Question about Dell Inspiron 5150 Notebook
Inspiron 5150 fan continously running
Fan is working ,going all the time ,but laptop still runs hot.
  • 85 Answers
Dell Inspiron 5150, has overheating problems. The position of the fan is a problem.Also,don't press of the left upper corner of the laptop.Here's an excerpt from a wikipedia article: "The overheating problems on the Inspiron 5150 model was due to the position of the fan and fan-vent and the way in which it vents air through the CPU's heatsink.[citation needed] The fan draws air from underneath the unit and vents it through the rear after passing over the heatsink. However, the unit also sucks up dust from underneath it. Over time a buildup of dust constricts the airflow through the unit, reducing cooling. The airflow is perceptibly diminished. A simple test is to place a hand near the fan vent; when the fan is running at high speed there should be a good flow of warm air. Heat will also build up along the top of the unit near the LCD display and left toward the optical drive. Users may notice this while typing. Performance may also suffer, with jittery game movement and slow Windows performance. Some systems may experience jerky reactions where the unit goes into an almost slow-motion phase for short periods of time. Continued operation in this condition may lead to overheating and could result in permanent damage to the CPU, GPU, motherboard and other internal components. To remedy this the unit must be disassembled, the dust removed, and fan operation checked. This problem not uncommonly results in a CPU temperature-increase of between 15-20°C over an normally functioning unit. Further temperature increases may damage the casing of the unit."From Wikipedia article"Dell Inspiron" under problems Hope it helps -CG
Posted on Jun 09, 2009
    Problem Solver:
  • 8 Answers
You need to speak to Dell Tech Support and get the FAN and HEATSINK ASSEMBLY replaced. This is the only resolution to this issue before it gets worst.
Please rate this comment if helpful
Posted on Jan 20, 2009
How can I tell if the fan is bad or if it it not being truned on? Dell Inspiron 1501
On a laptop this can be a slightly annoying thing. The fans are normally set to run only when needed so will not be working all the time. If your laptop is warm/hot then you should be able to feel some air movement from the exhaust vent. That will tell you if the fan is working. Use it for a while and then start checking around the sides for any warm air coming out. The fan itself might be quiet but you can feel the warm air.
You can also turn the cooling setting to max cooling through the power panel. That should force the fan to run all the time.
If the fan is running but you can't feel any airflow then the cooling system/vents may be plugged with dust or lint and need to be cleaned. Most computer shops will offer a flat fee to clean this. Usually the service depot will as well. If this is the case you really don;t want to run the laptop until you get it cleaned. Without the airflow the cpu will overheat. At best it runs slow and at worst it burns out.
Nov 09, 2010 | Dell Inspiron 1501 Notebook
I my laptop is getting very hot and the fan been getting very loud and running continously. What should I do beside cleaning the fan area and exhaust?
I think you should put some cooling fluid on the CPU and make sure the fan runs smoothly otherwise try to grease it or if its hopeless replace it with a new one , I know it is not that much but it is THAT important.
hope this helps.
May 09, 2010 | Acer Aspire 3680 Laptop
My Dell Inspirion 5150 will not turn on. The Battery, gleen light is on. When I press the power button the fan starts and the computer appears to try to start for 5 seconds and then dies. Any ideas?
The Inspirion 5150 is a wonderful computer. reseat the memory chips it should fix it. or else. you cna run the hardware test. to run the hardware test. turn off the computer and then press the Fn key on the keyboard hold it down and then turn on the computer. the computer will go into diagnostic boot where it will test all the components. and you cna release the fn key then. it will tell you which h/w part has gone bad. i think its a motherbaord, but you can try to reseat the memory may be it will fix it.
how to reseat the memory? click here to see how to reseat all the components in 5150. Good luck.
Aug 05, 2009 | Dell Inspiron 5150 Cooling Fan with...
Keeps shutting down 5150inspiron
thermal shutdown.... it's overheating and you need to make sure the fan is working and clean out the dust and dirt
Jan 19, 2009 | Dell Inspiron 5150 Notebook
The fan on my Dell Inspiron 4000 is always running.
a couple suggestions:
try starting in safe mode and see if it does it still. It could be that you have some background program like Windows update or that new Windows active search function, which spends copious amounts of processor time cataloging your entire computer. Some anti-virus programs will do the same and eat up processor time. I'd try shutting down as many of these background processes to see what (or what combination) is causing the problem.
If this doesn't work, you might have a bad connection with your heatsink, which would cause your computer to stay at or your fan might be going bad, causing it to get really loud.
I'm not going to go into the possibility of it being used on a lap or bed or carpet where the fan intake vent is getting blocked. I know you've eliminated this as a possibility. Right?
Oct 07, 2008 | Dell Inspiron 4000 Notebook
Mouse problem when running on ac power
Might be a driver glitch. Try uninstalling the drivers for the touch pad, some times refered to as synaptic pointing device, from the devic manager, then plug the power supply in and reboot. The machine will find the touch pad, and reinstall the drivers. Try this and let me know.
Aug 15, 2008 | Dell Inspiron 5150 Notebook
Laptop running hot - Fan cycling on and off every 10-20 seconds
My guess is that CPU fan, it there is one, is not working properly and your computer is heating up. Is it turning off, too, occasionally after a period of time? Suggest a new CPU fan.
Jun 14, 2008 | Dell Inspiron B130 Notebook
Fan not running
it depends on make of laptop. my toshiba's fan "NEVER" came on, yet it is going on 14 years old and works perfectly. I have another toshiba where the fan cycles on and off on its own. to be sure you are not overheating it, purchase one of those cooling trays (or prop it up on a hard surface for maximum exposure to ambient air) just for peace of mind.
Nov 08, 2007 | Dell Inspiron 2200 Notebook
Can't charge battery or run off AC
You may have a problem in the DC charge circuitry. These parts are located on the moatherboard directly and can't be bought separately and repaired. You must send your Dell to a specialised service to have it fixed by them. Sorry, I can't see no other way for this problem to be solved.
Jan 20, 2007 | Dell Inspiron 5150 Notebook
Dell Inspiron 5150 Notebook Logo
474 people viewed this question
Alun Cox
