Question about Asko Dishwashers
Where is the pan or tray locate d3122 asko dishwasher
Model d3122
5 Suggested Answers
SOURCE: asko d/w d3122 Hi gang the overfilling
Have a look to make sure that the pump and drain hose are unblocked. If they are, you might have to call Asko and arrange a service call.
Posted on Oct 08, 2008
  • 42 Answers
SOURCE: Overfill Protection tripped on ASKO D3112 dishwasher
remove the front toe kick. you should have 6 torx screws. four in the top 2 in the front. your float switch will be in the front center .the float is a piece of styrofoam - the float many times is what you find jammed up making the unit believe it has water in the base
Posted on Dec 21, 2008
  • 127 Answers
SOURCE: how can we get to the base pan in our asko d3350
if this is an under counter unit you will need to remove the unit to gain access to the sides where you may be able to drain that base pan. some of these fancy things require you to remove the side panels to get to that pesky base pan..
hope this helps,
best of luck,
ttfn
Posted on Oct 25, 2009
SOURCE: The pump on our Asko
d3122 Asko Dishwasher fault code F2 - how do you stop pump runing and reset?
Posted on Jan 05, 2011
Asko D3122 WAX MOTOR
Can plug in either way. If was meant only one way, the plug would have a blocking protrusion on one side. Plus the motor will run only one direction no matter which side is the hot side of the wires. As long as is getting power, it will work.
Nov 11, 2014 | Asko D3122XLSS Stainless Steel Dishwasher
Start light flashing. Dishwasher wont start
I'm guessing as you did not list the model number. Something similar happened on mine. Due to a freeze, there was a small crack in the inlet and water had slowly leaked. As a safety feature, the Asko has a tray under the dishwasher inside the overall dimensions. It has a float. When the float rises, the drain pump starts and the dishwasher will not start. In my case, the drip pan is not connected to the drain which gave me the drain sound, but did nothing to remove the leaky water.
I suggest you take the front bottom panel off the dishwasher and check for water/leaks.
Oct 29, 2014 | Asko 24 in. D3121XL Free-standing...
Asko Dishwasher D3122 fills with water and stops
if the heating element has failed the water temperature will not reach the trigering threshold to allow the timer to advance to the next program step good luck !
Dec 26, 2013 | Asko Dishwashers
Dead circulation pump capacitor: I have an Asko
Capacitor should have a uF and voltage rating stamped on it. They are NOT a one-size-fits-all.
Always keep your Owners Manuals so you can use it to get parts. Without seeing it myself, the part will probably have to be replaced.
Sometimes you can find the manufacturer online and get parts through their website.
Possibly find this capacitor at an AC shop.
Oct 29, 2013 | Dishwashers
ASKO D3122 PUMP STAYS ON AND MACHINE WILL NOT SWITCH ON
The machine has activated a safty seq. There is most likely water on the lower buttom. Leakage or drain pipe blocked. The power will get to the drain pump, when this happends. To prevent overflow on your kitchen floor. Dry out the water. Then it will start as usual.
Jul 25, 2009 | Asko D3122XLSS Stainless Steel Dishwasher
Asko D3122 dishwasher will not fill with water and will not turn off
you may have water under the dishwaher ... have any plumbing work done lately?
if the dishwaher overflows or leaks it will trip a float switch under the dishwasher... as long as it is triped it will run the drain pump.. and not let any water into the tub...
the water will have to be removed and the leak stopped before it will run a cycle....
Hope this helps if not let me know more about your problem..
Mar 20, 2009 | Asko D1876 Dishwasher
Asko d/w d3122 Hi gang the overfilling protection has been activated, what can I do to remedy the sitution. regards banger35
Oct 08, 2008 | Asko Dishwashers
Asko D1706
I also had this problem. Support person couldn't tell me if the pump was supposed to run even when setting the control knob to 'off' (bar before (1)). After draining the pan, the control knob functioned normally. So apparently any power to the unit will run the pump when the overflow pan is filled, no matter the position of the knob.
Sep 10, 2008 | Asko D1706 Built-in Dishwasher
Dishwashers Logo
Top Asko Dishwashers Experts
John Tripp
John Tripp
Owen Barnes
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
