Question about Panasonic Microwave Ovens
Panasonic NN-CF760M error H97 - Panasonic Microwave Ovens
5 Suggested Answers
robotek
  • 1512 Answers
SOURCE: h97
Hi there..
If it is displaying error H97, this means that the invertor(power supply Panasonic part number: Z606YM300BP,) is not functioning. The magnatron may also be faulty.
You can get a new invertor on ebay.UK from here
Here is some more information about the part. The microwave may also have a faulty magnatron. If you are unsure, then you should get someone to look at the unit for you before you go buying parts.
BEWARE... VOLTAGES INSIDE MICROWAVES CAN KILL
Panasonic part number: Z606YM300BP, supersedes all previous versions of the inverter used with the 2M261-M32J This Inverter is now available at a lower cost, it used to be £60.00 plus VAT and delivery trade price.
This inverter is fitted to many of the more recent Panasonic inverter type microwaves such as the NNC596S .Some microwaves such as Bosch and Siemens also use this inverter as they are rebranded Panasonic ovens. These ovens are upmarket models, some include advanced functions such as steaming and are normally well worth repairing.
The inverter as fitted to earlier ovens with the 2M236-M42 and 2M236-M1 is also available.
An inverter microwave oven is one without a high voltage transformer You will know you have one as it is not extremely heavy at one end. This type of microwave uses a high power DC converter, called an inverter, to produce the high voltage and filament voltage required by the magnetron.
If you purchase this item for replacement in your microwave then we recommend that you do this only if you are qualified and aware of the dangers of tampering with electrical equipment.
Failure of the magnetron is common and at times the inverter can fail as well. Sometimes the inverter fails on it's own. If your microwave blows the 10 amp mains input fuse as the cooking cycle starts then you probably need a new inverter. An instruction sheet with basic guidelines on fitting will be provided but please do not purchase this item unless you are confident about fitting it. We only accept returns if the inverter supplied is defective which is extremely unlikely.
If you have one of these ovens that is not cooking then it is worthwhile looking at the magnetron. It often shows signs of distress through overheating.
As well as the inverter failing it is also possible you could also have a defective magnetron,
Good luck and thanks for using FixYa
A FixYa rating would be spot on for this information to you.
regards
robotek
Posted on May 07, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: panasonic microwave no working at all
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Dec 28, 2008
fathitkf
  • 1871 Answers
SOURCE: error code h97, on a genius prestige microwave -
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Posted on Apr 13, 2010
  • 8909 Answers
SOURCE: My Panasonic NN-ST657W microwave has
There is not a lot the layman can do except maybe to try a new magnetron.
It is a job for an experienced Panasonic Microwave repair man.
Posted on Dec 31, 2010
Testimonial: "That's what I was dreading. Might be cheaper to buy a new microwave than to have a new magnetron put in... sucks only 3 yrs old. Thanks anyway."
Error H97 on Panasonic Inverter NN-SF 550W microwave... working but not heating food
Likely inverter problem. For the testing procedure,go here:
http://educypedia.karadimov.info/library/Inverter.pdf
Sep 05, 2016 | Panasonic Microwave Ovens
What does H97 mean?
It is an error code that means ether the magnetron or the inverter is bad.
Oct 16, 2014 | Panasonic NN-SD372S 0.8 cuft 950-Watt...
H97
Call Panasonic (905) 624-5010.
Jun 12, 2014 | Panasonic NN-P295SF Microwave Oven
Panasonic nn-sn778s microwave shuts off and no heat- H97 is error code
You can find an authorized Panasonic servicer here.
Aug 21, 2012 | Panasonic Genius Prestige Nnsd997s -...
Error code h97, on a genius prestige microwave - nn-sd787st. what does this mean?
Hello :
WARNING :
good luck .
Apr 13, 2010 | Panasonic NN-SD797S Microwave Oven
Panasonic microwave no working at all
Dec 27, 2008 | Maytag MMV4205 Microwave Oven
Microwave Ovens Logo
97 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
