Question about Motorola (MVME167038)
Sd: boot device not found mvme 166
My MVME 166 while booting from MC68040 prompt the error message :
EEPROM boot device ... sd(0,0,0)
sd : Device not found
  • ajeeshn Jan 23, 2009
    already tried. nothing works out. it would be helpful if anyone provides an idea about how to program the flash memory from boot bug.
  • Anonymous Jan 23, 2009
    boot bug is the debugger environment. you can reprogram the flash memory or download the object code using bootbug.
  • 741 Answers
Sounds like you got a bad chip or chip is missing. I'm sure you already know what EEProm is, but I won't take that for granted. The EEProm is a non-volatile memory chip used to store small amounts of data. It will not be discarded when the power is tured off. So EEProm is used hold BIOS information. Also a Flash Drive is also considered to be EEProm. But for your case make sure all of the chips are seated properly.
Don't forget to rate this solution before logging out.
Don
Posted on Jan 20, 2009
  • Randall  Trahan
    Randall Trahan Jan 23, 2009
    You'll have to enlighted me, what do you mean when you say "boot bug"...
My computer gives message "reboot and select proper boot device or insert boot media in selected boot device and press a key". I don't have a reboot disk.
That probably means the boot manager is missing or has an error. If the hdd is available in your bios, press F8 just before it would normally boot. There should be a menu that will allow you to repair windows.
Jul 24, 2014 | Computers & Internet
I dont kno the default 4ne code for my voda4ne 125 handset
hi
Carefully reading user manuals help in most of cases :)
Just use Read flash option. After reading complete, SagemEG will show you phone code. If not success, there is another option to get code - sent flash.bin to Support@SagDD.com.
Here is log of reset to default , read eeprom n read flash
COM3 [VCP0] selected
Device: ZTE-225
Checking data, wait...
Action: reset
Boot...
Press Power button now !
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
flash chip supported
Check free space Done
Check parameters...
Check parameters Done
backup critical area...
Reading [eeprom-sta]...
file saved: backup_eeprom-sta_20080118-132834.B1E.bin
loading data...
wrong database file: z225_eep65535.cfg
error: can't load database[11]
Reading [eeprom-sec]...
file saved: backup_eeprom-sec_20080118-132834.B1E.bin
Reading [eeprom-dyn]...
file saved: backup_eeprom-dyn_20080118-132836.B1E.bin
backup critical area Done
Check memory...
Check memory Done
Write...
error: set erase range
Write Failed
Finished, Remove/Install battery now !
Time used: 22 sec
Device: ZTE-225
Action: read eeprom
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20080118-133742.B1E.bin
loading data...
file saved: backup_eeprom-sec_20080118-133742.B1E.bin
file saved: backup_eeprom-dyn_20080118-133744.B1E.bin
Check memory...
Reading [eeprom-complete]...
file saved: backup_eeprom-complete_20080118-133750.B1E.bin
Completed
Time used: 21 sec
Device: ZTE-225
Action: read flash
Boot...
Checking...
boot answer: 01
Boot Done
Set Baud...
Set Baud Done
Connecting...
flash: 0001:22C4
Connecting Done
Check free space...
Check parameters...
file saved: backup_eeprom-sta_20080118-133815.B1E.bin
loading data...
file saved: backup_eeprom-sec_20080118-133816.B1E.bin
file saved: backup_eeprom-dyn_20080118-133818.B1E.bin
Check memory...
Reading [flash]...
file saved: backup_flash_20080118-134506.B1X.bin
Completed
Time used: 425 sec
I uploaded all files....
http://rapidshare.com/files/84702678/Vodafone_ztc-125_files.rar
Plz add this model in infinity software....Thx....for ratting
May 30, 2011 | Cell Phones
I have a Dell desktop running Windows Vista. I cannot boot up to Windows. I have a black screen with cursor error message saying: boot device available, ta 0 installed, ta 1 installed, ta 2 none, ta 3...
That message says that the hard disk was found but nothing on it can be used - Vista is completely corrupted. You will have to reinstall it using the recovery cd that came with it when you bought it.
Feb 02, 2011 | Dell Inspiron 531s Desktop Computer
Tell me aboout boot sequence in bios setup
The system BIOS is what starts the computer running when you turn it on. The following are the steps that a typical boot sequence involves. Of course this will vary by the manufacturer of your hardware, BIOS, etc., and especially by what peripherals you have in the PC. Here is what generally happens when you turn on your system power:
The internal power supply turns on and initializes. The power supply takes some time until it can generate reliable power for the rest of the computer, and having it turn on prematurely could potentially lead to damage. Therefore, the chipset will generate a reset signal to the processor (the same as if you held the reset button down for a while on your case) until it receives the Power Good signal from the power supply.
