Question about Electrolux Dryers
Repair manual for electrolux electric dryer model # feo84000fs1
Can't get the dryer to stop beeping and sometimes goes right to cool down instead of drying
aborcass
  • 2651 Answers
SOURCE: MAYTAG MODEL MDE9706AYW NEEDS REPAIR
sounds like your motor is overheating, replace motor
Posted on Mar 01, 2008
  • 36 Answers
SOURCE: Whirlpool Duet Dryer WED9600 Beeping during drying
Dear Customer
Please perform the following
please rate this,thank u
Posted on Dec 16, 2008
jumptrout51
  • 3361 Answers
SOURCE: Maytag Performa Electric Dryer Won't Start
Replace the thermal fuse and the high limit switch.
They come as a set.
Clean the auto dry sensor with rubbing alcohol.
Posted on Mar 10, 2009
localwonder
  • 6784 Answers
SOURCE: The dryer won't run. Dry, extra dry, and coold down process lights are lit.
Hi, the lights are signaling a control fault the is concerning the logic sector of the control board/timer. you will need to make sure that the wiring harness is connected to all points and it should be in good condition. if there are no apparent issue with the wiring harness, replace the control.
Posted on May 29, 2009
SOURCE: I have model 417 88042 700 Kenmore Electric Dryer.
The front electric panel is out. I have the same problem. The part costs around $161.00 and about $100 for labor to fix it. Sorry for the bad news.
Posted on Sep 17, 2010
Problem with LG electric dryer DLE2532W, approx 10yrs old.
When you turn it yourself is it real stiff and hard to turn? It should not be. You might need a wheel or maybe a glide. I have the manual
Nov 24, 2013 | LG DLE2532W Electric Dryer
Electrolux frididaire serial XD40615481 02/04 electric heater comes on then goes out after a few seconds, fan stays on and drum keeps turning.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 31, 2010 | Electrolux EIGD55H Dryer
Model # dbxr463eg1ww, dryer overheats and stops sometimes, only on reg heat, after cools off starts right back up. Sometimes it goes thru cycle and sometimes it stops again. Top of dryer gets very hot to...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 30, 2010 | GE Dryers
I have an Electrolux IQ Touch dryer. Just now it stopped working. When I hit the start button, it makes a buzzing sound and then goes on Pause. I called Electrolux and they had no idea what was...
Dryer Repair ? The dryer will not start
heatman101
Aug 25, 2010 | Electrolux Dryers
I have a Kenmore Elite digital dryer, manufactured in 2002, and it will run for awhile but then it stops and sets itself to a certain dry time/settings and wont do anything else. When I press stop, it just...
I have a newer model of what I believe is the same dryer. I'm not sure if the layout is the same on yours as it is on mine.
I had the same problem, first the problem stems from user error -- there's a reason they say to empty the lint trap after every use. I know I've been remiss in emptying it thus my beeping bonanza.
Second -- THE FIX -- in the lint trap area (this is described based on my 2007/08 model) there are screws that allow you to remove the lint trap censor cover, unscrew, you'll see it's connected to wiring, there are 2 electrical connections, these slide on and off, gently pull and each will slide off, clean the connectors. By disconnecting to clean, which is the basis of the problem, the electric function resets (as far as I know), the beeping stops and you're good to go! Good luck.
Aug 20, 2010 | Kenmore Dryers
Belt replacement instructions for Maytag Ensignia model MDE4658AYW electrical dryer
Try Googling " user manual for Maytag Ensignia MDE4658AYW ". You may have to go to the Maytag web site and ask for manual. Sometimes I've had to ask for repair manual instead of user manual. Good luck.
Jul 24, 2009 | Dryers
May 29, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Er20 comes up on my washer
Your on the right track .... To narrow it down all you have to do is disconect your waste pipe from under the sink or where ever it goes to and lower it ground level , if the water startss to flow out by means of gravity then you have no blockage and its the pump if water does not flow out then its a blockage....
Either to clear the blokage or change the pump turn the machine upside down as both are easily accessible from there hope this helps... any questions dont hesitate to ask...
Dec 22, 2007 | Electrolux EW1200i Front Load Washer /...
Dryers Logo
24 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
vince
JP Services
JP Services
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
