Question about Simplicity Sewing Machines
How to thread a monster high kids sewing machine
5 Suggested Answers
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
  • 323 Answers
SOURCE: Threading my sewing machine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on Aug 27, 2008
Michaelle
  • 65 Answers
SOURCE: need help to thread our sewing machine.
you really must get a manual for this machine.
You can find manuals online for a small price.
At one time some sites had them for free, but I haven't been able to find many recently. sewusa.com has some older ones for free. but not many. you could try the kenmore site as well, if not I'd try to search on dogpile.com (sewing machine manuals)
Just so you know, your manual is the MOST important tool for any sewing machine, and its worth a couple of bucks to get it.
Posted on Jan 24, 2009
  • 139 Answers
SOURCE: How to thread the Singer Sewing Machine Ser NO 1507 ZHV 826606183
You can find Singer threading diagrams at http://www.singerco.com/resources/threading.html.
Posted on Apr 16, 2010
Manual for dial sew machine how to thread would be helpful to know how to set tension too
Search for:
Make Model threading
or
Make Model manual
Usually, the top tension factory setting is the midway point between high & low numbers. However, every machine differs and changes over time. But that is a good starting point.
Understanding Thread Tension Threads
Sewing Lesson 10 How to Fix Tension on Your Sewing Machine
Mar 17, 2017 | Sewing Machines
Why the thread cracked with when i sticked with the machine
Thread breakage could occur for several reasons.
First, try a brand new needle.
Second, use only good quality thread--NOT old thread or bargain bin varieties.
Third, when threading the upper thread, be sure to ALWAYS RAISE the presser foot throughout the threading process.
Verify that the thread path is correct (consult the owner's manual). Incorrect threading will usually break the thread.
Check that the upper thread tension is set at the midway point between the high & low numbers.
Why Does My Top Thread Keep Breaking Sewing Machine
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
NMSU Checklist of Common Machine Troubles
Why Does My Thread Keep Breaking While Sew
Aug 27, 2016 | Brother ES2000 Computerized Sewing Machine
When using the button hole attachment, my fabric is not moved forward by the lower plate and thread gets caught up under that bottom plate. How do I fix this
Perhaps you have the stitch length set too short (close together) so the thread under the fabric is building up into a knot and then hangs up in the space under the needle plate. Try lengthening the stitch length and do some tests until you get it where you want the buttonhole to look.
How to Make Buttonhole on Your Sewing Machine Sew4Home
How to sew buttonhole with an old machine
Sew Buttonhole without Buttonhole Foot by Create Kids Couture
Jan 30, 2016 | Sewing Machines
Stitch length singer
Run through the "10 minute tuneup" here: https://answers.yahoo.com/question/index?qid=20090925205957AAq0xc4 DO NOT MESS WITH THE BOBBIN TENSION. Top tension setting should be about 3-4. Stitch length probably in the neighborhood of 2.5 - 3.5 mm.
Little kids and sewing machines seem to have a natural attraction, which is why my mom taught me to sew on her machine when I was 5. Sometimes it's easier to teach the kid how to do it right than keep the kid from messing with the machine.
Jun 24, 2014 | Sewing Machines
Thread take up lever does not raise high enough to thread.
you don't thread it like we did the older machines... it has a slot... just come up the right side over and down the left side... it will slip into place.
Dec 14, 2012 | Brother CS6000i Computerized Sewing...
The thread from the spool breaks immediately. Does it need a particular kind?
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
upper tension may be to tight
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads or lint
Oct 12, 2012 | PfaFF Sewing Machines
How do you thread one of these monsters
First of all what kind of machine is it. where is your manual.If it's a overlock its not that hard.
Aug 06, 2009 | White Sewing 1300DE Sewing Machine
CG-590
Time for a semi-industrial or Singer has the Empress Jean Sewing Machine - have not read reviews yet about it OVER time durability.
The Reliable 2000 is a mini monster - but the price also becomes a monster - there are many high dollar machines that will handle denium....
Since I didn't have that type of money for many years I would "hand walk" the machine throgu as much as possible - and ALWAYS have a very sharp fresh needle on - when it just got to be too much for my machine - I would hand sew pulling through with pliers - pushing up with one of my son's welding projects from school. Several machines I ruined because I ended up BENDING the internal drive arm. :( Ooopppsss
Feb 17, 2008 | Sewing Machines
Sewing Machines Logo
219 people viewed this question
Top Simplicity Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Greg Cann
Greg Cann
Are you a Simplicity Sewing Machine Expert? Answer questions, earn points and help others
