Question about Canon PIXMA MP150 All-In-One InkJet Printer
Paper Jamming The printer is only feeding the paper thru on the right side, it starts feeding and then james on the left side. Can't print on any kind of paper. I've checked for small pieces of paper--don't see any, have tried clearing the dust out of it... Not working, can anyone help or have any suggestions ?
    Sergeant:
  • 390 Answers
Could be a faulty roller, or jam you have not found yet. Check again with a torch right up insied unit. If no go, try uninstalling and reinstalling printer.
Posted on Aug 11, 2007
Canon mp280
The printer hardware should even this out when printing. You should also ensure the paper meets the automatic feeder requirements of the printer.
If printing is skewed, feeding multiple pages or jamming, please follow these instructions (use a regular letter size paper to test after doing the steps given below):
Please check to ensure there is nothing obstructing the paper feed mechanism down inside the printer where it is not easily seen. If there is nothing obvious, unplug the printer and remove the paper. Open the front cover and look above the steel rod. You should see a conveyor belt with rubber teeth on it, like a fan belt. Take the bottom part of that belt and move it gently to the left. The cartridges should come out with it. Make sure the cartridges can move fully from one side of the printer to the other. Check also the output rollers on the bottom of the printer for any blockage. If it is jamming under the carrier assembly, you may be able to fix it using the manual feed slot. Turn the printer off. Next take a #10 envelope and feed it through the left side of the paper feed slot (The manual paper feed slot is preferred, but the automatic feed will do if there is no manual paper feed for this printer) until it comes completely through the printer to the back of the exit rollers. Move it up and down and slowly move it over to the right side. If something is stuck under the black guide plate this may work it loose or you may have to feed the envelope through the front rollers and push your way backward (please be careful here).
Next, take a damp warm cloth and clean the rubber rollers in the automatic sheet feeder. Dust may be coating the rollers there and as they become less tacky, they cannot feed paper correctly.
Finally, turn the printer upside down and carefully shake it for 10 to 20 seconds to see if something falls out of the paper feed path. Then plug the printer back up, take your paper out and replace it with a fresh, small stack (about 5 pages) of paper. Quickly bend the stack in an 'S' shape a few times to separate pages. Make sure it is lined up on the right side of the paper feed and the paper guide on the left is snug on the left side of the paper. Then try to form feed again. If that works, then try to print again.
May 13, 2013 | Canon Office Equipment & Supplies
Printer problem
May 12, 2013 | Canon MX300 Office All-In-One Printer
Z42 not feeding paper
Regards,
Sanath
Feb 20, 2013 | Lexmark Color JetPrinter Z42 InkJet
JAMMING IN THE FINISHNER
Good Luck!!!!!
Sep 25, 2011 | Office Equipment & Supplies
Paper d,ont feed unblock paper but no paper stuck
Good Luck!!!!!!!
Sep 25, 2011 | Lexmark X5495 Printer
When we try to print keeps saying load paper even although there is paper in feed tray. We have tried removing and replacing apper still same problem Printer just does not seem to register that there is...
Good Luck!!!!!
Sep 24, 2011 | Lexmark X4530 InkJet Printer
Paper is constantly jamming on right hand side-as you face printer-it feeds in unevenly as soon as I start to print.
Remove all print paper from the paper tray. check if there are any dust particles or any other substances that might be jamming the paper. That is the only fix.
Dec 20, 2010 | Epson Stylus RX650 All-In-One Printer
Pper jams
May 27, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
I replaced ink and paper..paper keeps jamming when printing and copying. after the replaced inl and paper, i was able to print with no problem however without warning iunable to print or copy without...
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Oct 20, 2008 | Lexmark Office Equipment & Supplies
Printing
It almost sounds as if the guide on the left side has been moved. Reload the paper so it is up against the right side of the paper tray and then move the left guide up against the paper.
Judy F.
Aug 28, 2008 | HP DeskJet 6122 InkJet Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
old marine
old marine
