Question about Dell Dimension 8400 power supply ** FREE ** (D8400SATA300W24PINB) Power Supply
Dell Dimension power problem
My Dell Dimension 8400 stopped powering up last year and was giving a blinking amber light. It stayed like this for about a month and then powered up one day!! It was fine all last year except for once when it did the same thing then powered up after one day. Last week, it did the same thing and is not powering up!! What is up? The problem seems so random.
p.s. I bought it from the states but I am using it overseas where the power is 240 not 110. Also, its power supply was damaged before due to a misconnection and was replaced by the original Dell Dimension 8400 power supply from Dell.
Any idea what is going on? Is this a common problem with the power supply of this model?
  •  Marcus Draper
    Marcus Draper Mar 31, 2009
    I had the same problem and did a lot of research on different forums.
    http://www.tomshardware.com/forum/51352-...
    Thsi forum really had 3 different solutions but replaceing the Power Supply was the fix for me. They had also suggested replacing the Mother Board as well as the CPU. Luclily it was a $40 fix for me but if you are looking for the mother board you will have to go directly to Dell or get another Case to for a new Mother Board.
    Anyways, I hope that you have solved your problem by now.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
There are several different solutions for this as posted at this Forum.
http://www.tomshardware.com/forum/51352-2-dell-dimension-8400-wont-boot
1) A lot of people have just removed the Jumper for the CMOS and turned the Power back on and back off and replaced the jumper and/or removed the battery.
2) Several people have reseated the Memory and after booting back up it worked.
3) A few had to replace the Mother Board and CPU but in this instance they had to also replace the Case because the Dell case wasn't really fit for the heat of from the CPU.
4) I had the exact same problem and luckily replacing the Power Supply fixed this for me. I had to cut out the back of the Dell case for the toggle on/off switch but when I tested the old Power Supply it was only getting 5amps and this was causing the Amber/Orange/Yellow light to constantly flash.
I hope this helps!
Posted on Mar 31, 2009
  • 41 Answers
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
Posted on Jan 20, 2009
2 Suggested Answers
proton77
  • 1183 Answers
SOURCE: Dell Dimension 8400 power supply
It not a common problem. The problem that you are facing is is beacuse of faulty motherboard. The blinking amber is caused , becasue the motherboard is not able to distribute the power signal to the devices . You can follow the link below to trouleshoot the problem if you are comfortable in opening the computer chassis
http://tinyurl.com/8mkpnm
Thanks
Proton
Dell dimension 8400 blinking amber light ethernet port
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Since you replaced the power supply, my guess is that the motherboard has a problem.
Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Jul 27, 2012 | Dell Dimension 8400 PC Desktop
Dell 8400 dimension desktop on start up the fan runs at top speed like a jet engine taking off, and power light is constant amber with a blank screen. I have removed ram and grafics card etc and replaced...
Your power supply or motherboard has a problem. You can try getting a power supply on the internet ( $25 to $75) first. If no go then motherboard (about $100 to $200 ). The 8400 is about 6 years old which is the average lifespan of computers. One last thing you can try is removing the heatsink assembly and re-seating the processor. You have to clean the old thermal compound from the CPU chip and heat sink and reapply the compound (thermal paste). You might be better off buying a new computer from Walmart.
Feb 26, 2011 | Dell Dimension 8400 PC Desktop
My 6 year old Dell Dimension 8400 quit working completely.
Depending on the symptoms, you may have different faults.
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
Flashing Amber power LED, normally power supply
AAGG Diag LEDs normally bad RAM
Solid Amber Power LED, bad motherboard or Expansion card connected to it.
If you need a motherboard a Precision Workstation 370 motherboard is essentially the same and is available, (8400 motherboards are scarce)
http://shop.ebay.com/i.html?_kw=T7787&_kw=DELL&_kw=Motherboard
Feb 05, 2011 | Dell Dimension 8400 PC Desktop
My dell dimension 8400 canot boot up at all and the Diagnostic Lights not light oso..so wat i can do?
The POWER and DIAG LEDs can give you information. If no DIAG LED look at the POWER LED
Flashing amber, most likely the power supply
Solid Amber, motherboard or item plugged into the motherboard (Expansion card, external connection etc.)
Apr 17, 2010 | Dell Dimension 8400 PC Desktop
Dell Inspiron flashing amber power light, not charging
I would think the batteries need replacing. That happened to my Dell Latitude CPI. The batteries won't charge past about 3%, so I got new ones and that did the trick. If this is under a year old I would contact Dell about it, if it is under a year old they should replace the batteries.
Hope this helps.
Feb 23, 2009 | Dell Dimension 8400 power supply ** FREE...
Thanks
Proton
Jan 20, 2009 | Dell Dimension 8400 power supply ** FREE...
Have a yellow amber light blinking
A Blinking Amber or Yellow power button means that the power supply is receiving power from the source but is unable to properly distribute it to the components. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Dec 25, 2008 | Dell Dimension 8400 power supply ** FREE...
My dell 8400 will not start up. power switch blinks amber.
you need a new power supply. go to a store called microcenter or any place that sells computer parts and ask them for a "Sata Power supply 300 watt" it shouldn't cost you no more than 40 dollars
Nov 27, 2008 | Dell Dimension 8400 power supply ** FREE...
Computer Won't Power Up
If the blinking amber LED is on the computer itself and not the monitor, this is most likely a power supply issue. First thing to try would be replace the power supply. If the blinking led is on the monitor, it probably has bad capacitors and needs to be replaced. (or repaired)
Jul 15, 2008 | Dell Dimension 8400 power supply ** FREE...
Woes with Dell
If the power light is steady amber, a device might be malfunctioning or incorrectly installed.
Disconect fan , see if it starts.
Jan 13, 2008 | Dell Dimension 8400 PC Desktop
Computers & Internet Logo
789 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
