 2008
enov8
  • 53 Answers
SOURCE: STRIPPING DOWN THE JUICER FOR CLEANING
Yes.  There should be an orange handle-looking accessory with to small metal rods sticking out that is made to clik into the wire mesh screen and unlock it be twisting the screen mechanism slightly so you can unscrew it out.
See the enclose photos of the tool.
Hope this helps...
-enov8
Posted on Mar 07, 2009
SOURCE: HOW DO I GET MY JUICER APART TO CLEAN IT
I looked all over for the disassembly instructions for the JM300 to no avail...so I got a flathead screwdriver and decided I'd either get the darned blade out or break it for good. It took some prying but the blade popped out and it was the RIGHT way to handle it after all. Now everything is clean and ready to use again.
Posted on Sep 24, 2009
SOURCE: For an Oster Juicer Model 3165, how do I remove
Move from side to side and jiggle the whole assembly .. including the juice collector and juicing basket. With patience and even a break between attempts it will finally dislodge itself and lift up and off.
Just juiced carrots and a couple apples .. mmmm good ;-) best of luck
Posted on Mar 12, 2010
  • 3 Answers
SOURCE: I can't find how to release the stainless
twist the top to remove the strainer blade
Posted on May 30, 2010
We have a power juicer pro and cannot get it apart. cant find the manuel. looking for a part to get the basket out? is there a picture of the tool so we know what we are looking for?
;-) just use a dull butter knife or end of spoon to gently pry it up in a few positions as you go around. i've owned one for 5 years and do it all the time ;-)
Jan 07, 2011 | Jack Lalanne Power Juicer (Stainless...
Looking for a manual for juiceman 210
Here you go:
http://common.csnstores.com/common/marketing/jcm1003_user_manual.pdf
Jan 02, 2010 | Juicers
Do not know how to remove basket
(1) Remove the food plunger and top cover; (2) unscrew the 3 screws from the blade/cutter plate and lift it off its base; (3) Unscrew the plastic base COUNTERWISE and lift it off of the center spindle; (4) Now you can remove the basket and juice bowl for cleaning.
To reassemble, reverse the process.
Dec 29, 2009 | Salton JM411 Juiceman II Elite Juicer
For an Oster Juicer Model 3165, how do I remove the stainless steel basket? Thanks.
Aug 23, 2009 | Oster 3186 Citrus Juicer
Hope this helps...
-enov8
Mar 03, 2009 | Jack Lalanne Power Juicer (Stainless...
Unable to take juiceman apart to clean
Generally you will have good luck with this item - however after using it for a while here is the problem people are stating in other reviews. You cannot get the basket our for cleaning. Unfortunately there are no instructions or troubleshooting or anything on the manufacturer's website for fixing this..
Here's the problem...There are 3 little captured balls on the basket that engage into holes into the juicer to hold it into place when you load it. The problem is that over time - the balls get juice in them. Then you store the thing with the basket locked into the juicer. Then from sitting in your cupboard - the juice dries and the balls are stuck. When they get very sticky they do not float in their cavity they are stuck. Then after you juice the next time - you cannot get basket off. basket is stuck and you will destroy the juicer if you try to pry it out with excessive force.
If you have this problem and you are lucky enough to be reading this - I have figured out the fix on my own...
You need to fill up a large tupperware, rubbermaid, whatever - bowl about 3 inches deep with hot water. Then take the juicer with the clear cover off and flip it upside down and into the hot water. Make sure the water is covering the entire basket area, but not so deep it goes into the motor area. I let it soak for about 3 hours, but I don't think you will need to do it for that long. When I took it out of the water I was able to pry the basket out with very little force. This is when I discovered this flawed design with the balls.
I used it probably for a year or so about 40 or 50 times without this issue, but let it sit for about 4 months - which is why I believe it caused these balls with juice in them to get so frozen I couldn't remove it.
Good luck. It worked for me.. this should work for you!
Tom
Jan 25, 2009 | Salton JM411 Juiceman II Elite Juicer
Jack lalanne juicer, 8 yrs.old model?
I have a Jack LaLanne power juicer model number JLS-8 and lost instruction manual and don't remember how to remove filter basket to clean machine.
rhanson616@cox.net
Sep 08, 2008 | Juicers
Parts
i need a user guide for my jucier
Jun 29, 2008 | Jack Lalanne Power Juicer (Stainless...
How do u wash this?
if you have a jack lalanne it comes with an orange handle that fits into the sharp cutter and you twist it to tighten/loosen the blade. hope this helps
Dec 04, 2007 | Juicers
Juicers Logo
32 people viewed this question
Top Salton Juicers Experts
eyecam
Tom Chichester
David Payne
David Payne
Are you a Salton Juicer Expert? Answer questions, earn points and help others
