Question about Sanyo Microwave Ovens
Sanyo euro touch microwave oven has no power, no lights or anything. What could be the problem
MicrowaveSvc
  • 9098 Answers
SOURCE: Sanyo Microwave Oven EM_S1553
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If it's a bad magnetron and your unit is within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 23, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: light bulb replacement for sanyo ems3553 microwave oven
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
You'll need to remove the outer cover (wrapper) to get to the bulb.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
If you don't have your instructions, please reply back with your brand and model number.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
See these links before proceeding:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had locally in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Mar 06, 2009
SOURCE: REPLACING LIGHT BULB
i have a cookwork microwave the light stoped working
Posted on Apr 11, 2009
  • 236 Answers
SOURCE: plz help!! microwave oven not working!!!!
You need to check the door interlock switches. If the door is shut the light should be out unless the machine is runing.
Posted on Nov 12, 2009
rohntech
  • 422 Answers
SOURCE: I have a Sanyo EM-P673B
The microwave fuse is already blown, it need to be replace with the same rating. If you can replace it by yourself, if you can't call someone who has knowledge in servicing appliances.
It should be good and you can use it again if you follow my advice.
Thanks for asking.
Posted on Apr 04, 2011
Sanyo microwave oven touch pad controls faulty
The keypad control board is defective, cost of the part alone will be close to a new microwave oven.
Apr 06, 2012 | Sanyo Microwave Ovens
I have a Sanyo EM-P673B microwave oven and yesterday when I was making some popcorn it just shut off and no lights or anything work. I checked the outlet n it works and reset the house switches and still...
Thanks for asking.
Apr 04, 2011 | Sanyo Microwave Ovens
Sanyo microwave not heating. Light on at top rigt hand corner
Unfortunately when the microwave stops heating and everything else still works, this means your magnetron shorted out. The magnetron is the part that heats the food and also is the most expensive part. It is almost cheaper to buy a new microwave and taking into account the hassle of replacing the magnetron, I recommend just getting a new microwave. Let me know if you need anything else.
Benjamin
Nov 04, 2010 | Sanyo Microwave Ovens
Replace light bulb on SANYO EM-U1000W Compact Microwave Oven
PLESE BEFORE YOU DO ANYTHING RFER TO A GUI HOW TO DISCHARGE A HIGH VOLTAGE CAPACITOR OR SEEK THE HELP OF A MICROWAVE TECHNICIAN. As for changing the bulb, if you remove the case you will be able to locate the bulb, and merely a case or removing ad replacing with a new one. Good luck.
Nov 16, 2009 | Sanyo Microwave Ovens
Sep 16, 2008 | Microwave Ovens
Microwave won't heat anything
take the cover off the machine and look for a 13amp fuse that supplys the tranformers. BEWARE!!!
when you open the machine disconnect from the mains and do not touch the high power circuits the capacitors can hold a charge that can kill.
Jul 06, 2008 | GE JES1142SF Microwave Oven
Sanyo microwave
Could be the Magnatron, Diode, HV Cap or Transfomer, some also have a high voltage fuse that blow. Unless you really are confident playing with Very High Voltages, and have a meter capable of 5000v, I dont recommend you repair yourself as a microwave will happily electrocute you. Also if the discharge resistor has burnt out on the cap (assuming it was fitted on your model) the capacitor can store enough power to kill you even when the unit is unplugged so you must discharge the cap before playing with anything else to be safe.
Mar 14, 2008 | Sanyo EM-Z2100GS Microwave Oven
MICROWAVE BULB
Hi There!
Most microwave ovens today requires you to remove the cover to replace a lamp. Normally situated next to the Magnetron. Check the inside cavity for tiny holes where the light is suppose to shine through. This will indicate where the lamp is situated. Remember to unplug from mains before opening the unit and try not to touch the High Voltage components. They may still be charged. Good Luck, JUS004
Feb 26, 2008 | Microwave Ovens
EM-P672W
Is anything working? Light when you open door? Is your area prone to have Voltage Surges? Did anything else in your home fail at the same time? These may sound like DUMB questions, but they are necessary.
If the light comes on when door is opened then the FUSE is ok. If the light comes on, but nothing else, you have lose a Control Panel. Perhaps from power surges.
Jan 27, 2008 | Sanyo EM-P672W Microwave Oven
Sanyo Super Showerwave out!
Sounds like a bad connection inside. unplug the power, take off the cover, look over all the connectors closely.
Dec 31, 2007 | Hotpoint RVM1435 Microwave Oven
Microwave Ovens Logo
298 people viewed this question
Top Sanyo Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
robert landry
Are you a Sanyo Microwave Oven Expert? Answer questions, earn points and help others
