Question about Goodman CLQ36AR49 Air Conditioner
Electric furnace runs but won't shut off on heat setting
I have a Kenmore (Goodman) heat pump unit 7 years old. Approx. 2 years ago Sears changed some sequensors and I have had problems since. First of all they cut plugs off original wire harnesses, why I do not know. But now on heat mode when thermostat set at certain room temperature furnace will run and keep rinning forever after reaching set temperature unless I set thermostat down 2 or 3 detgrees manually. Also while running to reach set temperature it will sometimes drop 4 or 5 degrees befor reaching set themostat temp. Sears has looke at, but since they created this problem seem to be lost in reolving it. What is causing this problem?
    Scholar:
  • 144 Answers
I would insist that Sears either have a Senior tech come out and fix it or return it to the state it was prior to them touching. Then call some one else. Have them involve the Goodman rep in your area.
Posted on Jan 20, 2009
How do i find out the year my a/c unit was built?goodman a/c unit ?
Year model is the first 2 numbers in the serial number on the placard.
Aug 23, 2014 | Goodman Heating & Cooling
5 ton goodman package unit
I guess this is a heat pump unit, check the change over valve in the gas circuit, sounds like the solenoid on the valve is burnt out
Mar 24, 2014 | Heating & Cooling
Heating elements not energizing on Goodman AFUE 60 air handler
FIRST i would use a multi meter and check elements for power. one or more may not be working. SECOND iwould check sequenser . also look for burnt wires at element and throughout. probably sequensor they are usually under 20 dollars. the wires on very bottom of sequensor should have 24 volts when heat is on.
Jan 21, 2014 | Goodman Heating & Cooling
Where can I find the specs for an earlier Goodman heat pump?
You say 2 to 3 years... I'm assuming the unit is older than that. Especially being r22. What about the first 10 years??? Normally you will get 400 to 500 sqft per ton of cooling, but, that depends on heat load calculations. If the unit wasn't big enough you would have had this issue 10 years ago, not when the system kept running low on refrigerant. At first guess I would say a 2 ton unit is not big enough but if it worked fine for 10 years...wuth all that in mind, if it were me, (a seasoned professional) I would spend 1800 to fix my 15 year old r22 unit before I spent $4000 on a new r410a piece of junk. Best Wishes!!
Jun 29, 2017 | Goodman GMS90703BXA Heater
We installed a goodman heat pump in Nov 2004 to replace the goodman heat pump that was installed in the new house we bought in 1991. We looked the years of service we got out of the old unit which is why...
WELL THE TECH SHOULD HAVE A LEAK DECTOR AND CHECK THE COIL AND LINE SET FOR LEAKS THE REFRIGERANT IS LEAKING SOMEWHERE THAT DOES'N HAPPEN IF NO LEAK. A LEAK CAN CAUSE ALOT OF OTHER PROBLEMS
Aug 11, 2011 | Goodman Heating & Cooling
Goodman ck36 1b a/c. Capacitor replaced 2 years ago. Unit is 13 years old and thermostat is Honeywell, also 13 years old. This summer there seems to be a 3-5 min delay (from when thermostat registers call)...
If you have a AC unit with electric or gas its doing what its supposed to do, let the pressures in the system equilize before starting again, If you have a heat pump its doing it there as well you just have not noticed. Anti cycling is a good thing, 4 to 5 minutes is normal.
Jul 05, 2011 | Goodman Heating & Cooling
3 year-old Goodman compressor/heat pump terribly loud @ start
I don't think this problem (btw I agree 'from a far distance' with the Hvac guy) is inherant to Goodman, after all the compressor (that is in the unit) is one that if found in other brands too.
Of course the compressor is under warranty so there's no charge for it - but - $800 to change out the compressor (and that's the proper fix) is a 'bit' high - you possibly could save a few bucks by getting some other estimates.
good luck!
May 09, 2010 | Goodman CKL60AR60 Air Conditioner
Fan not running on Heat Pum
That does not sound normal at all, I have a Goodman Heatpump and the Fan on the Evaporator (outside unit) should run as soon as it starts up!
The only delay you should be seeing is when the unit starts, the fan in the AHU starts 5 seconds after and runs for about 1.5 minutes after shutdown.
Sep 19, 2009 | Goodman CLQ36AR49 Air Conditioner
No heat in any selection Kenmore Model 110.60612990
remove the back panel and check the heater box fuse and the heating element-mike
Jul 24, 2009 | Kenmore 64902 Electric Dryer
Electric furnace won't shut off
It sounds like a bad or badly miswired T-stat
Jan 20, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
220 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