When the reset button is released, the processor will be ready to start executing. When the processor first starts up, it is suffering from amnesia; there is nothing at all in the memory to execute. Of course processor makers know this will happen, so they pre-program the processor to always look at the same place in the system BIOS ROM for the start of the BIOS boot program. This is normally location FFFF0h, right at the end of the system memory. They put it there so that the size of the ROM can be changed without creating compatibility problems. Since there are only 16 bytes left from there to the end of conventional memory, this location just contains a "jump" instruction telling the processor where to go to find the real BIOS startup program.
The BIOS performs the power-on self test (POST). If there are any fatal errors, the boot process stops. POST beep codes can be found in this area of the Troubleshooting Expert.
The BIOS looks for the video card. In particular, it looks for the video card's built in BIOS program and runs it. This BIOS is normally found at location C000h in memory. The system BIOS executes the video card BIOS, which initializes the video card. Most modern cards will display information on the screen about the video card. (This is why on a modern PC you usually see something on the screen about the video card before you see the messages from the system BIOS itself).
The BIOS then looks for other devices' ROMs to see if any of them have BIOSes. Normally, the IDE/ATA hard disk BIOS will be found at C8000h and executed. If any other device BIOSes are found, they are executed as well.
The BIOS displays its startup screen.
The BIOS does more tests on the system, including the memory count-up test which you see on the screen. The BIOS will generally display a text error message on the screen if it encounters an error at this point; these error messages and their explanations can be found in this part of the Troubleshooting Expert.
The BIOS performs a "system inventory" of sorts, doing more tests to determine what sort of hardware is in the system. Modern BIOSes have many automatic settings and will determine memory timing (for example) based on what kind of memory it finds. Many BIOSes can also dynamically set hard drive parameters and access modes, and will determine these at roughly this time. Some will display a message on the screen for each drive they detect and configure this way. The BIOS will also now search for and label logical devices (COM and LPT ports).
If the BIOS supports the Plug and Play standard, it will detect and configure Plug and Play devices at this time and display a message on the screen for each one it finds. See here for more details on how PnP detects devices and assigns resources.
The BIOS will display a summary screen about your system's configuration. Checking this page of data can be helpful in diagnosing setup problems, although it can be hard to see because sometimes it flashes on the screen very quickly before scrolling off the top.
The BIOS begins the search for a drive to boot from. Most modern BIOSes contain a setting that controls if the system should first try to boot from the floppy disk (A:) or first try the hard disk (C:). Some BIOSes will even let you boot from your CD-ROM drive or other devices, depending on the boot sequence BIOS setting.
Having identified its target boot drive, the BIOS looks for boot information to start the operating system boot process. If it is searching a hard disk, it looks for a master boot record at cylinder 0, head 0, sector 1 (the first sector on the disk); if it is searching a floppy disk, it looks at the same address on the floppy disk for a volume boot sector.
If it finds what it is looking for, the BIOS starts the process of booting the operating system, using the information in the boot sector. At this point, the code in the boot sector takes over from the BIOS. The DOS boot process is described in detail here. If the first device that the system tries (floppy, hard disk, etc.) is not found, the BIOS will then try the next device in the boot sequence, and continue until it finds a bootable device.
If no boot device at all can be found, the system will normally display an error message and then freeze up the system. What the error message is depends entirely on the BIOS, and can be anything from the rather clear "No boot device available" to the very cryptic "NO ROM BASIC - SYSTEM HALTED". This will also happen if you have a bootable hard disk partition but forget to set it active.
Dec 15, 2010 | HP Computers & Internet
What happens inside the PC between turning the power on and you see the desktop on the screen?
  1. The internal power supply turns on and initializes. The power supply takes some time until it can generate reliable power for the rest of the computer, and having it turn on prematurely could potentially lead to damage. Therefore, the chipset will generate a reset signal to the processor (the same as if you held the reset button down for a while on your case) until it receives the Power Good signal from the power supply.
  2. When the reset button is released, the processor will be ready to start executing. When the processor first starts up, it is suffering from amnesia; there is nothing at all in the memory to execute. Of course processor makers know this will happen, so they pre-program the processor to always look at the same place in the system BIOS ROM for the start of the BIOS boot program. This is normally location FFFF0h, right at the end of the system memory. They put it there so that the size of the ROM can be changed without creating compatibility problems. Since there are only 16 bytes left from there to the end of conventional memory, this location just contains a "jump" instruction telling the processor where to go to find the real BIOS startup program.
  3. The BIOS performs the power-on self test (POST). If there are any fatal errors, the boot process stops. POST beep codes can be found in this area of the Troubleshooting Expert.
  4. The BIOS looks for the video card. In particular, it looks for the video card's built in BIOS program and runs it. This BIOS is normally found at location C000h in memory. The system BIOS executes the video card BIOS, which initializes the video card. Most modern cards will display information on the screen about the video card. (This is why on a modern PC you usually see something on the screen about the video card before you see the messages from the system BIOS itself).
  5. The BIOS then looks for other devices' ROMs to see if any of them have BIOSes. Normally, the IDE/ATA hard disk BIOS will be found at C8000h and executed. If any other device BIOSes are found, they are executed as well.
