Bosch WFL 1660front loader wont spin or drain
Made a thumping noise during the spin cycle for a few weeks before stopping.
    Sergeant:
  • 291 Answers
See if the drum will wiggle up and down. There should be no free movement. If so the bearings likely need replaced.
Posted on Jan 07, 2013
  • Deborah Jan 07, 2013
    Thanks everyone. I checked to see if it was the bearings. This was one of my earlier thoughts and my worst case scenario. By using the above method I thought it was probably not the bearings. It turned out to be coins and other obstructions which we removed easily! Voila!
SOURCE: My Bosch 2060 Front end loader will not drain/spin
Get the pennies or dimes out of the accordian style black hose at the bottom of the washer. You will need to lay the washer against something so you can get in from underneath. Take a plyers and squeeze the medal clamp so the hose can slip off. I found 3 dimes that acted like washers. The machine will drain.
Posted on Jul 19, 2008
  • 1462 Answers
SOURCE: Bosch WLF 2260
suspect you have filter blocked or a foreign object in pump. put drain hose as low as possible in a bowl and drain as much water as you can undo filter but be carefull, water will come out in considerable quantities. clean filter check nothing stuck in pump impellor
Posted on Jun 14, 2007
  • 4 Answers
SOURCE: Bosch wfl 2450
Just fixed the same problem - new brushes on ebay were only £5. Fitting the brushes was fiddly and easiest if you take the motor off, which was easy to do (just 2 bolts).
Posted on Sep 05, 2008
  • 38 Answers
SOURCE: making screeching noise during spin cycle
Problem: very irritating squealing sound when washer is spinning or coasting to a stop after the spin cycle.
Case:  1. Snubber damage defective.
           2. Foreign material (sand/dust or grit) is on the base.
Solution: 1. Replace the snubber.
                2. clean base.
     The snubber is a ring that is located between the convex (domed up) center portion of the base and the domed down center portion of the LEG & DOME ASSEMBLY.
     The snubber has teflon strips at the top and bottom edges that slide easily on the base as well as the underside of the leg and dome assembly.
     This system makes the machine very stable by providing isolation between the leg & dome assy. Which carries both the inner and outer tubs, as well as the main motor and transmission and the base; which is of course connected to the cabinet. This means that the machine is capable of spinning out of balance loads.
     As simple as this system is, if one on the strips is bent or there is some foreign material on the base in the snubber area, the result can be an extremely obnoxious scratching or squealing sound that can make the consumer very unhappy.
     A very similiar sound can be produced when the belt is worn but the difference is that a snubber noise can be produced during the spin cycle or when the cycle has finished and the spin tub is coasting to a stop. A worn belt noise can only be produced while the motor is actively engaged in spinning the spin tub. If it is discovered that the belt is worn and the base has black, shredded belt residue then it may not necessary to clean it out (belt residue generally will not cause a problem with the snubber). It will be necessary however, to find the cause of the belt failure.
     The following procedure should be followed to diagnose and eliminate this condition:
Removing the snubber:
The base must be wiped whether the snubber is replaced or not.  Any residue whether it is dust or grit of any kind (other than belt residue as noted above) can cause the objectionable sound to occur.
Remove the front service panel and place the timer in the spin cycle and start the machine.  You want to try to duplicate the complaint.  Inspect the base for sign of any foreign material.  Lift the top panel up and over and lean it against the rear wall.
You will need a tool to raise the entire Leg & Dome Assembly (to which the main motor, tubs and transmission are attached).  The machine will not need to be disassembled; the springs will not even be released.
Some Techs use a length of two-by-four" to raise the assembly.  A pry-bar makes a superior tool when combined with a block of wood to act as a fulcrum (or pivot point).
Before raising the assembly, pull forward on it so that when you do raise it, the rear of the tub cover does not catch on the rear cabinet frame as it is being lifted.
Using your body weight, raise the assembly high enough to slide the snubber out.  You will need to inspect the snubber for defects or damage.  It is a good idea to be prepared with some sort of supports (like 3/4 inch pieces of wood) to slide between the lower edge of the assembly and the base to help support it if it were to slide off your pry-bar.
Posted on Mar 14, 2009
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
What is the life expectancy of Bosch front loader (under counter)? Making loud noises during wash - not spin - cycles. Worth repairing?
not long. have a Bosch Axiss WFL 2060. It started making buzzing noises starting about a year ago and I ignored them. It failed and I am replacing either the motor or/and more things. If ur a DIY its definitely less expensive than a new machine. dwkendall sends
Dec 27, 2010 | Bosch WFK 2401
Started making loud "clicking" noise
Blocked pump, open flap bottom right, drain off excess water manually and remove pump filter. Make sure you get right down and have a look in at the impellor and give it a turn to make sure its free to rotate. You'll probably find a coin, button etc that is catching the pump impellor. When you start a cycle the pump engages for a few seconds and then the w/m takes in water, so if something is stopping the impellor rotating the w/m will not start.
Best of luck
Jul 13, 2010 | Bosch Axxis WFL 2060 Front Load Washer
My Bosch WFL 1220 MAXX F/L washing machine stops during a cycle
The diagnostics are finding a proble. Usually a time out on the fill or empty. Check water supply is clear and that the drain filter is clean
Dec 08, 2009 | Washing Machines
Clicking noises
IF APPLIANCE IS RUNNING OK I WOULDNT WORRY TOO MUCH THE CLICKING YOURE HEARING IS PROBABLY THE HEATER RELAYS SWITCHING ON AND OFF AND THE MOTOR REVERSING RELAY ALSO NORMALLY THEY WOULD NOT BE HEARD OVER NORMAL RUNNING NOISES OF MACHINE.
Sep 11, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Water wont drain from my front loader bosch axxis washer and no spin cycle
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
May 05, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Banging noise on spin cycle
most front loaders are balanced by a large: ready for this: cement block inside at the top of your machine and because spin is so fast it can sometimes hit inside your machine or it has brokin a peice off ,sorry but yours going to have to get the repair person out.adrian
Feb 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Jul 08, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Danby washing machine noisy only during spin cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
Jan 13, 2008 | Danby DWM99W Top Load Washer
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
