Question about Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool
Troy-Bilt Trimmer TB425CS
I have several attachments (weed trimmer, hedge trimmer,cultivator, edger) and they are all behaving the same way (underpowered). As the engine is running and responding fine, and it isunreasonable to assume that all 4 attachments had a problem at once, wemust conclude the problem is in the unit itself. When I cut the powerto the engine (i.e. give up), I hear something metallic spinning forseveral seconds. This noise was not there before.
  • 49 Answers
Sound like the clutch is going out or already is bad. There should be a cone shape cover that attaches the engine to the handle. Usually with 4 screws. Take those screws out and seperate the housing. There is a small centrifugal clutch, which is probably bad.
Posted on Jan 30, 2009
Posted on Jun 01, 2009
Model TB425CS WHAT IS SPARK PLUG GAP
Al, .025" is the plug gap for your trimmer,page 20 in your manual. There may be a recall on your model to do with safety.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://lawnandgarden.manualsonline.com/manuals/mfg/troybilt/tb475ss.html
Troy Bilt Model TB425CS Parts
Troy Bilt String Trimmer Sold at Lowe Recalled for Laceration Hazard
May 15, 2016 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
I own a Troy-Bilt 425cs string trimmer with multiple add-on attachments. The unit works fine for string trimming, brush cutting, and cultivating. However, it will not properly power my edger attachment. ...
The power edger attatchment may have a slightly different coupling size on it than the other attatchments. Also, do a good inspection of the power head unit's coupling at the EZ LINK connector. Maybe the head unit connector is getting hot over time, due to a lack of lube, and expanding internally, causing slippage in the connection to the edger attatchment. Inspect all that you can.
Sep 11, 2011 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Only used my trimmer 5 times since I had, trimmed my hedges 2 times last year & twice this year. After done doing my hedges, I put on my weed trimmer when finished & holding my trimmer in idle it...
Some disassembly may be required to get to the starter/recoil unit to fix this. The unit has Torx head fasteners and some level of mechanical skill is involved. Check your warranty?
Aug 13, 2010 | Troy Bilt Tb20cs 2 Cycle 31cc Gas String...
Starts and then shut off Troy bilt edger
clean out carb and run gas cleaner throught the tank
Dec 27, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
My troy-bilt TB425CS gas string trimmer gas lines have gone away. In replacing those lines how far into the tank do they go?
far enough so that you can reach through filler cap and pull the line out to attatch fuel filter.
then you can pull it back in and let it rest on the bottom of the tank
Aug 14, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Troy Bilt 4 cycle weed eater - trimmer head doesn't spin
rotate attatchment head slightly while inserting driveshaft
Jul 30, 2009 | Garden
Troy Bilt 4CC Trimmer - starts fine but won't turn off - TB425CS
Try cleaning up the switch button with Electronics Spray - you can get it from Wal-Mart for $3.
Usually is a bad contact or could be a broken wire .
Apr 25, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Troy Bilt Tb425cs 26cc 4 - Cycle Curved - Shaft Gas Trimmer with Ez - Start and Speed Spool Logo
996 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Wade Mobley
Wade Mobley
Are you a Troy Garden Expert? Answer questions, earn points and help others