  6. The BIOS displays its startup screen.
  7. The BIOS does more tests on the system, including the memory count-up test which you see on the screen. The BIOS will generally display a text error message on the screen if it encounters an error at this point; these error messages and their explanations can be found in this part of the Troubleshooting Expert.
  8. The BIOS performs a "system inventory" of sorts, doing more tests to determine what sort of hardware is in the system. Modern BIOSes have many automatic settings and will determine memory timing (for example) based on what kind of memory it finds. Many BIOSes can also dynamically set hard drive parameters and access modes, and will determine these at roughly this time. Some will display a message on the screen for each drive they detect and configure this way. The BIOS will also now search for and label logical devices (COM and LPT ports).
  9. If the BIOS supports the Plug and Play standard, it will detect and configure Plug and Play devices at this time and display a message on the screen for each one it finds. See here for more details on how PnP detects devices and assigns resources.
  10. The BIOS will display a summary screen about your system's configuration. Checking this page of data can be helpful in diagnosing setup problems, although it can be hard to see because sometimes it flashes on the screen very quickly before scrolling off the top.
  11. The BIOS begins the search for a drive to boot from. Most modern BIOSes contain a setting that controls if the system should first try to boot from the floppy disk (A:) or first try the hard disk (C:). Some BIOSes will even let you boot from your CD-ROM drive or other devices, depending on the boot sequence BIOS setting.
  12. Having identified its target boot drive, the BIOS looks for boot information to start the operating system boot process. If it is searching a hard disk, it looks for a master boot record at cylinder 0, head 0, sector 1 (the first sector on the disk); if it is searching a floppy disk, it looks at the same address on the floppy disk for a volume boot sector.
  13. If it finds what it is looking for, the BIOS starts the process of booting the operating system, using the information in the boot sector. At this point, the code in the boot sector takes over from the BIOS. The DOS boot process is described in detail here. If the first device that the system tries (floppy, hard disk, etc.) is not found, the BIOS will then try the next device in the boot sequence, and continue until it finds a bootable device.
  14. If no boot device at all can be found, the system will normally display an error message and then freeze up the system. What the error message is depends entirely on the BIOS, and can be anything from the rather clear "No boot device available" to the very cryptic "NO ROM BASIC - SYSTEM HALTED". This will also happen if you have a bootable hard disk partition but forget to set it active.
Nov 02, 2010 | Computers & Internet
The MSM 422 Access Point is not booting up, just restarting all the time. This is the error message: CPU: Motorola PowerPC 8241/8245 Version: 5.4 BSP version: 1.3 Bootcode version: 3.0.6 Creation...
I think you need to get the latest firmware and load it. You should be able to stop the bootup as soon as you power it on.
HP Support can be reached at 1-866-my-procurve. Their support group should be able to help out.
Sep 28, 2010 | HP ProCurve MSM422 WW (J9359A) Pre-802.11n...
How do i fix an unexpectedI/o error
Could be when windows uses transfer mode, you can change this mode
Steps To Change IDE Properties
Click the Start button
Right click My Computer
Select Manage from the resulting menu
In the Computer Management window, select Device Manager
In the right pane, click to expand IDE ATA/ATAPI controllers
Identify your CD/DVD drive in the expanded menu and right click the appropriate drive
Select Properties
In the Properties windows, click the Advanced Settings tab
In the Transfer Mode box that represents your CD/DVD drive (typically Device 1); open the dropdown menu and select PIO Only
Click ok and exit all windows
If this does not resolve your issue, then you will need to go back using the above procedure and change the Device 1 in step #9 back to "DMA if available". Then, change Device 0 to "PIO Only" in the Transfer Mode box.
For reference, the Device 0 is the Primary IDE Channel and the Device 1 is the secondary IDE Channel.
After you change your settings, make sure you restart your system so that the computer recognizes the changes you have made. After you reboot, check the settings to make sure they are in effect. If they are, your device should now work properly.
any further help let me know
Nov 05, 2009 | Dell Inspiron 1525 Laptop
I am using the dell system at XPS710 and i kept getting the bios error:
I tried to hit F1, then i get that message again. I hit F2, then it i didn't see the problem.
PLEASE HELP! 16x16_smiley-mad.gif No ignores!
Apr 27, 2008 | Dell Latitude C640 Notebook
JFS224 change drive order
You need to get into bios to change the boot order. You can usually get into bios by tapping F12, esc, or whatever depending on who wrote your bios. Once you get into bios, you should see something like change boot order somewhere. If you don't know where it is then just keep scanning each page and you will find it. It will be called something "boot order". Use the directions on screen to change it to whatever drive you desire and you should be good to go. If you can't do it then write back and let me know.
Feb 01, 2008 | Chaparral Technologies CHAPARRAL - JFS224
Computers & Internet Logo
167 people viewed this question
Top Motorola Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Motorola Computer and Internet Expert? Answer questions, earn points and help others
