Question about Kohler K-8803-VS Duostrainer sink basket strainer, Vibrant Stainless
Small rubber replacement cover rack feet
Rubber sink rack foot pad
5 Suggested Answers
landsend
  • 1066 Answers
SOURCE: Kitchen sink protector (plastic coated wire)
online.
Posted on Mar 09, 2009
  • 2976 Answers
SOURCE: plastic coated sink protectors - rubber feet deteriorated
You can get a product called Plasti-Dip at your hardware store. It is the stuff used to plastc coat tools.
Posted on Jul 02, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: Where do you find replacement
Sorry to read about your problem, I hope this helps you out.
You an contact Kohler direct, they will send a replacement
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Posted on Dec 29, 2010
SOURCE: I need to find replacement
Call Kohler Plumbing customer service: 1.800.456.4537, choose option 2 for service parts.
Tell them you need a "Feet Replacement Kit" for whatever model name/number and color your basement rack is. Prices run about $1 per piece plus shipping.
Posted on Nov 14, 2012
Can i replace base "feet" on singer 338 sewing machine?
many home improvement stores sell rubber feet that you could glue or screw on .
Feb 12, 2017 | Singer Sewing Machines
Feet for Acuvibe 5004 foot massager
Take one of the rubber feet to the hardware store and see if they can sell you replacements.
Oct 10, 2016 | Sewing Machines
I need to find replacement white rubber feet for my Kohler sink basin rack,
Feb 12, 2011 | Kohler K-8803-VS Duostrainer sink basket...
I need to buy replacement rubber feet for rival slow cooker. I cannot find a web site that sells them.
I found what appears to be an exact replacement rubber foot for the Rival oval crock pot at ACE Hardware. They're called a "Rubber Bumper" and the part number is #405756. Amusingly this was in the "Automotive" drawer in their small parts area, labeled "General Use: Ford". Ha! Anyway, I had two missing rubber feet and after installation I can't tell these replacements are any different than the originals. Or look here: http://wedo.hillmangroup.com/item/products-19/ts-maintenance-accessories-products-rubber-bumpers/405756-a
Jan 31, 2011 | Rival SCV702 Slow Cooker
The flexifoot on my old baracuda is split
What do you mean by flexifoot, and what do you mean split? The large rubber disc is called the "durometer" disc (on the G3 it's called a finned disc). The small rubber pad the the big one fits over is called a "foot pad", the foot pad fits over a hard piece called the foot plate. That being said.... if your referring to the durometer disc being split, or torn, I assume it is very worn out and needs to be replaced. if it's new and torn then it may still work fine. if it is worn out chances are you need to replace the foot pad, and possible a couple other pieces.
Sep 16, 2010 | Zodiac Baracuda G4 Automatic Pool Cleaner...
Need rubber foot for frigidaire professional series gas stove iron grill. My stove has three grills, each grill having 4 rubber (rivit-looking) feet. Apparently the missing foot, as small as it is,...
I just had my stove serviced today. You can purchase a foot kit for $30. The part # is 5304475129. http://www.mdappliance.com/ELX-5304475129.html. I could not find a place that only sold the rubber feet. Clean any debris from the hole that the rubber feet goes into. Add a small amount of the high temperature adhesive in the hole. Insert the rubber feet back in. The rubber feet has a pin point hole in the middle. Insert a paperclip in the hole and stretch out the sides of the rubber feet, so the sides stick to the adhesive. Place the grates back onto the stove and let it sit for 2 hours. Good luck.
Feb 06, 2010 | Kitchen Ranges
Archos 5 60GB media player Audio Jack has bad solder connections
First pry out the small rubber feet in the plastic end covers. There are three of them. The plastic cover near the fold out leg can be fully removed by unscrewing the two screws, one expossed by the leg being folded out and the other exposed by the rubber feet being removed. Remove the other two screws from the second plastic cover, do not try to remove this cover. The display metal cover has three small holes along the side. Using a push pin press in each hole releasing the well designed integral spring latch at each location. You may hear them click as they release. Small rubber pads inside the assembly help separate the covers as they are unlatched. The display cover with display will lift straight up off the latches but just enough to be able to hinge it on the flex connection to one side. You will have to rest it against something as you repair any broken solder connections of the audio jack.
When closing up the Archos case do everything in reverse order from the above explanation. A helpful hint is to lay the Archos on a flat surface and slowly guide the display cover onto the latches so they just slip evenly inside, watching to insure the connector baffle and power button also slip inside the cover. When everything looks evenly engaged you can press the cover compressing the rubber pads and latching the metal covers together. replace the screws, plastic cover and rubber feet and your done.
Dec 06, 2009 | Archos Internet Media Tablet MP3 Player
Why does my EPIC z walks during spin cycle even after I used the rubber pads? It moves from the right back corner out to the left.
Make sure that the leveling feet are secure with the jamb nut tight against the BODY of the washer. If not, the washer could walk during spin. Make sure that washer is flat level front to back and side to side with a 24" level. Just set the level on the top near the front and then on both sides as well. Adjust the feet and jamb nuts so that they are as low as possible. If washer is on a stand, remove drawer to adjust feet. Also, if on stands, washer will vibrate more due to increased height and natural flexion of stand. What kind of flooring? If ceramic tile, rubber feet may not couple to surface and provide enough friction to stay in place. I have had success with......I know it might sound stupid.....but buy a couple rubber jar opener pads and cut them into small pads. Put them under the rubber feet of stand or washer. These seem to make a better connection to the floor.
Aug 01, 2009 | Washing Machines
Plastic coated sink protectors - rubber feet deteriorated
Mar 09, 2009 | Kohler K-8803-VS Duostrainer sink basket...
Rubber feet
Yes, with the model number.
But in the meantime, you should sand and clean the arcing part until it's smooth.
I'd consider a little vinyl or electrical tape on the end to protect your metal in until it can be replaced.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 01, 2008 | Panasonic NN-C994S Convection/Microwave...
Kohler K-8803-VS Duostrainer sink basket strainer, Vibrant Stainless Logo
94 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
