Question about HP Computers & Internet
Laptop won't start up
I removed the 256 memory that was installed as standard in the HP ze4400 pavilion laptop to see how I could increase it to make it faster.
But when I put it back in it wouldn't start up. Is there something I should or should not have done when reinstalling it.
I get the normal Windows screen at start up with the green squares moving across and then just a black blank screen.
  • Jason Edinger May 11, 2010
    Did you try reseating the ram?
    Genius:
  • HP Master
  • 1,102 Answers
Make sure thr memory is installed correctly and securely
can you get into safemode
Posted on Jan 20, 2009
Can i install windows 7 on my hp pavilion ze4400
you can try as long as it has not been lock out from installing another set of windows on it,and your hdd and your ram can take it.
Jun 04, 2014 | HP Pavilion ze4400 Notebook
Can I increase the ram in my think pad?
Hello
Memory Upgrade for IBM ThinkPad R32 2658-xxx Laptop, the IBM ThinkPad R32 2658-xxx Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 128 or 256 MB (removable) of Memory. You can upgrade your IBM ThinkPad R32 2658-xxx Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 128 or 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
good luck and do rate the solution if helps.
Dec 22, 2010 | IBM ThinkPad R32 2658 Notebook
Need a bios password for a hp pavilion ze4400
You will have to reset your BIOS password. To reset the BIOS read the information from this link
In case of your HP laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Dec 17, 2010 | HP Pavilion ze4400 Notebook
I want to increase the memory ram of my lap top: HP pavilion ze4910us What kind and how much memory can I install ?
You can upgrade, have a look at the specs;
Pavilion ze4910us Memory Specifications Standard Memory 512 MB (removable) Maximum Memory 1.0 GB Memory Expansion 2 sockets Memory Comments PC2100/2700 DDR SDRAM SODIMMs CPU Type 1.4GHz Intel Celeron M 330 Model Comments 400MHz FSB Memory Upgrade for HewlettPackard Pavilion ze4910us Laptop, the HewlettPackard Pavilion ze4910us Laptop takes the PC2100/2700 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your HewlettPackard Pavilion ze4910us Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for HewlettPackard Pavilion ze4910us Laptop.
Hope that helps.
Dec 15, 2010 | Computers & Internet
What is the max ram for toshiba laptop model #
Hi Fhiken!
That modell comes with 256mb rab and supports up to 512mb ram.
The ramtype on it is SDRAM
I hope the info helped you
Nic
Aug 20, 2009 | Toshiba Computers & Internet
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
I have an HP Pavilion Laptop computer Model ze4400 when you push the power on all the lights come on and drives and fan power up then it turns itself off then back on then off over and over with no...
This sounds like a processor or system board failure. Most likely it is the processor. If the unit is still under manufacturer warranty contact them for replacement.
Mar 26, 2009 | HP Pavilion ze4400 Notebook
I have a Satellite 2405-S221 and I was wondering if the max memory i can install is 512K, is there a way to update the bios, or ANYTHING to increase that amount to at least 1 gig??
Toshiba Satellite 2405-S221 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 256 MB (removable) of Memory. You can upgrade your Toshiba Satellite 2405-S221 Laptop to up to a maximum of 512 MB Memory, the system has 2 sockets to install Memory, already with 256 MB (removable) standard Memory installed.
In short.... yeah, 512k is the max.
Doesn't appear to a bios limitation. It is a hardware issue that is limiting the amount.
Jan 24, 2009 | Toshiba 2405-S221 Notebook
Adding Memory to HP Pavilion N5160
The motherboard will only recognize 256 module. If you go to crucial.com and run the memory test, it will tell you the maximum memory the motherboard will support. So buyin a higher memory stick is wasting your money since it will not support it.
Dec 06, 2008 | HP Pavilion N5415 Notebook
Hp Pavillion laptop freezes when I install secondary memory
You may not put all together the 256 and 512, the system encountered error when two memory are not equal size and not equal brand.
Either you select 2 units 256 memory or either 2 units 512. or use only 1 unit 512 memory so that no freezes will happen.
Jan 17, 2008 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
93 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
